partner14
Posted: Fri Jan 30, 2009 8:15 pm Post subject: Van's tach |
I have dual lightspeed ignition, and now understand that it will not communicate with the Van's tach. So I ordered the tranducer. But upon receipt I then realized that with the backup SD20 Alternator mounted on the rear of the engine, there's no room to get the transducer to fit.
Has ANYONE found a solution to this? Is there another way to provide the Van's tach with the required input.
Thanks guys, Don McDonald
40636 |
seipel(at)seznam.cz Guest
Posted: Sat Jan 31, 2009 6:11 am Post subject: Van's tach |
You need the 12" extension. I believe you can get just the extension
and add it to the transducer. Part number is IE VTACH EXT12
PJ Seipel
RV-10 #40032
partner14 wrote:
Don A. McDonald
40636
http://forums.matronics.com/viewtopic.php?p 27818#227818
