Door strut
wayne.e(at)grandecom.net
PostPosted: Wed Jan 28, 2009 7:53 am    Post subject: Door strut Reply with quote
I have been having troubles, over time, with the door struts supplied by Van's becoming loose and allowing the door to fall and possible hit me or a passenger in the head, if we're not careful. I've talked to several people about this and they're having the same problem.
A friend of mine who's on the same field as me, Ron Grover who also has a 10, ordered some stronger struts and that seems to have solved his problem. I just ordered a pair for me this morning and thought I would pass along the source for these in case any of you are having the same problem. Both Ron and I have full interiors with the doors being finished with arm rests, so that makes them a little heavier than others I'm sure.
I ordered the struts from JWF Technologies, <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />6820 Fairfield Business Drive, Fairfield, OH 45014. Phone 513-769-9611. [url=]www.JWFtechnologies.com[/url].<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The struts are Stabilus, Lift-O-Mat part number 2218LP and cost was $78 each. They didn’t have them in stock, they come from Germany, and they said it would take 4 to 6 weeks to get them in.
On another note, I had to fly from North Texas up to northern Iowa this past weekend for a funeral, burr cold, and ran into a problem that I thought I would pass along. On my way up I kept noticing that my slip ball was constantly out to the left so I had to keep applying left rudder. I usually don't have an issue with rudder so I was attributing some of it to strong cross winds. Sounded good.
Anyway in leaving Iowa on Saturday, trying to get out ahead of a snow storm coming in, I pulled the plane out of the heated hangar space I rented into a minus 30 degrees wind-chill weather. Man after being in Texas for awhile I think I've turned into a Texas weenie, man that was cold. One positive of the cold was thick air and the plane was really liking to climb. I noticed again that I needed left rudder to keep the ball centered. We ended up with head winds and had to fly the last 100 miles in the dark.
About 60 out from my home base I started to hear and feeling a fairly noticeable fluttering noise/feel. As you can imagine my wife, who isn't real thrilled with flying in the dark to begin with, thought the engine was coming off, well maybe not quit but close. I was obviously concerned because any time something flutters I think of control surfaces, but everything felt fine there and the engine parameters were all fine.
So I just continued on home without making any quick movements and landed. The next morning I headed out to try and determine what was causing that problem. To make the story shorter I completely checked all surfaces and engine area and then, after talking to an A&P friend of mine, lifted up the plane and checked the tightness of the front wheel. I found that the wheel was fairly loose and could be pushed from side to side without much effort. Apparently over time the tension had loosened. The nut for the fork was in place but apparently over time in had just gotten more play. I tightened up the nut, took it out for a test flight and the vibration was gone and the ball was centered without help from the rudder.
I have to assume that when I took off, the wheel pant cantered to one side thus caused the need for additional rudder and for some reason when I started to feel the flutter it had gone way to one side with the wind hitting it sideways causing the fluttering noise.
Just thought I would pass this along in case any of you experience this same thing. I actually checked this wheel in June during my conditional before flying to Alaska and it was ok then. Maybe all those landings up there in the north country loosened it up.
Wayne Edgerton N602WT
ricksked(at)embarqmail.co
PostPosted: Wed Jan 28, 2009 9:20 am    Post subject: Door strut Reply with quote
Wayne,
What's with you and them nosewheels Smile does anyone recommend increasing the side pull tension initial set to more than 25 pounds? I plan to check it on a regular basis until the washers finally seat to each other. At what point can you stop checking the tension frequently?
Rick S.
Tim Olson
PostPosted: Wed Jan 28, 2009 9:50 am    Post subject: Door strut Reply with quote
Glad it worked out for you Wayne. I will tell you that the
nosewheel tension will probably be something that you'll have
to do about 3-4 times within the first 250 hours, and then
after that it will start to become more stable. I'm sure
it's just those parts wearing in together a little.
