trigo(at)mail.telepac.pt Guest
Posted: Sat Jan 17, 2009 4:29 am Post subject: ELT location |
Although this is not a direct Electrical related issue, the RV List is not
so active and there are many RV builders and flyers around this one, so Bob
will forgive me for posting it here.
Van's sells a sub-kit intended for the installation of the AmeriKing ELT on
2-place side-by-side RV's (7 and 9), and its instructions place it in the
tail, right behind the baggage compartment aft bulkhead.
IMHO that is not the best place to install this ELT because its capability
of voice transmission in case one survives a crash is somehow defeated. You
would have to unscrew more than 20 screws to remove that bulkhead corrugated
cover to reach the ELT.
Where does the 7 and 9 gang have installed the ELT?
Inside the baggage compartment, at an easy reach of the pilot?
And how about the ELT's external antenna?
Carlos
Posted: Sat Jan 17, 2009 6:50 am Post subject: ELT location |
At 06:27 AM 1/17/2009, you wrote:
<trigo(at)mail.telepac.pt>
It's an entirely appropriate question . . . to which
I would offer the following . . .
The optimized location for ELT installation was
picked almost 50 years ago as the area of an airplane
most likely to survive a crash. Rearward in the tailcone
with the antenna just forward of structure in the
vertical fin.
Given that non-gps aided, beacon ELTs are of
substantive value in only a small percentage of
rescues, it seem that the "voice transmission" capability
is of dubious value. If one assumes worst case conditions,
what ever value the ELT has to offer will be protected
if the legacy installation protocols are observed.
After you've wadded your airplane up into a ball,
the existence of a non-gps aided ELT seems to serve little
purpose other than to comply with a rule. Anyone
on board the aircraft is capable of exploiting
the voice transmission feature would be better off
using the stuff that should be in everybody's flight
bag. This equipment is accessible to survivors without
to disassembly of of the airplane.
http://aeroelectric.com/Pictures/Misc/Vacination_for_Dark_Panel_Syndrom.pdf
It's interesting to note that the AmeriKing folks
earned themselves unfavorable noticed by the FCC
when on several occasions were asked to stop clear
field emissions to 406 Mhz rescue satellites.
http://www.fcc.gov/eb/Orders/2008/DA-08-402A1.html
We have no first hand knowledge of how this
all came about. It's curious that anyone
developing new hardware would not be 100.00% sure
of operational compliance in the screen-room before
venturing out to do COORDINATED, open air testing
of any kind. Tweaking the whiskers of the sleeping
tiger is a risky pastime.
( -Thomas Paine 1776- )
bcollinsmn
Joined: 17 Aug 2008 Posts: 23 Location: St. Paul, MN.
Posted: Sat Jan 17, 2009 7:14 am Post subject: Re: ELT location |
We also kicked this around on the RV List in november. I don't have an exact link but I referenced the discussion here:
http://rvbuildershotline.com/archives/2008/20081122.html
The original question I had, however, wasn't so much about the unit, it was about the antenna. Many RVers tuck it around the rollbar, which seemed to preclude a decent ground plane to me (if I understand ground plane correctly).
The general consensus seemed to be, don't worry about it, it's not going to work anyway, which seemed an odd position for people who are so meticulous about the possibility of corrosion rotting their metal airplanes in record time or any of the other million things with little chance of happening that we obsess over.
Here's what I ended up doing, by the way.
http://rvnewsletter.blogspot.com/2008/11/installing-heres-where-my-remains-are.html
I had intended to run the antenna up a bulkhead support as indicated in that latter link and that have the antenna up top just afte of another bulkhead. Since then, i've bought a Dynon D100 and it recommends the remote compass in that same location. So now I'm wondering if the antenna will interfere with the th Dynon magnetometer?
_________________ Bob Collins
St. Paul, Minn.
RV-7A - Running wires
Day job: http://minnesota.publicradio.org/collections/special/columns/news_cut/ |
rv9jim(at)juno.com Guest
Posted: Sat Jan 17, 2009 2:40 pm Post subject: ELT location |
Carlos,
I have a "9" with the slider canopy. I mounted my "required" ELT
on the frame just behind the pass. seat. I use a Ameri king (the redish
colored one) and using the fame as the main mount, I ran the antenna back
through it and mounted it to the top of the cover that encloses the
rudder cable in the baggage compartment. This lets me remove the whole
unit easily if I need to in the future. Some day there will be a
reasonable 406 mz unit and I will put it in the tail cone behind the
baggage compartment. There are lots of problems with antenna placement.
First, there is a very good chance I will flip over. This places the
antenna under the airframe. The rudder will protect the antenna to a
point. That may break it off. I placed the antenna inside as my pix
shows. Not the best but it will work. The very low power of the
transmitter leaves much to be desired but its there. I have a PLB that I
carry in my survival vest. If I can get out or at least put the PLB out
side of the airframe, it has a built in gps so they can find me fairly
quickly. I hope that gives you some ideas.
Jim Nelson
N15JN
RV9-A
Free information - Learn about Wheel Chair options. Click now!
http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw1lvVIEGFiAbDHEmzQDSCNQgCEqYbyo3hXmSwmEWNo3D5JLj/
57.43 KB |
706 Time(s) |
62.51 KB |
729 Time(s) |
bicyclop(at)pacbell.net Guest
Posted: Sat Jan 17, 2009 11:15 pm Post subject: ELT location |
Posted: Sun Jan 18, 2009 3:00 am Post subject: ELT location |
Thank you very much, James.
