pilot(at)ip6.com Guest
Posted: Wed Jan 14, 2009 6:10 pm Post subject: Bing Carbs |
It is time to rebuild my Bing carbs for my 912 UL.
Should I just order the kit and do it myself,
or should I send it to some shops, in this case what do you recomend?
Thank You
-- Silvano
hgmckay
Posted: Wed Jan 14, 2009 7:10 pm Post subject: Bing Carbs |
Silvano:
If your plane is an E-LSA and you are trained by Rotax, you can do the inspection and re-build yourself. If your plane is a S-LSA you cannot do the work yourself.
Hugh McKay
Allegro 2000
Rotax 912UL
--- On Wed, 1/14/09, Silvano Gai <pilot(at)ip6.com> wrote:
| Quote: | From: Silvano Gai <pilot(at)ip6.com>
Subject: Bing Carbs
Date: Wednesday, January 14, 2009, 9:09 PM
| Quote: | --> RotaxEngines-List message posted by: Silvano Gai <pilot(at)ip6.com>
Thank You
-- Silvano
| [quote][b]
daveaustin2(at)primus.ca Guest
Posted: Wed Jan 14, 2009 7:23 pm Post subject: Bing Carbs |
Silvano,
How many hours do you have on the bings?
Dave Austin 601HDS - 912
Posted: Wed Jan 14, 2009 10:24 pm Post subject: Bing Carbs |
140 hours
-- Silvano
Dave Austin wrote:
| Quote: | Silvano,
Posted: Thu Jan 15, 2009 5:42 am Post subject: Bing Carbs |
Silvano,
Reason I asked is that I run a 912UL and other than lubricating the throttle
and choke shafts and cleaning out the float chambers I've needed to do
nothing else. Engine runs smooth and sweet from idle to full power.
IMOO, when running well, leave "well" alone.
Posted: Thu Jan 15, 2009 6:51 am Post subject: Bing Carbs |
Silvano,
You should order a Bing Carburettors Aircraft Tuning and Parts Manual
from BING
at 800-309-2464 and do the rebuild yourself. The task is not daunting
and akin to changing
out a tire. I'd not hire a mechanic to do such a routine task. The
manual is all you need
unless you've never held a screwdriver before.
Larry McFarland
Silvano Gai wrote:
Thank You
-- Silvano
rparigor(at)suffolk.lib.n Guest
Posted: Thu Jan 15, 2009 9:16 am Post subject: Bing Carbs |
Hi Silvano,
"other than lubricating the throttle and choke shafts"
Does Rotax or Bing recommend lubricating the throttle and choke shafts of
Bing type 64 carbs?
What lubricant do you use?
Thx.
Ron Parigoris
Posted: Thu Jan 15, 2009 12:16 pm Post subject: Bing Carbs |
Engine oil. I've had "Bing" carbs ever since my Triumph TR3. No big deal.
Dick Maddux
Posted: Fri Jan 16, 2009 4:18 am Post subject: Bing Carbs |
Triumph Tr'3s have never had Bing carbs ( they are SU H6) I bet you knew that was coming.
Dick Maddux
Pensacola,Fl
Inauguration '09: Get [url= http://www.aol.com?ncid=emlcntaolcom00000027]complete coverage[/url] from the nation's capital.
391.36 KB |
869 Time(s) |
Posted: Fri Jan 16, 2009 6:56 am Post subject: Bing Carbs |
Right on,Dick! But they sure looked the same, and worked the same..
Float Flyr
Posted: Fri Jan 16, 2009 11:03 am Post subject: Bing Carbs |
I think your Healey 3000 got shrunk... Beautiful machine!
Are the wheels original?
Noel
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Friday, January 16, 2009 8:47 AM
Subject: Re: Bing Carbs
Dick Maddux
Pensacola,Fl
Inauguration '09: Get from the nation's capital.
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Fri Jan 16, 2009 11:16 am Post subject: Bing Carbs |
Side draft SUs were a little more complex than they look at first glimpse. Once set up I liked ‘em.
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Dave Austin
Sent: Friday, January 16, 2009 11:25 AM
| Quote: | | http://www.matronics.com/Navigator?RotaxEngines-List | 0123456789
Kitfox III-A
Posted: Fri Jan 16, 2009 12:42 pm Post subject: Bing Carbs |
If you think setting up two of them is hard, try setting three of them in sync in an E Type!
Float Flyr
Posted: Fri Jan 16, 2009 4:52 pm Post subject: Bing Carbs |
To do it right you have to have the carb balancer.... but you will be surprised how close you can come with an old stethoscope.
Noel
Sent: Friday, January 16, 2009 5:11 PM
Kitfox III-A
Roger Lee
Posted: Fri Jan 16, 2009 9:06 pm Post subject: Re: Bing Carbs |
Recommended rebuild is at 200 hrs. The kit is about $214. Parts wear whether you notice it or not. It is not hard, but you should talk to someone with experience first if you have never done it. There are a couple of things unique to the Bing. Doing it right the first time, not doing something wrong can save you a lot of heart ache and having to redo it again. They absolutely will need to have a mechanical and pneumatic balance when they are re-installed. The right way is cheaper, easier and takes less time in the long run. Trust me I have seen and rebuilt the "wrong way' ones enough.
The people who never do a rebuild don't do themselves any favors in the long run.
If you absolutely won't do it at 200 hrs. then at 300 or 400 hrs. The parts do wear!
If you just don't want to do it yourself then I'll do them for $50 plus the rebuild kit. One day turn around.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Dick Maddux
Posted: Sat Jan 17, 2009 4:56 am Post subject: Bing Carbs |
Thanks for your kind replies on my Tr3B.( I also have a "cherry " TR3A and a Stag) The wheels are Panasports and were offered as an option. And as you said the SU carbs are very close in function to the Bings. When I went through Rotax school at Lockwood we tore down the Bing carb and reassembled it. The Bing has more parts but its function is almost identical to the SU so it was easy to correlate.
Dick Maddux
[b]Inauguration '0ete coverage from the nation's capital.
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Sat Jan 17, 2009 1:08 pm Post subject: Re: Bing Carbs |
Roger,
Are the prices you quoted per carb or for the pair? Thanks,
Scott
| Roger Lee wrote: | Recommended rebuild is at 200 hrs. The kit is about $214.
If you just don't want to do it yourself then I'll do them for $50 plus the rebuild kit. One day turn around. |
Roger Lee
Posted: Sat Jan 17, 2009 9:14 pm Post subject: Re: Bing Carbs |
Hi Scott,
The price for the rebuild kit ($214) is for the pair and my price ($50) is for the pair.
Tucson, Az.
Cell 520-349-7056 |
