msausen
Posted: Fri Jan 30, 2009 2:58 pm Post subject: Van's Whelen/ELT bracket |
Whoever may have used this, where does it go and do you have the instructions that you can share. I don’t think they are up on Tim’s site.
Michael
Jim Berry
Posted: Fri Jan 30, 2009 4:57 pm Post subject: Re: Van's Whelen/ELT bracket |
Michael,
Mine is mounted 8" behind the baggage bulkhead on the left. Rivets to the upper and middle J channel with 8 pull rivets. I don't have the instruction sheet anymore, but it is stone simple. It will not fit on the right, but it would be easy to make a mirror image if you wanted one for elt and one for strobe pack.
Jim Berry
40482
Finishing the finishing
tsts4
Posted: Fri Jan 30, 2009 4:58 pm Post subject: Re: Van's Whelen/ELT bracket |
I have the instructions but no way to post them electronically. I can either type them out here (there's 5 steps) or if you post or PM me a fax number I can send them that way.
It gets installed between the F-1047C-L and F-1047D-L J-stiffeners, and between the F-1006 and f-1007 Frames, but closer to the F-1006. You slide it fore and aft to get a good fit. The outside face of the bracket's top flange goes against the bottom side of the 1047C stiffener, while the inside face of the bracket's bottom flange goes against the bottom side of the 1047D stiffener. The instructions have a drawing that makes this arrangement perfectly clear.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
rene(at)felker.com Guest
Posted: Fri Jan 30, 2009 5:20 pm Post subject: Van's Whelen/ELT bracket |
I don’t have the instructions on me, but I placed mine on the left side of the fuselage, about a foot behind the baggage compartment bulk head.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Friday, January 30, 2009 3:43 PM
Subject: Van's Whelen/ELT bracket
Michael | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Fri Jan 30, 2009 8:18 pm Post subject: Van's Whelen/ELT bracket |
You can fax them to me and I'll post the pdf that I get from my fax
service.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 30, 2009, at 7:58 PM, tsts4 wrote:
Todd Stovall
728TT (reserved)
RV-10 Empacone
http://forums.matronics.com/viewtopic.php?p 27784#227784
westexflyboy
Posted: Fri Jan 30, 2009 9:49 pm Post subject: Re: Van's Whelen/ELT bracket |
| Jim Berry wrote: | | It will not fit on the right, but it would be easy to make a mirror image if you wanted one for elt and one for strobe pack |
Vans sells this same part in mirror image for the right. Search the onlike catalog for F-10112-R
_________________ Chase Snodgrass
Presidio, Texas
www.flybigbend.com
Simultaneous RV-10 twins under construction |
msausen
Posted: Sat Jan 31, 2009 8:00 am Post subject: Van's Whelen/ELT bracket |
Thanks guys, I figured it was mounted to the J Channel. That's basically what I needed as I'm looking for someplace to mount my Mountain High tank filler. Mine is the one with the gauge otherwise I would have mounted it through the rear bulkhead somewhere.
Michael
tsts4
Posted: Sat Jan 31, 2009 8:12 am Post subject: Re: Van's Whelen/ELT bracket |
I just faxed a copy to Jesse so he can post.
planesmith(at)hotmail.com Guest
Posted: Sat Jan 31, 2009 10:42 pm Post subject: Van's Whelen/ELT bracket |
Hi Michael C
Probably a little late C but I posted some pictures of the installed mounts on the blog: www.aviationstop.com
Vern Smith (#324 finishing)
[quote] From: rvbuilder(at)sausen.net
Date: Sat C 31 Jan 2009 09:38:46 -0600
Subject: RE: Re: Van's Whelen/ELT bracket
--> RV10-List message posted by: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Thanks guys C I figured it was mounted to the J Channel. That's basically what I needed as I'm looking for someplace to mount my Mountain High tank filler. Mine is the one with the gauge otherwise I would have mounted it through the rear bulkhead somewhere.
Michael
