HBaker
Posted: Mon Jan 26, 2009 12:53 pm Post subject: Hoses |
I am starting to hook up the engine oil hoses, are you guys using 601 hoses and 816 fittings , does # 12 sound right?
Cheers Henry
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
_________________ Currently building a Murphy Moose - any help would be appreciated. |
lbpollock(at)sympatico.ca Guest
Posted: Mon Jan 26, 2009 6:02 pm Post subject: Hoses |
Hi Henry just finished my oil system for the M-14 with -12 hose fittings for
oil delivery to oil filter oil tank and cooler there is -4 fittings for the
oil clean kit .
Bill
Moose 244
HBaker
Posted: Tue Jan 27, 2009 3:07 pm Post subject: Re: Hoses |
Thanks Bill
So #12 is the right size of fittings, did you go with aluminum fittings, and did you go with fittings that you make yourself? And the #4 line , is it for the clean kit that uses the scavange pump, and is that all that it hooks up to?
Henry
Moose 294
Posted: Tue Jan 27, 2009 6:26 pm Post subject: Hoses |
Henry, I use three 90 aluminum fittings and the rest straight and yes its
better to custom make yourself with caution of not to kink the steel braided
hose in curves.I only used steel bulkhead fittings for fuel lines through
the firewall which my inspector wanted .The scavenging system goes from the
front nose of the engine to the scavening pump and the to the external oil
tank.Hope that helps.
Bill
Moose 244
