rduplooy(at)iafrica.com Guest
Posted: Sun Jan 25, 2009 12:22 pm Post subject: Bob Nuckolls's Z-14 with dual Lightspeed iii and SD-8 |
Busy building an RV-8 with dual LS Plasma III (crank sensor) and would
appreciate some input on Z 14 changes required for my set-up.
Engine drives a B & C 60 Amp main Alt, and a SD-8 as back-up .
I wish to install 2 x 17aH batteries as per Bob's drawings and I would like
to know whether:-
1) the 2 shunts depicted on Z14 need to be changed to 50mv/60A and
.50mv/10A.?.
2) Klaus Savier recommends 2 x 5A "pull-able" C.B.s....Could I substitute
these for fuses of 5A each?
3) Could these be placed as per Z14 , #1 on the Main Batt bus and on Aux
Batt. the other?
4) Any other changes I should contemplate, as I would like the engine to
start only from the grip of my Infinity stick.
5) I am also installing a GRT HX & EIS 4000..any caveats/advice on any
additional systems/relays required on Z14 for these, or those below??
Many Thanks.
Robert
Bob Archer VOR antenna in wingtip.
AeroSUN Lites ( Leading edge lights)
Gretz heated Pitot
Sport AoA
Trutrak IIVSVG
Whelen Nav/Strobes
Christen Inverted Oil System( on Firewall)
Smoking Airplanes smoke-3.5.Gall( either fwd or rear baggage)
Sky Dynamics cold air and 4-into-1 exhaust
MT 3 blade C/W Acro Prop
Performanceengines O-360,balanced,flowed with 10:1.
On second thoughts, maybe I need 3 batteries?
longg(at)pjm.com Guest
Posted: Mon Jan 26, 2009 6:23 am Post subject: Bob Nuckolls's Z-14 with dual Lightspeed iii and SD-8 |
Rob,
I am installing the same dual plasma III in my Lancair. I am however
using Z-13/8 with one battery instead of two. I have yet to hear a good
argument as to why two batteries are better than two alternators. LS
does recommend a 4.5 amp battery behind a Schottky diode which I may
consider paralleling with the main at some time. The diode is about
$2.00 and the battery about $35. This is an easier/lower cost solution
than fussing with all the extras on Z14.
I also found the answer to the constant whining of pilots over fuse
blocks and cb's - use both You can tell Klaus's lawyers you had them
tied to cb's. If you use the below with the Bussman panel, you now have
the best of both worlds.
See...
https://www.alliedelec.com/Search/ProductDetail.aspx?SKU=6770385
Your shunt should be rated in conjunction with the alternator. No more,
no less. Use the ANL to drop amperage if desired and size the wire in
front and behind it accordingly. Think of the ANL as a step down
transformer, not the shunt.
You can install whatever battery/alt you choose. Z14 was designed as a
purely redundant system rather than an economical fly to safety system
like Z13/8.
I'm not sure if they sell handi-capped switch for folks that can't reach
the panel from their seat to start the engine, but there's no reason you
couldn't do a relay for the starter switch and even a remote starter if
you have FADEC. For me, I'd rather just lean over, push button - go. $20
and 15 minutes to install a starter button. If you're really lazy you
could wire one of those remotes to open the hanger door, turn on the
lights and start the coffee in the hangar before you get up the hill.
All from the stick.
You need to protect your avionics equipment per the manufacturer
recommendation. I think GRT's are about 3 amps. Remember, you are
protecting the wire in front of the device as well as the devices. If
you are pushing 20A through a wire rated for 3A on your GRT, you've got
something backwards. Remember, step it down before you deliver. Don't
introduce parts and complexity with relay's unless you really need them.
Half of the stuff in my panel is pulling less than 3 amps, even the
strobe lights.
Life is easy, keep it simple. You don't need 3 batteries to be safe. You
do need to give lots of TLC to the one or two batteries you do have and
change them regularly. Don't wait for problems to arise before deciding
you should beef up your system to overcome poor maintenance on your
part.
Most importantly, have fun. Yours sounds like a great system. Let's race
someday. I've got the Aerosport IO-375, Plasma III.
Glenn