I'd check it maybe at 50, 100, 175, 250 or so, and then
annually after that. I too have noticed that the nosewheel
can affect rudder trim. It moves some when you use the rudder
hard. If you kick one pedal good and then look at the
ball, and then kick the other pedal good and then look at
the ball, you will see it sometimes keeps the ball one way or
the other slightly. I try to tap them back and forth a couple
times lighter and get it to be as centered as possible, and
then trim out the rest with rudder trim. I attribute the
stickyness to the 20+ lbs of breakout force required to
get the nosewheel to move to make it swing. The
propwash circle of moving air pushing against the tail
of the nose fairing may also be part of why most builders
see a little bit of out-of-trim rudder even if they build
it straight. A minor annoyance, in any case.
I'm sure.
I ordered the struts from JWF Technologies, 6820 Fairfield Business
Drive, Fairfield, OH 45014. Phone 513-769-9611. www.JWFtechnologies.com.
miles in the dark.
the rudder.
Neal.George(at)hurlburt.a
PostPosted: Wed Jan 28, 2009 10:48 am    Post subject: Door strut Reply with quote
The day after you sell it...?
neal
<< At what point can you stop checking the tension frequently?
Rick S. >>
rnewman(at)tcwtech.com
PostPosted: Wed Jan 28, 2009 10:49 am    Post subject: Door strut Reply with quote
Wayne, Do you know how many lbs of force these new struts have vs. how many lbs the struts have that came from vans? I was working on my doors/canopy recently and decided to measure the strut force on my van's supplied parts. I measured 120 lbs force required to compress the strut and thought that was an amazing amount of force even given the tight geometry of door/strut mounting brackets. thoughts??
Bob Newman
Tim Olson
PostPosted: Wed Jan 28, 2009 11:30 am    Post subject: Door strut Reply with quote
Rick, to answer your question about > 25lbs, that's what I did the
2nd or 3rd time I did mine. With that castlenut, I could choose
between maybe 18-20lbs, or maybe 30-35lbs, so with the past
experience, I chose the higher. Now when I did the Matco axle,
I just did a guesstimate by hand and I'd say I was now in the
20's somewhere. So I'd err on the high side within reason,
if you have to choose.
Rick Sked wrote:
[quote] Wayne,
Rick S.
PostPosted: Wed Jan 28, 2009 12:36 pm    Post subject: Door strut Reply with quote
I'm swapping my nose wheel out with Grove unit so I thought I'd ask before lowering the nose down.
Sent via BlackBerry by AT&T
AV8ORJWC
PostPosted: Wed Jan 28, 2009 12:55 pm    Post subject: Door strut Reply with quote
Attached is a beautiful shot of a Canadian, Three blade with the nose
wheel cant "In Cruise". This is one of over 100 fully painted RV-10s
from my database update. I always wondered how many were skewed in
flight due to low breakout force and the nosewheel weather veining at
cruise.
Maybe Mr. Corrigan could fill us in.
Tim, I missed the Break Out force numbers on the Nosewheel called out in
your Conditional Inspection - Landing Gear Section. Must be ole age on
my part cause you are soooo thorough. We have added it to RV6s which
required the mod for such things.
John Cox Flying N26XE in my dreams
 Filesize:  424.34 KB
 Viewed:  378 Time(s)
PostPosted: Thu Jan 29, 2009 4:48 am    Post subject: Door strut Reply with quote
Hi Tim,
I'm at almost 240 hours now so hopefully it will stay tight a little longer.
Wayne edgerton N602WT
Time: 09:50:18 AM PST US From: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)> Subject: Re: Door strut
PostPosted: Thu Jan 29, 2009 5:03 am    Post subject: Door strut Reply with quote
Bob,
Ron told me the number but I forgot what it was. I do remember it was about 25% stronger than the Van's strut.
dmaib@me.com
PostPosted: Thu Jan 29, 2009 4:32 pm    Post subject: Door strut Reply with quote
I checked mine at the end of the 40 hour phase one and it was very
loose. I will check again in another 25 hours or so.
David Maib
40559 flying
> same problem.
> head winds and had to fly the last 100 miles in the dark. About 60
> rudder.
> those landings up there in the north country loosened it up. Wayne
> Edgerton N602WT
David Maib
RV-10 #40559
New Smyrna Beach, FL
