westexflyboy
Posted: Sun Jan 11, 2009 7:37 pm Post subject: F-10110-R? |
Van's Wiring Harness comes with a fuselage part F-10110-L, which covers the wires in the left sidewall. I have quite a few wires running down the right sidewall, and wonder if there is an aftermarket F-10110-R that would allow for similar routing on the right side. I suppose I could make the part myself, but trying to avoid the hours. Anybody have any better ideas?
_________________ Chase Snodgrass
Presidio, Texas
www.flybigbend.com
Simultaneous RV-10 twins under construction |
ron.mcgann(at)baesystems. Guest
Posted: Sun Jan 11, 2009 7:48 pm Post subject: F-10110-R? |
Tried to order a RHS one from vans with no success. Made one using
mirror image of the left - took about an hour and works fine.
Ron
-187 fiddly bits and paperwork
MauleDriver(at)nc.rr.com Guest
Posted: Sun Jan 11, 2009 8:47 pm Post subject: F-10110-R? |
I had wanted to do the same. Instead I ran my right side wires
according to the Wiring Harness kit's procedure (at least that's what I
recall). My thick wires (2 batt/2 alt) are both run on the left under
F-10110-L along with a few other wire. I only have thin wires on the
right side and they are run up under the triangular piece common to both
sides. It's working well so far.
BTW, I didn't buy the Van's kit but did use the manual to order the key
parts. The Wiring Harness manual is very useful even if one is doing a
very custom wiring job.
Bill
westexflyboy wrote:
Chase Snodgrass, CFI
Presidio, Texas
www.flybigbend.com
40820/40821
http://forums.matronics.com/viewtopic.php?p 24150#224150
Gwayne
Posted: Mon Jan 12, 2009 3:05 pm Post subject: Re: F-10110-R? (wiring manual) |
| Quote: | BTW, I didn't buy the Van's kit but did use the manual to order the key
very custom wiring job. |
Where can I get a copy of the "Van's Wiring Manual" ?
[/quote][/quote]
_________________ Wayne
RV 7 "eh?" 120 hrs
RV 10 fuse |
