saolesen(at)sirentel.net Guest
Posted: Sun Jan 04, 2009 8:48 am Post subject: Fuel pressure sender testing |
I'm having trouble with my EIS 6000 fuel pressure reading. I have the
proper scale, offset factors, and resistor entered into the EIS for a
0-30 setup. It reads a constant 10.3 psi regardless of whether or
not the fuel pump is on or not. I've checked the continuity of the
pressure sender across the terminals and it has continuity and a
resistance of 6.2 ohms without the pump being on. However, I have no
idea of what it is supposed to read and how to trouble shoot the
problem. Some hints would be welcome.
Sheldon Olesen
wschertz(at)comcast.net Guest
Posted: Mon Jan 05, 2009 7:29 am Post subject: Fuel pressure sender testing |
Try calibrating it off the plane, with air pressure and a pressure gauge
hooked up to a regulator. then you can measure the resistance as a function
of pressure and see if the sender is changing, or if the problem lies with
the readout.
Bill Schertz
KIS Cruiser #4045
N343BS
Dennis Johnson
Posted: Tue Jan 06, 2009 5:11 pm Post subject: Fuel pressure sender testing |
Hi Sheldon,
Take another look at the EIS instruction manual, including any documentation you got with the fuel pressure sensor itself. You need to change the offset value (I think, it's been two years since I did this) in order to get a zero psi when there is no pressure. It's in the instruction manual, but you may have to hunt for it. You can also call EIS; they have always been eager to help whenever I called.
Good luck,
Dennis
