craig.nelson(at)heraeus.c Guest
Posted: Mon Jan 19, 2009 4:02 pm Post subject: No mold free hand lay up |
<<DSC_1407.JPG>> <<DSC_1413.JPG>> <<DSC_1414.JPG>>
<<DSC_1429.JPG>> <<DSC_1432.JPG>>
You can see the jogle I made on the back sidde of the pant with epoxy
filler and used seperator. Layed it all up, then cut the pannel around
the leg and removed the parts and finished them. Never tried this but it
worked quite well
Uncle craig
This e-mail is intended for the exclusive use of the individual or entity named above and may constitute information that is privileged or confidential or otherwise protected from disclosure. Dissemination, distribution, forwarding or copying of this e-mail by anyone other than the intended recipient is prohibited. If you have received this e-mail in error, please notify the sender immediately by telephone or e-mail and completely delete or destroy any and all electronic or other copies of the original message.
*** 5, 4, 3, 2, 1 - ONLINE! Please click on over to www.heraeus.com to experience the new websites for yourself! ***
44.95 KB |
448 Time(s) |
40.4 KB |
443 Time(s) |
37.12 KB |
457 Time(s) |
43.87 KB |
429 Time(s) |
35.04 KB |
439 Time(s) |
Posted: Mon Jan 19, 2009 4:35 pm Post subject: No Mold Free Hand Lay up |
Craig- What kind of resin are you using- polyester or epoxy? I am using polyester, and it resembles maple syrup- not clear like your photos.
Bill Sullivan
Windsor Locks, Ct.
Posted: Mon Jan 26, 2009 7:07 am Post subject: No Mold Free Hand Lay up |
Epoxy/ Sorry I did not get back earlier I have been in a national sales meeting and did not have my computer
Craig Nelson AAS CDT
Technical Manager
Heraeus
300 Heraeus Way
South Bend, IN.
46614
Direct: 623-764-0680
Craig.Nelson(at)heraeus.com (Craig.Nelson(at)heraeus.com)
P Please consider the environment before printing this e-mail.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of william sullivan
Sent: Monday, January 19, 2009 5:35 PM
To: kolb list
Subject: Re: No Mold Free Hand Lay up
Bill Sullivan
Windsor Locks, Ct.
01234567890123
Posted: Mon Jan 26, 2009 9:43 am Post subject: No Mold Free Hand Lay up |
Craig- I never worked with epoxy resin, just polyester. I know you get a lot more working time with it, and it's supposed to be quite a bit more expensive. How does it grind or sand? How bad is the dust? Fumes? How about working out air bubbles?
Keep the photos and tips coming, you do great work. Your work looks more like art than mechanics or science.
Bill Sullivan
Windsor Locks, Ct.
25 degrees, clear and sunny
Posted: Mon Jan 26, 2009 10:39 am Post subject: No Mold Free Hand Lay up |
Thanks for the kind words…Composite is fun to work with and with a little preparation anything is possible. With epoxy you can get options with working time. The resin I used on the wheel pants goes to a B stage in about 10 min. there is a long working time epoxy that gives twice that time and this is also dependant on temp. the higher the temp the shorter the time. there are no fumes like polyester. My neighbors never know I am working with resin, even my wife can’t smell it and I’m in the garage. The wetting properties are similar to polyester, there is an additive that you can put in it and polyester that helps. It sands great and best of all it keeps its shape unlike polyester
Technical Manager
Heraeus
300 Heraeus Way
South Bend, IN.
46614
Sent: Monday, January 26, 2009 10:43 AM
To: kolb list
Bill Sullivan
Windsor Locks, Ct.
| Quote: | | http://www.matronics.com/Navigator?Kolb-List | 01234567890123
Posted: Mon Jan 26, 2009 11:44 am Post subject: No Mold Free Hand Lay up |
Craig- I'll have to try the epoxy on my next project. My wife can't stand the fumes, and gags or chokes up on them. This can lead to domestic trouble. The thicker you lay up polyester, the worse the fumes. They drove me out of the garage when I put the floor in the canoe.
Thanks again.
Bill Sullivan
Windsor Locks, Ct.
