patreilly43(at)hotmail.co Guest
Posted: Sat Jan 24, 2009 8:08 pm Post subject: Exhaust Manifold |
Kitfoxers. Looking at a closeup of a Bluehead 582 engine installation Bill Chenoweths), I see the exhaust manifold is installed angled down with the EGT sensor mounts on the bottom. I swear when I received my used engine the manifold was mounted angled up with the EGT probe mounts up. I have reinstalled the engine and mounted the pipe and muffler. Fits fine with probe mounts up. And looking at it, I believe if I flipped the manifold over the pipe/muffler would be too low to bolt up. What gives? Were some engines installed with exhaust manifold up and others down? I sure hate to remove mine with all the springs saftey wired already, flip it over and find I am right and the pipe won't bolt up.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
msm_9949(at)yahoo.com Guest
Posted: Sun Jan 25, 2009 9:06 am Post subject: Exhaust Manifold |
My grayhead's exhaust is mounted same as yours, Pat. It all fits and it works like it's supposed to.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Sat, 1/10/09, Pat Reilly <patreilly43(at)hotmail.com> wrote:
| Quote: | From: Pat Reilly <patreilly43(at)hotmail.com>
Subject: Exhaust Manifold
Date: Saturday, January 10, 2009, 3:25 PM
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Posted: Sun Jan 25, 2009 9:57 am Post subject: Exhaust Manifold |
Marco C Thanks for info. How do you like that clutch?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Sun C 25 Jan 2009 09:04:57 -0800
Subject: Re: Exhaust Manifold
My grayhead's exhaust is mounted same as yours C Pat. It all fits and it works like it's supposed to.
Marco Menezes N99KX
Date: Saturday C January 10 C 2009 C 3:25 PM
Kitfoxers. Looking at a closeup of a Bluehead 582 engine installation Bill Chenoweths) C I see the exhaust manifold is installed angled down with the EGT sensor mounts on the bottom. I swear when I received my used engine the manifold was mounted angled up with the EGT probe mounts up. I have reinstalled the engine and mounted the pipe and muffler. Fits fine with probe mounts up. And looking at it C I believe if I flipped the manifold over the pipe/muffler would be too low to bolt up. What gives? Were some engines installed with exhaust manifold up and others down? I sure hate to remove mine with all the springs saftey wired already C flip it over and find I am right and the pipe won't bolt up.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
brubakermal(at)yahoo.com Guest
Posted: Sun Jan 25, 2009 10:08 am Post subject: Exhaust Manifold |
has anybody ever figured out how much power is lost or the effect it has on accurate egt readings by chopping the elbow and muffler?
--- On Sun, 1/25/09, Marco Menezes <msm_9949(at)yahoo.com> wrote:
[quote]From: Marco Menezes <msm_9949(at)yahoo.com>
Date: Sunday, January 25, 2009, 5:04 PM
Marco Menezes N99KX
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
propellerdesign(at)tele2. Guest
Posted: Sun Jan 25, 2009 11:15 am Post subject: Exhaust Manifold |
Yes ask Dick about that
Guy Buchanan
Posted: Sun Jan 25, 2009 2:07 pm Post subject: Exhaust Manifold |
At 09:59 AM 1/25/2009, you wrote:
| Quote: | has anybody ever figured out how much power is lost or the effect it
Malcolm,
I extended my muffler back to Rotax specs and saw no effect
whatsoever, EGT or otherwise. I couldn't fix the elbow because I
didn't have room. I'd love to make a custom exhaust, but just don't
have the tools to make nice expansions with curves.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Posted: Sun Jan 25, 2009 9:21 pm Post subject: Exhaust Manifold |
I like it fine Pat. Makes a big difference at idle, alot less shaking. The thought of an engine-out situation and resulting free-wheeling prop freaks me out a bit, but that topic has been beaten to death here.
Marco Menezes N99KX
--- On Sun, 1/25/09, patrick reilly <patreilly43(at)hotmail.com> wrote:
| Quote: | From: patrick reilly <patreilly43(at)hotmail.com>
Subject: RE: Exhaust Manifold
To: "kitfox matronics" <kitfox-list(at)matronics.com>
Date: Sunday, January 25, 2009, 12:55 PM
#yiv377796825 .hmmessage P { margin:0px;padding:0px;} #yiv377796825 { font-size:10pt;font-family:Verdana;} Marco, Thanks for info. How do you like that clutch?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Sun, 25 Jan 2009 09:04:57 -0800
Marco Menezes N99KX
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Float Flyr
Posted: Mon Jan 26, 2009 8:55 am Post subject: Exhaust Manifold |
I got to assume you are talking about a 582... Well it will kill your power. The elbow and the piece actually going to the muffler are what is called and expansion chamber. It causes a sonic barrier inside the chamber that sort of acts like an exhaust valve. This is why different pipes can cause the engine to produce more power but usually it will also cause the engine to get very peaky where maximum power and torque are in a very narrow power band. This si great for bikes but has no place in planes unless you are doing short take off contests all the time.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Malcolm Brubaker
Sent: Sunday, January 25, 2009 2:29 PM
Marco Menezes N99KX
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
01234567890123
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Mon Jan 26, 2009 10:25 am Post subject: Exhaust Manifold |
That wouldn’t be a calculation but a dynamometer test. If you really want more power just drop in a snowmobile exhaust... You will get more.... power and heat and less power band.
Apparently the original Rotax exhaust is slightly longer than the Kitfox one. The Kitfox expansion chamber had to fit inside the cowl. That will cause a modest reduction of power If you wanted to you could make a blister on your cowl and put the longer expansion chamber on and gain maybe 5 hp without making the engine too peaky.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of JC Propeller Design
Sent: Sunday, January 25, 2009 3:41 PM
----- Original Message -----
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Sunday, January 25, 2009 6:59 PM
Subject: Re: Kitfox-List: Exhaust Manifold
--- On Sun, 1/25/09, Marco Menezes <msm_9949(at)yahoo.com (msm_9949(at)yahoo.com)> wrote:
From: Marco Menezes <msm_9949(at)yahoo.com (msm_9949(at)yahoo.com)>
Marco Menezes N99KX
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
| Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref='3D"http://www.matronics.com/Navigator?Kitfox-List"'>http://www.matronics.com/Navigator?Kitfox-List3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref='3D"http://forums.matronics.com"'>http://forums.matronics.com3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 01234567890123456789 | Quote: | | 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 0
Kitfox III-A
