Need help & consuling on Rivet puller
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List
KM Heide
PostPosted: Mon Jan 12, 2009 9:40 am    Post subject: Need help & consuling on Rivet puller Reply with quote
Bob,
I have purchased the gun from Zenith and have never had any problems with it. Expensive?....yes but I wanted to make sure I had the right force when pulling rivets.
I have recently purchased a blue colored pneumatic inexpensive rivet gun from Harbor Freight tools that works as good if not better than the big yellow Zenith gun! I have purchased two of them which were recommend from another aircraft building site. I also made the heads similar to the rivet heads from Zenith and switch gun regularly between different size rivets. I have had no problems with these guns and they are a few years old already.
[/url][url=http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93458] 3/16" AIR HYDRAULIC RIVETER
Central Pneumatic
93458-1VGA
$29.99
KMHeide
Fargo, ND
--- On Mon, 1/12/09, stepinwolf <robert.pelland(at)cgocable.ca> wrote:
Subject: Need help & consuling on Rivet puller
To: zenith750-list(at)matronics.com
Date: Monday, January 12, 2009, 10:18 AM
--> Zenith750-List message posted by: "stepinwolf"
When I first started looking for a rivet puller, I shied away from the gun that
was being offered by Zenith because I had heard from builders on this List, that
there was many instances of cracking in the casings. As a replacement I decided
to go with a gun that was being offered by ACS ( see pic below ) however it is
starting to look like this was not my best decision.
I had difficulty with the setup instructions ( Chinese instructions ) and for
the life of me I still have not been able to get the oil level correct. The
instructions state that the unit should be filled with oil up to the top of the
frame, without showing where exactly what they consider as being the top or the
exact filling level is.
My second mistake was purchasing two guns so as not to have to continually swap
out the two tips. As it stands, when I do get one of the (at)#$%&* things to
work, it won't pull more then a dozen or so rivets, before me being obliged
to open up the air cylinder and start fidgeting with the oil level again.
I am basically a neat person, and I can't live with the constant spewing of
oil out the front, or the back stem catcher, and ending up on my freshly made
parts, or my work table for that matter. I am now in the process of trying to
look for a replacement, but all the suppliers seem to have the same low cost
gun. The list of resellers I checked with is rather extensive and includes, but
is not limited to, The Yard, ATS, Browns, Cleavland, US Tools, all registered
trademarks etc, and a few more I will not mention.
My question to the List is this, is the rivet gun being sold by all of these
suppliers the same gun. I have looked as best as I can, and every last one is
showing what looks to be the exact same unit on their web-page, with the only
difference being the color or the pricing. The cases are identical, the same
tips, the same nose pieces, hell they even the same triggering mechanism, and
the only difference so far is prices, that are anywhere between 40$, to a 140$.
For those of you who have used any of the above guns, are you aware of any
difference in quality of these guns, or is it a " find the peanut under the
shell " type of situation for me to get a proper replacement that will
work,
Thank's to all of you who will take the time to respond to my concerns.
Bob, the 701 & 750 Scratch
Three Rivers , Quebec.
7-7143 & 7-75???
Live each day, as if it was your last
http://forums.matronics.com/viewtopic.php?p 24232#224232
http://forums.matronics.com//files/rivet_gun_964.jpg
- The Matronics Zenith750-List Email Forum -
http://www.matronics.com/Navigator?Zenith750-List
jdsmit8(at)attglobal.net
PostPosted: Mon Jan 12, 2009 12:21 pm    Post subject: Need help & consuling on Rivet puller Reply with quote
I got whatever gun came with the Zenith tool kit. It requires no oil
and has been trouble free through about 3,000 rivets. Are you sure
they're all the same?
Jim Smith
Claremore, Oklahoma
the gun that was being offered by Zenith because I had heard from
builders on this List, that there was many instances of cracking in
the casings. As a replacement I decided to go with a gun that was
being offered by ACS ( see pic below ) however it is starting to
instructions ) and for the life of me I still have not been able to
get the oil level correct. The instructions state that the unit
should be filled with oil up to the top of the frame, without
continually swap out the two tips. As it stands, when I do get one
of the (at)#$%&* things to work, it won't pull more then a dozen or
so rivets, before me being obliged to open up the air cylinder and
spewing of oil out the front, or the back stem catcher, and ending
up on my freshly made parts, or my work table for that matter. I am
now in the process of trying to look for a replacement, but all the
suppliers seem to have the same low cost gun. The list of resellers
I checked with is rather extensive and includes, but is not limited
of these suppliers the same gun. I have looked as best as I can, and
every last one is showing what looks to be the exact same unit on
their web-page, with the only difference being the color or the
pricing. The cases are identical, the same tips, the same nose
pieces, hell they even the same triggering mechanism, and the only
of any difference in quality of these guns, or is it a " find the
peanut under the shell " type of situation for me to get a proper
replacement that will work,
concerns.
7-7143 & 7-75???
stepinwolf
PostPosted: Tue Jan 13, 2009 8:21 am    Post subject: Re: Need help & consuling on Rivet puller Reply with quote
A big thank you to all who responded to my call for help.
Yesterday evening I was able to find, and correct the problem with my rivet gun. As was mentioned in a previous response, the defect was with the large O-ring on the piston at the top of the handle. it has an O-ring at the rear to seal the oil, and both guns had O-rings that were dried out and hardened.
This is why the gun was quitting after a dozen or so rivets, because the oil was leaking pass the O-ring into the stem catcher. Now it is working great, with no oil leaks.
There was however one casualty in all this and that is my second gun. While I was rebuilding the first one on the bench I casually pulled the trigger to check how far back the piston was pulling, and when it evacuated the air from the lower canister, it blow the spring from my second gun off the bench, and was never to be seen again.
Bob the 701 & 750 scratch
Three Rivers, Quebec
 Filesize:  107.04 KB
 Viewed:  947 Time(s)
Long wing + vga's, = lo & slo
ifly4fun2(at)sbcglobal.ne
PostPosted: Thu Jan 15, 2009 6:16 pm    Post subject: Need help & consuling on Rivet puller Reply with quote
Bob,
I have the Zen riveter and it has pulled along without issue, thus far that is.
701 Rudder
750 Plans builder
Art
[quote]From: stepinwolf <robert.pelland(at)cgocable.ca>
[quote]--> Zenith750-List message posted by: "stepinwolf"
For those of you who have used [quote][b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List All times are GMT - 8 Hours
