gareywittich2000(at)yahoo Guest
Posted: Sat Jan 24, 2009 10:02 pm Post subject: Routing Elevator Trim Tab Servo Wires |
Greetings:
Looking for a better solution than routing the Trim Tab Servo wires thru the hole in the Elevator Spar (where the long Servo Motor Screw goes).
Does anybody have any pictures or diagrams of the Wire Routing of the Trim Tab Motor wires in the Elevator to the Horizontal STABILIZER to the fuselage.
Not much given on this subject on Matronics.
Thanks, Garey Santa Monica, CA
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27563 Location: Livermore CA USA
Posted: Sat Jan 24, 2009 11:10 pm Post subject: Routing Elevator Trim Tab Servo Wires |
At 10:01 PM 1/24/2009 Saturday, you wrote:
Greetings:
Hi Garey,
I just did this task. I simply drilled a 1/4" hole above the servo screw hole and added a little black plastic bushing. Attached is a picture.
Best regards,
RV-8 #82880 N998RV (res)
Building Time Since July 2008: 728.75 Hours
| Description: |
| Filesize: |
150.47 KB |
| Viewed: |
396 Time(s) |
_________________ Matt Dralle
