Parking brake
woxofswa
PostPosted: Fri Feb 06, 2009 2:31 pm    Post subject: Parking brake Reply with quote
I would appreciate the brain trust opinion on parking brake installation.
I have one in my Socata and find it very useful. Are there downsides other than cost and more seals to leak?
Are the Van's valve and install kit the way most are doing it or are there alternatives?
Thanks in advance.
Myron Nelson
Mesa, AZ
Flew May 10 2014
jeff(at)westcottpress.com
PostPosted: Fri Feb 06, 2009 4:54 pm    Post subject: Parking brake Reply with quote
Hi Myron,
It's pretty easy to roll your own bracket for mounting. I made mine
from 3/4" angle and Nick Gautier gave me a duplicate of his plate
design that you see between the bracket and valve in the picture
attached that will hold the adel clamp for the vernier cable and
forms the stop for the arm on the valve. The valve, straight
fittings and other odds and ends shouldn't reach $200.00... and you
can get it all from Spruce.
Jeff Carpenter
40304
N410CF
Progress suddenly slowed by the economy
(all kinds of time, but no money for the panel)
you have the same number of connections to make
installation.
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p 28974#228974
 Filesize:  43.89 KB
 Viewed:  523 Time(s)
Deems Davis
PostPosted: Fri Feb 06, 2009 6:56 pm    Post subject: Parking brake Reply with quote
Myron, I think the parking brake is a 'no-brainer'. I assume that Van's
is selling the Matco unit. The installation is straight forward, as far
as seals go, The unit is fairly simple and easily serviced. I doubt that
you will have a leak in the airplanes useful life. Do it! (its only money!)
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
kdbelue(at)charter.net
PostPosted: Fri Feb 06, 2009 7:27 pm    Post subject: Parking brake Reply with quote
I installed the Matco parking brake in my RV10 and it didn't leak
until I started using my brakes for engine runup. Then it started
leaking out of the valve (not the fittings), so I removed it.
Kevin Belue
Van's is selling the Matco unit. The installation is straight
forward, as far as seals go, The unit is fairly simple and easily
serviced. I doubt that you will have a leak in the airplanes useful
Deems Davis # 406
Deems Davis
PostPosted: Fri Feb 06, 2009 7:51 pm    Post subject: Parking brake Reply with quote
Wow, That's news, I wonder if others have also had the same problem?
Looking at the parts diagram it looks like you should be able to replace
the 3 O-rings fairly
easily.http://matco.veracart.com/pdf/mastercylinder23a.pdf
I wonder if you could get the Vitron O-rings this size?
Deems
PostPosted: Fri Feb 06, 2009 8:44 pm    Post subject: Parking brake Reply with quote
Yes, I was thinking it would be easy to repair, but after the pain of
getting to it and removing it, I decided to not go through that again
and left it out. It is really in a difficult place to access once
everything is finished. I mounted mine the same as most of you did- in
place of the bracket that holds the brake lines to the firewall. I
hope you guys have better luck than I did.
Kevin Belue
replace the 3 O-rings fairly easily.http://matco.veracart.com/pdf/
Deems
pascal(at)rv10builder.net
PostPosted: Fri Feb 06, 2009 9:05 pm    Post subject: Parking brake Reply with quote
I would let Matco know of this. I think they would make it right based on my
experience with them thus far. Also if there is an issue, which I can't
figure out why the valve would fail so soon then they need to be aware of
it. Since yours is out already no harm calling Matco explaining the issue
and seeing if they will RMA and fix for you and figure out why the valves
are leaking.
P
Sent: Friday, February 06, 2009 7:49 PM
Subject: Re: Parking brake
Deems
Kevin Belue wrote:
> I installed the Matco parking brake in my RV10 and it didn't leak until I
> started using my brakes for engine runup. Then it started leaking out of
rv(at)thelefflers.com
PostPosted: Sat Feb 07, 2009 3:54 am    Post subject: Parking brake Reply with quote
Did you have the PVPV-1 or PVPV-D?
I just ordered a PV-2 yesterday from Van's, which I believe is the PVPV-D.
Just curious.....
Bob
speckter(at)comcast.net
PostPosted: Sat Feb 07, 2009 5:48 am    Post subject: Parking brake Reply with quote
Another leak issue is when you set the break and it is cool, go away and the
weather warms, it will blow out the seal in the wheel because there is no
place for the expanded fluid to go. This happened with solid lines, so if
you have flexible ones you might be OK. Someone with too much time on there
hands could calculate the expansion volume and let us know.
Gary Specketer
Kellym
PostPosted: Sat Feb 07, 2009 7:44 am    Post subject: Parking brake Reply with quote
I don't think any parking brake will stand up to that abuse. IMHO, a
parking brake is to hold the aircraft just long enough for you to place
chocks, or to hold it during runup so you don't inadvertently let it
creep while running checklist. Holding pressure on the system for hours
or days is just asking for a leak or failed O-ring.
Gary Specketer
Kelly McMullen
KCHD
PostPosted: Sat Feb 07, 2009 8:27 am    Post subject: Parking brake Reply with quote
The word "parking brake" is deceiving. It is not meant to be left on all the
time when "parked". It is for temporary use. set to hold plane in place
while a long term solution (chocks, etc) is completed. The parking brake is
than released before leaving.
Pascal
Sent: Saturday, February 07, 2009 5:42 AM
Subject: RE: Parking brake
the
there
Gary Specketer
PostPosted: Sun Feb 08, 2009 9:51 am    Post subject: Parking brake Reply with quote
The problem I had with the parking brake valve is where it is, not how
it is mounted. It is really difficult to bend up under the panel to
remove or install it after everything is finished. I even took the
seat out. I decided it was not worth the effort to put it back. I
haven't had a need for it anyway.
Kevin Belue
PVPV-D.
Just curious.....
Bob
Bob Turner
PostPosted: Sun Feb 08, 2009 3:45 pm    Post subject: Re: Parking brake Reply with quote
" no
hands could calculate the expansion volume and let us know. "
Actually, this is backwards. When it gets hot, the fluid expands, but the aluminum lines and brake cylinders expand even more! So theoretically you might have a problem going hot to cold. Which is exactly what happens if you set the brake after landing - some of the brake heat will make its way to the brake cylinders, and later they will cool down.
Bob Turner
RV-10 QB
