aerobiz(at)optusnet.com.a Guest
Posted: Mon Jan 19, 2009 1:16 am Post subject: GT-50 G-meter |
Hi Peter,
I have fitted the GT-50 to both my aircraft ( one still under
construction) but I find it a very reasonably priced and accurate
instrument with a number of usefull functions. I wired it as per the
instructions, which means running the 'always on' wire direct to the
battery. Never had a problem with the Odyssey PC680 starting the RV-6,
but then again, I try and fly at least once a week. If you are worried
about battery drain, leave it disconnected till you need it or put a
switch in-line. Just means that the clock function will be only
accurate twice a day.....
Martin in Oz
