Flight Simulator
Goto page 1, 2  Next
matronics(at)bob.brennan.
PostPosted: Wed Jan 07, 2009 9:33 am    Post subject: Flight Simulator Reply with quote
I hope this isn't too off topic for a Kitfox forum but does anyone use MS Flight Simulator X? I had hoped to get some simulator time in while the weather is so gruesome but it is unusable on my PC. I bought FSX, then the Saitek Aviator joystick to hopefully make it work better, then more Ram, then a new video card, and most recently the Acceleration Expansion Pack. But nothing gets it going faster than about 2-3 frames per second, even at minimal settings, which is unusable.
MS lists minimum requirements as Good, Better, Best - my PC falls into the Best category with a 3g P4, 1.5g Ram, and new 512m GeForce video card.
MS support have been very helpful so far and my problem has been "elevated" to the highest level as I await yet another phone call from them. My question is simply - is anyone using FSX successfully?
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
akflyer
PostPosted: Wed Jan 07, 2009 10:08 am    Post subject: Re: Flight Simulator Reply with quote
I dont have any problems with it on my laptop, but I bought it knowing I would be gaming with it so I built it for that purpose. I can run all settings on max without a hick up
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
PostPosted: Wed Jan 07, 2009 11:06 am    Post subject: Flight Simulator Reply with quote
Thanks for the reply Leonard, but how does your laptop compare to my PC
spec-wise?
Mine: 3ghz Pentium4, 1.5g Ram, great big disk, and new 512m GeForce 8400GS
video card
Running at default settings I get 2 to 3 frames per second (hit shift-z
twice to display real time fps), at absolute minimums the max I get is 6 to
7 fps, at high settings it goes into seconds per frame and control inputs
can take many seconds if not completely ignored. What frame rates can you
get?
Thanks for taking the time to compare, I'm needing as much info as possible
for when(if) MS support ever calls back.
bob
815TL
PostPosted: Wed Jan 07, 2009 11:09 am    Post subject: Re: Flight Simulator Reply with quote
Bob,
Take The MS flight sim back and in invest in x-plane. It is a much, much better simulator in my opinion. I have used both, and x-plane looks better, higher frame rate, and feels more 'real'. Plus I have a nice model of a Kitfox II that I repainted, and re did the cockpit on, to look like my plane. The orginal was created by Michel Verheughe, who is a member here. I modified it for my use.
The only down side to x-plane is it can be hard to set up and configure properly, but I can help you out with that. Also invest in a set of rudder pedals, they are worth it.
More on x-plane here: www.x-plane.com
And here: www.x-plane.org
Andrew
815TL, Kitfox II, Rotax 582-C
[/quote]
 Filesize:  104.29 KB
 Viewed:  684 Time(s)
PostPosted: Wed Jan 07, 2009 11:36 am    Post subject: Flight Simulator Reply with quote
I might give X-plane a try as well as FSX Andrew thanks, but for the moment
I really need to determine if it is FSX that is the problem or my PC, or
some magical setting I don't know about yet. If my PC is at fault it most
likely won't run X-plane well either.
bob
815TL
PostPosted: Wed Jan 07, 2009 12:56 pm    Post subject: Re: Flight Simulator Reply with quote
bob
I have a fairly impressive computer, but was never able to run FSX at a decent frame rate either. What video card do you have, Nvidia or ATI based, and what chipset? I believe that FSX runs in DirectX, and X-plane runs in OpenGL or something equivelent. When I was running an ATI card, I had good preformance in Direct X, but realy poor in OpenGL. I switched to a Nvidia based card and the OpenGL preformance went way up, but I did notice that some DirectX games slowed down, maybe 5-10%. It was worth it to get the much better OGL preformance though.
Let me fire up FSX tonight and play with some settings and see if we can't get you figured out. One thing to turn down, is water textures, and shadow complexity. They are frame rate killers.
Andrew
akflyer
PostPosted: Wed Jan 07, 2009 12:57 pm    Post subject: Re: Flight Simulator Reply with quote
spec-wise?
video card
get?
