DanM
Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
Posted: Fri Jan 23, 2009 10:24 am Post subject: Aircaft weighing procedures |
I'm getting ready to do the weight and balance on my model iv. This maybe a dumb question but I thought I'd ask it anyway. Are three scales required to weigh the aircraft properly or can each wheel be weighed separately as long the aircraft is kept level? Please advise. thanks
391.19 KB |
413 Time(s) |
_________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
Guy Buchanan
Posted: Fri Jan 23, 2009 10:41 am Post subject: Aircaft weighing procedures |
At 10:24 AM 1/23/2009, you wrote:
| Quote: | Are three scales required to weigh the aircraft properly or can
Dan,
There's nothing wrong with doing this way, as long as you're
using a good, repeatable, scale.
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
kirkhull(at)kc.rr.com Guest
Posted: Fri Jan 23, 2009 12:13 pm Post subject: Aircaft weighing procedures |
You can do it that way but you might want check around and see is you can
find some aircraft scales. Many eaa chapter have them available and in some
cases for free.
If you are near Kansas city mo EAA Chapter 612 has a set.
Roosterville612.org
Float Flyr
Posted: Fri Jan 23, 2009 1:27 pm Post subject: Aircaft weighing procedures |
Each wheel can be weighed separately but the plane must be levelled each
time you move the scales. Lots easier to get three scales.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Fri Jan 23, 2009 4:07 pm Post subject: Re: Aircaft weighing procedures |
The first time I weighed I borrowed a bathroom scales from a couple neighbors. First I tried the move one scale to each wheel but that is more trouble than it seems until you try it.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
