p-a.austin(at)xnet.co.nz Guest
Posted: Wed Jan 28, 2009 9:00 pm Post subject: Mono Wheel Tyre |
Team,
Prior to first flight I replaced the original tyre supplied by Europa with a
Tru-trac 8.00 x 6 x 6 ply after several cycles it started to rub against the
root end of the L/gear forks progressively getting worse, I made up two
spacers ending up with 3mm thick on the right side and 2mm on the left and
all was well. Having now done just over 100 cycles it is starting to rub
again on both sides, I'm loath to add more spacers for fear of getting to
close or starting to conflict with the Rudder cables passing through the
wheel well. As I see it I have two options, replace the Tyre with a narrower
one (would that be a 7.00 x 6 x 6 ?) or remove the swing arm (with all the
work that entails) and get an engineering shop to reform it, which would
allow the removal of the existing spacers and retain the existing tyre. I
would appreciate the forums thoughts on the pro's and cons as regards the
narrower tyre etc. I use grass strips, tyre at approx 20psi.
Peter Austin
Classic ZK-ZEB.
acrojim7534(at)YAHOO.COM Guest
Posted: Thu Jan 29, 2009 4:49 am Post subject: Mono Wheel Tyre |
Change the tire to a 700x6. It will solve the tire rubbing the landing gear frame. I have used the 700x6 size past seven years w/o any problems.
Jim Brown
--- On Thu, 1/29/09, p-a.austin <p-a.austin(at)xnet.co.nz> wrote:
Quote: | From: p-a.austin <p-a.austin(at)xnet.co.nz>
Subject: Mono Wheel Tyre
Date: Thursday, January 29, 2009, 4:39 AM
Team,
root end of the L/gear forks progressively getting worse, I made up two spacers
ending up with 3mm thick on the right side and 2mm on the left and all was well.
Having now done just over 100 cycles it is starting to rub again on both sides,
I'm loath to add more spacers for fear of getting to close or starting to
conflict with the Rudder cables passing through the wheel well. As I see it I
have two options, replace the Tyre with a narrower one (would that be a 7.00 x 6
x 6 ?) or remove the swing arm (with all the work that entails) and get an
engineering shop to reform it, which would allow the removal of the existing
spacers and retain the existing tyre. I would appreciate the forums thoughts on
the pro's and cons as regards the narrower tyre etc. I use grass strips,
Peter Austin
Classic ZK-ZEB.
jpg12305
Posted: Mon Feb 02, 2009 12:25 pm Post subject: Re: Mono Wheel Tyre |
I used to have a similar issue with the 8.00x6. I switched to 7.00x6 and it works fine. I do not notice significant change in ground operations.
Jean-Paul
Europa 332
