Kelly McMullen
Posted: Thu Feb 05, 2009 7:58 am Post subject: Kits |
I note that on Tim's site for what is in the various kits, there are
listings for a firewall forward kit, separate from finishing kit.
However, Vans only lists empennage, fuselage, wing and finishing kits.
Has Vans changed how they package things? Or is that just a convenient
division of parts in the finishing kit?
Kelly
40866
A&P/IA, EAA Tech Counselor
KCHD |
planesmith(at)hotmail.com Guest
Posted: Thu Feb 05, 2009 8:17 am Post subject: Kits |
The firewall forward kit is listed in the web store separately. Here's a link: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233850394-2-318&browse=engines&product=FF_Kit
Vern Smith (#324 finishing)
| Quote: | Date: Thu C 5 Feb 2009 08:57:26 -0700
Subject: Kits
--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com>
I note that on Tim's site for what is in the various kits C there are
listings for a firewall forward kit C separate from finishing kit.
However C Vans only lists empennage C fuselage C wing and finishing kits.
Windows Live™: E-mail. Chat. Share. Get more ways to connect. Check it out. [quote][b]
rv(at)thelefflers.com Guest
Posted: Thu Feb 05, 2009 12:11 pm Post subject: Kits |
The firewall kit is highly dependent on which engine you get. There are too
many options, so quite a few folks roll their own. Vans does sell a
firewall kit for the 540 models they sell. It's in their catalog. You
can use those as a starting point if you get an engine from another source.
There is no overlap with the finishing kit. You can see the details here:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233864459-434-198&bro
wse=engines&product=FF_Kit The following is off the web store.
The RV-10 Firewall Forward Kits below can be ordered with or without a three
lever throttle/prop/mixture quadrant part number "CT10-3". If you opt for
the NON three lever quadrant, your engine control cables will be supplied as
vernier style.
| Quote: | From December 2007, FWF kits DO NOT contain the wiring harness.
EXAMPLE KIT FOR AN RV-7A, O-360, WITH A CONSTANT-SPEED PROPELLER:
1 VA-138 FUEL SUPPLY HOSE 14.0"
1 VA-139 FUEL SUPPLY HOSE 16.5"
1 CT BLUE VPROP 48 7(ALL)/9(ALL)
1 CT BLK THROTTLE 44 6(ALL)/7(360)/9(320)
1 CT RED VMIXTURE 45 7(360)/9(320)
1 FAB-360/540 FLTRD A/BOX-360 FI320
1 BAF-360 COWL BAFFLE KIT 6/7/8
1 VA-149-360-PC KIT THROTTLE/MIXTURE BRACKET
1 VA-153-PC McCauley or MT governor cable bracket
1 PROP GOV MT P-860-4 (I)O-320/360 LYCOMING
1 AT0-028X3/16X6 ALUMINUM TUBE SOFT
1 AT6-058X5/16X15 7/8 ALUMINUM TUBE HARD
1 SS304-26GAX1/2X9 STAINLESS CLAMP MATERIAL
1 FF 3/4 FIREWALL PL SS FIREWALL PLUG
1 ES PC680 INSTALL KIT BATTERY MOUNT 7/9
1 AS3-063X1X12 ALUMINUM STRIP
1 EA LV-1 HEAT SHIELD EXHAUST HEAT SHIELD
2 CT A-740 BLACK PUSH PULL CABLE BLACK
1 DUCT CBT-5/8 COOLING BLAST TUBE
1 EA CV HOSE 9816 BREATHER HOSE 4 CYL
1 EA DYNA BOLT BOLT SET 4 CYL DYNAFOCAL
4 EA DYNA VI-STD VIB.ISO. ALL EXCEPT-10
1 EA EXH W/MUFF 320/360 EXHAUST SYSTEM
1 EA OIL COOLER II O-320/360 OIL COOLER
1 ES 24021 STARTER SOLENOID RELAY
1 ES 24115 MASTER SOLENOID RELAY
1 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT
1 FF-705 OIL BREATHER TUBE
1 FF-709 OIL COOLER DOUBLER
1 VA-161 GASCOLATOR DOUBLER
1 IE VMP INSTALL KIT MANIFOLD PRESSURE FITTINGS
1 GAS-5 GASCOLATOR
1 PT-035X1/4X12 FUEL OVERFLOW TUBE
1 VA-102 FUEL PRES. HOSE 15.5
1 VA-168 FIREWALL SENDER MOUNT
1 VA-133 OIL PRESS. HOSE 27.25
1 VA-134 OIL COOLER HOSE 19.0
1 VA-135 OIL COOLER HOSE 16.5
1 VENT DL-03 2" ALUMINUM DUCT FLANGE
1 VENT SCAT 2X6' RED SCAT TUBE 2"X 6'
1 VENT TG-10 CABIN HEAT SELECTOR
1 DOC FWF COMPLETE TEXT/DRAWINGS
1 CT BEARING HWR, CARB BOLT, NUT, WASHERS
1 CT BEARING HWR, PROP BOLT, NUT, WASHERS
1 BAG 604-1 FF MISC. HDWRE
1 BAG 607 FF MISC. HDWRE
1 BAG 608 FF MISC. HDWRE
1 BAG 611 FF MISC. HDWRE
1 BAG 613-1 FF MISC. HARDWARE
1 BAG 958 AN426AD3-4
1 BAG 991 AN426AD3-3.5
1 BAG 1907 AN426AD4-7
1 BAG 1916 AN426AD3-4.5
1 BAG 1934 AN426AD3-5
1 BAG 1935 AN426AD3-6
1 BAG 312 AN426AD4-6
1 BAG 1978 AN470AD4-5
Kellym
Posted: Thu Feb 05, 2009 7:34 pm Post subject: Kits |
Thanks for the replies. Appreciate all that. I think it is a bit disingenuous of Vans to not list it in the kit prices <http://www.vansaircraft.com/public/kitprice.htm>, and in the price estimator to show $3400-4800 when the current price is $6000. Oh well, won't be the first chunk overlooked in budget. I don't see a whole lot changing in that kit if you stick with a 540 series engine, regardless of source, which is perhaps 98% of all RV-10s? Obviously we can choose to roll own, with the time issues to research, price, order, etc.
Kelly
Bob Leffler wrote: | Quote: | | Quote: | --> RV10-List message posted by: "Bob Leffler" <rv(at)thelefflers.com> (rv(at)thelefflers.com)
T | | [img]cid:part1.08070808.04060009(at)aviating.com[/img]
1.97 KB |
1954 Time(s) |
KCHD |
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Fri Feb 06, 2009 5:59 am Post subject: Kits |
There are definitely cheaper and better options for some of the items for the FWF kit. For instance I believe both Bonaco and Aircrafthose.com have kits to replace the Van’s hoses for less money and with integral fire sleeve. I know I went through and deleted probably about half the items in the FWF.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Thursday, February 05, 2009 9:30 PM
Subject: Re: Kits
Kelly
Bob Leffler wrote: | Quote: | | --> RV10-List message posted by: "Bob Leffler" <rv(at)thelefflers.com> The firewall kit is highly dependent on which engine you get. There are toomany options, so quite a few folks roll their own. Vans does sell afirewall kit for the 540 models they sell. It's in their catalog. Youcan use those as a starting point if you get an engine from another source. There is no overlap with the finishing kit. You can see the details here:http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233864459-434-198&browse=engines&product=FF_Kit The following is off the web store. | 01
1.97 KB |
1956 Time(s) |