bob
Sager NP9262
17" Wide Viewing Angles WSXGA+ LCD with super glossy surface (1920X1200)
Intel core 2 quad processor Q9450 / 12 mb L2 Cache, 2.66 Ghz, 1333 Mhz FSB
Nvidia GeForce 9800M GT / 512 MB DDR3 Vid Memory
Vista home Premium
4 GB Dual Channel DDR2 SD RAM (at) 800 Mhz (2X 2048 MB)
200 & 320 GB 7200 RPM SATA 300 HD
8X DVD +_ R/RW/ 4X +DL Super Multi Drive
Intel Pro Wireless 4965AGN 802.11A/B/G/N Wireless LAN Module
Internal BlueTooth Module
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
steve.didier(at)gmail.com
PostPosted: Wed Jan 07, 2009 1:33 pm    Post subject: Flight Simulator Reply with quote
I use FSX along with Xplane 9 on my iMac FSX under Bootcamp in XP with no hiccups full frame rates and all of the eye candy turned on. I can't, however, run it in a virual machine in eithr VmWare or Parallels at an acceptable setting.Steve Didier
C172
Idaho
Wrightsville Pa
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List
PostPosted: Wed Jan 07, 2009 1:38 pm    Post subject: Flight Simulator Reply with quote
Video card is brand new Nvidea GeForce 8400 GS on an ATI bus which is all my
motherboard has on it other than AGP. DirectX is the latest downloaded from
M$ yesterday. FSX has service packs 1 & 2 installed from the Acceleration
disk. I tried turning off every option in the Custom Settings dialog, off if
I can and absolute minimum otherwise, lowest resolution on the list. Target
frame rate is 17, the best it will actually do in a very blurry dull jerky
world is 7.
Still waiting for the call from the M$ expert who promised to call at noon
(is now 4:30 EST here). I'm glad real airplanes aren't this much trouble!
bob
Michel
PostPosted: Wed Jan 07, 2009 1:58 pm    Post subject: Flight Simulator Reply with quote
Well, X-Plane feels more real, that's for sure. But MS FS is "nicer" in the way that it has many fine eye-candy features and a very large existing database of airfields and sceneries.
The difference in the simulators models is that MS FS use what can be called "look-up tables." When you build an aircraft, you enter the stall speed, Vne, etc. and for speeds in-between, the values are interpolated.
X-Plane, on the other hand, uses what is called "blade theory." It takes any part of the aircraft into an airfoil with own lift, drag and moment. Then it goes through each computation for each frame refresh.
When you build an aircraft in X-Plane, you have to enter what you think is the closest model then you go and fly. If the aircraft then stalls at the speed intended then you are very lucky! You can then work with the actual airfoil, the wash-out, the CoG, learn about aviation and see how the model changes.
I often work with X-Plane, PlaneMaker and AirfoilMaker programs open at the same time. Tiny adjustments, testing, back to the drawing board ... you get the picture!
With MS FS, if you enter a value for stall speed, the aircraft will always stall exactly at that speed!
X-Plane is in fact a digital wind tunnel. Even small change in the step of the fuselage of a seaplane makes great difference. It is truly a wind (and water) modeller.
However, two warnings about simulators.
- None of them can simulate properly a spin. That is because data about airfoil is known for "normal" angles; not when the apparent wind meets the wing and perhaps an angle of 80 degrees and certainly not when e.g. because of the spinning motion, one of the horizontal stabs is in the "shade" of the tail. The only way to simulate that is with Computerized Fluid Dynamics (CFD) and that just can't be done in real time.
- You can set the angle of view of the screen as you want. But if you do a bit of geometry, in order to match the actual angle the screen makes and your perspective view of everything around you, the angle should be put to perhaps 25 or 30 degrees and that's too little to be able to see the panel.
Imagine you are in your Kitfox and you hold at arm's length a piece of cardboard that represents the frame of your screen when you are at home. You will see only a tiny part of the panel and landing with only that angle of view would be suicide.
Otherwise, it's fun, harmless and you are all welcomed to use my or Andrew's model.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
PostPosted: Wed Jan 07, 2009 2:10 pm    Post subject: Flight Simulator Reply with quote
Thanks Michel, that is a glowing endorsement for X-plane. Now can you fold
the wings on your Kitfox model and trailer it backwards at different angles?
(just kidding!)
My reason for wanting FSX is to review my former days of talking to ATC,
exploring local airports (the scenery in FSX is amazingly accurate),
simulating cross-country flights, and maybe learn a bit of IFR on the cheap.
It certainly seems capable of all that and more, if I could get the darn
thing to do more than a frame a second. Heck, I might even visit your
country.
bob
MichaelGibbs(at)cox.net
PostPosted: Wed Jan 07, 2009 2:28 pm    Post subject: Flight Simulator Reply with quote
One way to figure out if the problem is with FSX would be to try X-
Plane. You can download it for free from their website: <http://www.x-plane.com
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
On Jan 7, 2009, at 12:35 PM, "Bob Brennan"
moment
PC, or
most
bob
Float Flyr
PostPosted: Wed Jan 07, 2009 2:43 pm    Post subject: Flight Simulator Reply with quote
I have a similar system... A P4, 3.2 gHz W/ i gig of RAM and a GeForce 6200 card. 256 VRAM the computer is a second hand return from lease. $250 tx incl. The monitor is considerably more. The FS-X runs great on this. I like the FS 9 better only because my Kitfox flys great on it. I fiddled with the program so tha plane gives closer to what I get in the real plane... Then I did a repaint and a new panel. Now if I could only figure out how to add floats. BTW there are more and better ponds in FS 9.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Bob Brennan
Sent: Wednesday, January 07, 2009 2:03 PM
Subject: Flight Simulator
Wrightsville Pa
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Wed Jan 07, 2009 2:48 pm    Post subject: Flight Simulator Reply with quote
My best guess is there is a problem with the way your video card
communicates with your confuser. Make sure you have consistant RAM cards.