That's exactly the kind of answer I needed!!
In a further comment, I am also waiting for decent prices on 406MHz ELT's, but AmeriKing has recently released the AK-451, with and without GPS (It’s funny how they’re already in Aircraft Spruce catalogue but not in AmeriKing website?!).
Unfortunately, the international (INT) version (I need it for Europe) with GPS seems not yet available, therefore I’ll have to wait a little bit longer.
However, together with 121.5, 243 and 406 MHz frequencies and GPS position transmission, this unit seems to have voice transmission as well, so it looks that, beyond all other location recommendations (structural attachment, directional position, less potential destructive place, etc.), one should install it in an easy reachable position inside the cabin.
Carlos
[quote] --
Posted: Sun Jan 18, 2009 10:39 am Post subject: ELT location |
James,
I tried last night but my message came through empty.
The way your ELT is mounted, the 'G' switch is oriented to starboard
instead of down. I think it would take a pretty unusual crash to
activate it. Mounted that way, it is unlikely to pass inspection, too.
You might want to rethink it.
Van's recommends and supplies kits for mounting behind the baggage
bulkhead to some pretty solid structure. That meets the ELT
manufacturer's specs and the FAA's as well. I know a guy who mounted his
to the baggage floor and zip tied the remote switch right too it. His
passed the DAR's scrutiny, OK.
Pax,
Ed Holyoke
James H Nelson wrote:
| Quote: | Carlos,
Jim Nelson
N15JN
RV9-A
AV8ORJWC
Posted: Sun Jan 18, 2009 3:27 pm Post subject: ELT location |
There is an old Van builder's Tale of the instructions for installation of an "effective" ELT and rigging of the antennae with proper ground plane. If it annunciates at all, from a few feet away, then it must be compliant. We check the battery life, confirm it annunciates from a few feet and they fly for another year.
Most builders install the device to comply with a requirement in a written document that one must be onboard. Most ELTs do not emit a proper signal and few builders care to research why.
I dropped by ARTEX last week to query them on my understanding of RF transmission signals (in the 121 to 406 range) and they confirmed that most ELTs are installed for looks, not for their intended function of timely location. Maybe that is why the location of downed aircraft receive the response they do. It could be the non-activation of the switch, it could be that cute, hidden antenna.
Ground planes below the skin of the aircraft are one false tale, Installation of an antenna next to a rigid structure is another. Lets all agree we are doing the installation for compliance, not function and that aethetics plays a big role in not doing it correctly. I acknowledge that sliders affect the logic of sound antenna placement. My understanding is that the RF signals don't care one whit about any of that.
Now getting into Canada next month, now that is a meaningful question.
John Cox
From: owner-aeroelectric-list-server(at)matronics.com on behalf of bcollinsmn
Sent: Sat 1/17/2009 7:14 AM
Subject: Re: ELT location
--> AeroElectric-List message posted by: "bcollinsmn" <bob(at)rvbuildershotline.com>
The general consensus seemed to be, don't worry about it, it's not going to work anyway, which seemed an odd position for people who are so meticulous about the possibility of corrosion rotting their metal airplanes in record time or any of the other million things with little chance of happening that we obsess over. [Laughing]
Bob Collins
St. Paul, Minn.
RV-7A (#&^ fiberglass!)
http://forums.matronics.com/viewtopic.php?p=225286#225286
http://www.Same great content also available via the Web href="http://forums.matronics.com/">http://forums.matronics.com
p; - List Contribution bsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
Posted: Thu Jan 22, 2009 4:25 pm Post subject: ELT location |
Hi Ed,
Shoot, I'll have to look at it. My last bird mounted it the same
way (switches forward) but it was a different mfg. I assumed (bad me)
that the orientation would be the same. I don't have a lot of reason to
believe that this unit will be of any help. Its there for the DAR and
regulations. That is why I bought a PLB with GPS. If I'm alive, I will
remove it from my survival vest and turn it on. Even if I'm upside down,
I will break the canopy and stick my arm outside and run it. As a note,
I have a survival vest that I got from the U.S. Army during my 32 years
with them flying helicopters. It has a good survival knife, pocket for a
survival radio (my PLB) and lots of other neat stuff to keep you alive
for a while. A good fishing vest with pockets all over will do the same
thing. I should weigh it to see what it weighs as I think it is around 7#
=/- a pound or two.
Thanks again for the heads up.
Jim
Click for free info on college degrees.
http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw1U6R6KubryOwbqqIvdia8uuNezTxsmslPHQHES9IEeUMJwV/
Posted: Thu Jan 22, 2009 7:21 pm Post subject: ELT location |
Howdy Jim,
Yeah, the switches should be forward, but there is a side (the wide one)
which is supposed to face down. You're right, it probably won't save
your life no matter how you mount it, but you do have to get it signed
off. Good luck with it.
Pax,
Ed
Hi Ed,
=/- a pound or two.
Jim
Posted: Fri Jan 23, 2009 8:50 am Post subject: ELT location |
Cool!
Ed
