New to the forum
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Ultralight-List
RMC
PostPosted: Sun Feb 01, 2009 7:30 pm    Post subject: New to the forum Reply with quote
I am new to the forum. I am not a pilot. I have assisted in a kit build of an allegro 2000 and would like to build my own ultralight... I have little knowledge of kit building of ultralights but would appreciate any direction on what, where, and how.....
RMC from NC
- The Matronics Ultralight-List Email Forum -
http://www.matronics.com/Navigator?Ultralight-List
larry(at)macsmachine.com
PostPosted: Mon Feb 02, 2009 7:09 am    Post subject: New to the forum Reply with quote
Hi Randy,
I'd suggest finding the nearest Experimental Aviation Association
Chapter in your locale and begin attending meetings. Mutual builder
support is one of the
things that make building an aircraft so enjoyable. You build, learn new
skills and then have friends to fly with. The 701 is a light plane, but
doesn't qualify
as an ultralight. Those are maxed out at 254 lbs empty and do not
require FAA registration.
Your membership in the EAA will provide you with a good number of
suggestions for what, where and how and you only have to connect the
dots from there.
Very best regards,
RMC from NC
http://forums.matronics.com/viewtopic.php?p 28107#228107
RMC
PostPosted: Mon Feb 02, 2009 6:04 pm    Post subject: Re: New to the forum Reply with quote
Thanks Larry, I appreciate the info and I was impressed with the web link.
RMC
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Ultralight-List All times are GMT - 8 Hours
