AOA CPU
daveleikam(at)wi.rr.com
PostPosted: Sun Jan 18, 2009 9:30 pm    Post subject: AOA CPU Reply with quote
For those who have installed an AFS AOA, where did you mount the CPU?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
wayne.e(at)grandecom.net
PostPosted: Mon Jan 19, 2009 4:22 am    Post subject: AOA CPU Reply with quote
Hi Dave,
I built a shelf and mounted it up under and to the rear of the instrument panel.
Wayne Edgerton N602WT
Time: 09:30:59 PM PST US From: "Dave Leikam" <daveleikam(at)wi.rr.com (daveleikam(at)wi.rr.com)> Subject: AOA CPU
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
rene(at)felker.com
PostPosted: Mon Jan 19, 2009 5:14 am    Post subject: AOA CPU Reply with quote
Subpanel, behind GRT displays……
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Sunday, January 18, 2009 10:29 PM
To: RV-10 matronics
Subject: AOA CPU
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
hotwheels
PostPosted: Tue Jan 20, 2009 8:21 am    Post subject: Re: AOA CPU Reply with quote
Subpanel photo attached... The AOA CPU is in the lower left hand corner. The AL angles used were 1"x1" (trimmed one side) as the AOA screw holes didn't line up to be able to use 3/4 x 3/4 angle without cutting yet another subpanel hole.
Jay
 Filesize:  609.46 KB
 Viewed:  416 Time(s)
