Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
Posted: Fri Jan 23, 2009 4:44 am Post subject: Intake Manifold |
Would any one have the dimensions for a WW style intake Manifold for the Corvair on a 601XL.
I have a picture attached if you could just get the three dimensions.
Thank you
ianrat
Manifold Model (1).pdf |
6.01 KB |
602 Time(s) |
jaybannist(at)cs.com Guest
Posted: Fri Jan 23, 2009 6:52 am Post subject: Intake Manifold |
Ian,
Here is a drawing I made of the manifold as received from WW, before I installed it. I actually had to bend it slightly to decrease the distance (~0.5") between the upper sections to fit the pipes on the engine. Not a big deal. And, of course, the lengths of the upper horizontal sections are different. The side view shows the proximity to the motor mount.
This is not an engineering drawing, but a measured drawing, without lasers and such. I think it is accurate, but take it for what it is worth. I hope it helps. Let me know if you have questions.
Jay Bannister
INTAKE-PIPE.pdf |
14.96 KB |
644 Time(s) |