You may also have to enable the graphics card in control.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Wed Jan 07, 2009 3:02 pm    Post subject: Flight Simulator Reply with quote
Make sure you have consistant RAM cards.?
I formerly had just an onboard Intel chipset for video, now my monitor is
plugged into the Nvidea card so the video must be coming from there.
Checking My Computer > Manage > Device Manager > Display Adapters shows the
Intel chipset disabled and the Nvidea enabled. FSX only shows the Nvidea in
the Graphics dialog. Funny thing though - none of my programs show the
slightest difference, including all performance problems in FSX, when I
upgraded to the Nvidea. That can't be right... I expected more for my 120
bucks.
bob
Float Flyr
I forgot to say my platform is XP SP-3 for the Flight Sim.... More and more
I'm switching to Dreamlinux distribution for internet browsing and office.
I still haven't seen a linux program with the flexibility of MS Outlook.
When I do that's the way I'll go.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Wed Jan 07, 2009 3:33 pm    Post subject: Flight Simulator Reply with quote
I was referring to your RAM sticks... Sometimes different sizes and speeds
of chips appear magically in the ram slots. Having different sizes ,speeds
etc can slow down a computer.
Perhaps you should run the possibility of removing the onboard video from
control panel past the people at Micro Soft... It is possible the onboard
and the NVidia are having a tug of war for every frame.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Wed Jan 07, 2009 3:58 pm    Post subject: Flight Simulator Reply with quote
Thanks Mike, I downloaded the free trial version from their website, a 30
minute download for a 10 minute preview. 10 minutes wasn't nearly enough to
figure out how to do anything other than crash, but the frame rate as I
plunged toward the earth was good and the detailed scenery rushing toward me
was impressive.
So likely not my PC then, and at $39.95 I just might order that DVD and do
it right.
bob
PostPosted: Wed Jan 07, 2009 4:17 pm    Post subject: Flight Simulator Reply with quote
The RAM sticks have been there for ages, I upgraded from the original 512m
by adding a 1g stick back when 1g sticks cost real money (I recently put 4g
in my Garmin for $18!), and never a problem. The Performance Monitor rarely
shows over 400m in use anyway. BTW I ran FSX with *everything* else shut
down, no difference.
The instructions for installing the Nvidea said to uninstall the onboard
drivers, I declined to follow a step that would leave me unable to read the
next step! Now that I know the Nvidea card is working I have uninstalled the
onboard chipset and restarted the PC - M$ plug-and-pray of course then
starts the whole Found New Hardware thing with no options to ignore it. It
re-installed the chipset as an "unknown" video controller which I had to
then disable.
Sadly, no difference, FSX is still doing an average of 2 frames per second
on default settings. And no phone calls from M$, what a surprise...
bob
815TL
PostPosted: Wed Jan 07, 2009 4:19 pm    Post subject: Re: Flight Simulator Reply with quote
Bob,
Make sure you have the latest video drivers as well, that makes a world of difference.
About x-plane, let me get a couple of screen shots. With the new version 9+, full detail and forests, I believe it looks much better than FSX. Of course that is my own opinion.
Like I said, the program with all the add ons is huge, and a little complicated to get set up for the beginner, but I can help you out.
Oh, it also simulates ATC, and the airport database is more up to date. On FSX, it still shows 7N1 in Painted Post NY, as a grass srtip, at its old location. X-plane has it correct, with the new paved runway and taxiway.
Andrew
Edit: here are some pictures I took of our local area. Elmira, NY specifically. The buildings are generic, but it uses a real road map database, so all the roads and railroads you see are real. Notice the numbers of trees, this adds a lot of realism over just flat terrain in my opinion. Also notice the cloud shadows over th hills, really nice effect.
I don't want to push x-plane on you, but I do really think it is the better of the 2. The only complaint is like Michel said. Filed of view is limited. It does make it kind of hard on your base leg to turn on to final.
Andrew
 Filesize:  115.55 KB
 Viewed:  728 Time(s)
 Filesize:  123.88 KB
 Viewed:  638 Time(s)
 Filesize:  109.59 KB
 Viewed:  665 Time(s)
 Filesize:  73.76 KB
 Viewed:  597 Time(s)
 Filesize:  121.66 KB
 Viewed:  610 Time(s)
 Filesize:  130.26 KB
 Viewed:  631 Time(s)
 Filesize:  177.2 KB
 Viewed:  734 Time(s)
Goto page 1, 2  Next
Page 1 of 2
