Older Firestar weight
Richard Pike
PostPosted: Fri Feb 06, 2009 7:56 am    Post subject: Older Firestar weight Reply with quote
Got a friend who has purchased an early model Firestar, 5 rib wing, there is a 447 on it, and he is concerned about total weight as well as weight and balance, because he is on the chubby side. Searched the archives, and found a plethora of stuff on Firestar weights, but nothing pertinent to the question. Appreciate if anybody with any real data can give me some numbers to pass along.
Richard Pike
MKIII N420P (420ldPoops)
Thom Riddle
PostPosted: Fri Feb 06, 2009 8:59 am    Post subject: Re: Older Firestar weight Reply with quote
Richard,
My FS1 is on the heavy side as am I. It weighs 362 lb empty and I weigh about 215 with clothing and my FS1 has a ten gallon tank. So, my typical take-off weight, before I bent it, was about 635-640 lbs and it handles(d) fine with very good performance with the 447 engine. Hope this is useful data.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
aslsa.rng(at)gmail.com
PostPosted: Fri Feb 06, 2009 12:44 pm    Post subject: Older Firestar weight Reply with quote
Roughly the same aircraft, 338 lb.
Rick
On Fri, Feb 6, 2009 at 9:56 AM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote]--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
http://forums.matronics.com/viewtopic.php?p=228870#228870
" target="_blank">http://www.matronics.com/Navigator?Kolb-List
MS -
e -
Ralph B
PostPosted: Sat Feb 07, 2009 5:50 pm    Post subject: Re: Older Firestar weight Reply with quote
Richard Pike
Richard, my Original Firestar is 319lbs empty with a 447 engine. I listed it with a gross weight of 650lb. Here are some pictures and my weight and balance sheet.
 Filesize:  135.19 KB
 Viewed:  451 Time(s)
 Filesize:  155.68 KB
 Viewed:  430 Time(s)
 Filesize:  149.98 KB
 Viewed:  439 Time(s)
N91493 FAA weight and balance submit Ralph.xls
 Filename:  N91493 FAA weight and balance submit Ralph.xls
 Filesize:  20 KB
 Downloaded:  406 Time(s)
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
