jef.vervoortw(at)telenet. Guest
Posted: Sun Jan 04, 2009 10:54 am Post subject: VOR interference with other wiring? |
Hello,
I'm mounting a Bob Archer VOR antenna in the right wingtip.
There will be also lights, nav. & landing & strobe.
The strobes will be powered by a single power pack in the fuselage, using a
shielded cable ( from Whelen).
I have mounted a corrugated nylon conduit in the wings, and was planning to
put all the wires, including the VOR coax, together in this conduit.
Is this a good solution? I do not find accurate info in the archives.
Thanks; Jef Vervoort, RV9A.
Dennis Glaeser
Joined: 10 Jan 2006 Posts: 53 Location: Rochester Hills, Michigan
Posted: Sun Jan 04, 2009 1:46 pm Post subject: VOR interference with other wiring? |
I did exactly that on my RV7A and have no problems whatsoever.
Dennis Glaeser
Hello,
Posted: Mon Jan 05, 2009 1:29 pm Post subject: VOR interference with other wiring? |
It's a well watered and fertilized myth that strobe head
wires are a noise coupling risk to coaxial feedlines to
antennas. You may route them together without concern.
At 03:44 PM 1/4/2009, you wrote:
<glaesers(at)wideopenwest.com>
Dennis Glaeser
Hello,
