Bill Vincent
Posted: Sat Mar 25, 2006 6:35 pm Post subject: Stock Performance |
Hi John
I was wondering if you did this with no flaps and the stick all the way back
Bill Vincent
| Quote: | However, at 3000 feet, at idle power I can put her in a 40 to 50 mph
mush at 2000 fpm rate of decent with no tendancy to lose roll or pitch
control. Think it and it is flying again.
Take care,
_________________ Bill Vincent
Firestar II
Upper Peninsula of Michigan |
Posted: Sat Mar 25, 2006 6:47 pm Post subject: Stock Performance |
way back
| Bill Vincent
That is correct.
It is a characteristic of the Kolb design.
Depending on the situation, it is an excellent way to lose a lot of
altitude in a short period of time at minimum airspeed.
To recover from the mush, I release some back pressure on the stick
and it is flying.
Does not work nearly as well with full flaps.
MKIII
_________________ John Hauck
Titus, Alabama |
