RADIUS PLATES & RADIUS BLOCKS for Grove U/C
Thruster87
PostPosted: Thu Feb 05, 2009 9:00 pm    Post subject: RADIUS PLATES & RADIUS BLOCKS for Grove U/C Reply with quote
RADIUS PLATES & RADIUS BLOCKS for Grove U/C any comments!!!! Cheers T87
 Filesize:  705.06 KB
 Viewed:  523 Time(s)
annken100
PostPosted: Fri Feb 06, 2009 4:41 am    Post subject: Re: RADIUS PLATES & RADIUS BLOCKS for Grove U/C Reply with quote
Radius plates are a good idea because they help alleviate the twisting of the bottom fuselage longerons. You can call Zenair in Canada and order the set that is used on the AMD 601 with grove gear.
Ken Pavlou
601 XL / Corvair
