lwhitlow
Joined: 15 Jan 2006 Posts: 76 Location: Valparaiso Indiana
Posted: Sat Jan 31, 2009 9:37 pm Post subject: EGT Probe Installation |
Ok I'm Stumped
The manual says to install the EGT Probe 100mm from the flange
Since the pipe is curved where am I making this measurement?
Anyone got any insight or a pic to help a feller out??
Larry Whitlow
601XL Jabiru 3300
BobsV35B(at)aol.com Guest
Posted: Sun Feb 01, 2009 6:20 am Post subject: EGT Probe Installation |
Good Morning Larry,
Not a big deal. You can measure on the side, front, or back. The primary thing is to have the probe location consistent from cylinder to cylinder. Even then, there will be variances.
If the carburetor, or other fuel control device, you are using allows leaning you could run a slow lean check and see just where each cylinder hits it's peak EGT, but with the Bing, I have found no way to make such a check.
Without a lean check, just make note of where they seem to run, then try to notice changes in the balance between cylinders.
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 2/1/2009 12:04:25 A.M. Central Standard Time, ldwhitlow(at)comcast.net writes:
| Quote: | --> JabiruEngine-List message posted by: "lwhitlow" <ldwhitlow(at)comcast.net>
Ok I'm Stumped
Larry Whitlow
601XL Jabiru 3300
http://forums.matronics.com/viewtopic.php?p=227956#227956
Great Deals on Dell Laptops. Starting at $499.
jeffrey_davidson(at)earth Guest
Posted: Sun Feb 01, 2009 6:40 am Post subject: EGT Probe Installation |
Larry,
The exhaust pipe has changed over the years, but on mine with three
separate pipes all the way from the exhaust port to the muffler on each side
(3300), there was enough straight pipe from the flange at the exhaust port
to measure down 100 mm and drill a hole for the EGT probe. I don't have a
picture handy, but I'll try to remember to take one today.
Jeff Davidson
<snip>
<snip>
dhonabach
Posted: Sun Feb 01, 2009 7:37 am Post subject: EGT Probe Installation |
I measured mine using a fabric tape and split the difference around the
curves.
While I'm not sure if the location really makes a big difference
although I think way too close would be bad ?, just make sure you drill
the hole for it in a place that allows the probe to stick straight in
and not be forced to bend to a side. Apparently from other comments, if
the EGT probe doesn't go straight into the exhaust pipe, the valves
being read/sent will be wrong.
Don
dredmoody(at)cox.net Guest
Posted: Sun Feb 01, 2009 8:18 am Post subject: EGT Probe Installation |
Stick the measuring tape up alongside the pipe all the way up to the flange then measure along the center of the side of the pipe around the curve to the 100mm point. Don't measure the outside radius of the bend or the inside... go halfway between the two and measure along that line. The measurement is not critical but getting all the sensors nearly the same is important. Does that help?
Ed
lwhitlow
tjs22t(at)verizon.net Guest
Posted: Sun Feb 01, 2009 12:20 pm Post subject: EGT Probe Installation |
Larry,
How about taking a piece of single strand heavy wiring (maybe 10AWG) and
cutting a pie 100mm long. Then place it on a side of the pipe midway
between the inside and outside bend (does that make sense? Someone else
said about the same thing.) Voila!!! exactly 100mm from wherever you
measured. Worked here. Coat hanger wire would work too.
CAVU jeff HDS/3300 Mechanicsburg, PA
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon Feb 02, 2009 8:53 am Post subject: Re: EGT Probe Installation |
The installation manual I have, dated 2006, says 100mm is the distance to use for the EGT probe palcement. The Jabiru engine tuning Service Bulletin JSB018-1, dated October, 2007, says to use 120mm. I don't have my Oshkosh notes with me, but I remember Pete K. saying in the Jabiru forum there that 120mm was the new recommended location. I used 120mm on my installation.
Good luck,
293.21 KB |
955 Time(s) |
_________________ David Gallagher
Cincinnati, OH area |
Thruster87
Posted: Tue Apr 28, 2009 12:29 am Post subject: Re: EGT Probe Installation |
On my 2004 solid lifter engine I can only manage 50mm or 2" as it is the older style exhaust system which has the 180 deg bend Cheers
