mikspin
Posted: Fri Jan 16, 2009 12:40 am Post subject: CFM rating of the AK-50 compressor? |
Just like it says folks; whoever knows it, please post it.
TIA
Mike Hastings
eddiemoranii(at)yahoo.com Guest
Posted: Fri Jan 16, 2009 6:25 am Post subject: CFM rating of the AK-50 compressor? |
Is this what you are looking for?
2.2.1. Specifications
First stage cylinder diameter 46 mm
Second stage cylinder diameter 40 mm
Piston stroke 20 mm
3 Operating pressure Up to 50 kgf/cm
Drive direction of rotation Arbitrary
Compressor speed of rotation:
Maximum at continuous operation during 1 min Up to 2655 r/min
Maximum at continuous operation during 10 min ............. Up to 2610 r/min
At "bottle charging:
Maximum ................................................ 2300 r/min
Minimum ................................................ 1450 r/min
Rate of compressor cylinder air cooling through area of 25x100 mm ................................ At least 20 m/s
Cylinder temperature:
Maximum .................................................. 110 °C
Recommended .............................................. 70 to 80 °C
Oil grade .................................................. MS-20 GOHT 21743-76
p Oil pressure ............................................... 2 to 5 kgf/cm2
Oil temperature ............................................ Up to 95 "C
Oil leakage at oil temperature of 40 to 80 °C and
I rotational speed of 1450 r/min Up to 30 cnr/h
Time of filling "bottle, 8 lit in capacity to operating
pressure (compressor delivery at eccentric speed, of
UbO r/min) ................................................ Up to 30 min
--- On Fri, 1/16/09, mikspin <acromike(at)gmail.com> wrote:
| Quote: | From: mikspin <acromike(at)gmail.com>
Subject: CFM rating of the AK-50 compressor?
To: m14pengines-list(at)matronics.com
Date: Friday, January 16, 2009, 3:40 AM
| Quote: | --> M14PEngines-List
message posted by: "mikspin"<acromike(at)gmail.com>Just like it says folks; whoever knows it, please post it.TIAMike HastingsRead this topic online here:http://forums.matronics.com/viewtopic.php?p=225046#225046======================== |
mikspin
Posted: Fri Jan 16, 2009 6:39 am Post subject: Re: CFM rating of the AK-50 compressor? |
CFM stands for cubic feet per minute, a measure of the rate of airflow.
US compressors, air tools, and other air related devices usually have a rating for this.
I could calculate it from the numbers posted (I've got 'em in the manuals as well), just didn't know if anyone had the CFM value(s) handy.
Thanks anyway,
Mike
Posted: Fri Jan 16, 2009 7:11 am Post subject: CFM rating of the AK-50 compressor? |
Ok, I thought you most likely had the manual....
Eddie
[quote]From: mikspin <acromike(at)gmail.com>
Subject: Re: CFM rating of the AK-50 compressor?
Date: Friday, January 16, 2009, 9:39 AM
[quote]--> M14PEngines-List message posted by: "mikspin"
for this.
manuals as well), just didn't know if anyone had the CFM value(s) [quote][b]
