nosky2high
Joined: 07 Oct 2008 Posts: 13 Location: Fayetteville, NC
Posted: Sat Jan 03, 2009 10:06 am Post subject: Aileron Trim Tab Lessons Learned Request |
It's the "new guy" again,
In the middle of measuring out the cutouts for the aileron trim tab. There are no directions to go by, just the plans for the option. Having assembled the elevator trim tab, is the aileron install basically the same operation?
Requesting any lessons learned out there, I read the past posts about the 25deg up and down issue. Any others?
Best Regards,
Anthony
_________________ Anthony Hanson
Ft.Bragg, NC
Kiowa Warrior Pilot
Building ZenVair650 from Nov'08 ZAC 650 kit, tail 95%, Flaps Done, Working on Ailerons, Engine test ran. |
sdthatcher
Joined: 13 Mar 2008 Posts: 91 Location: Port Saint Lucie
Posted: Sat Jan 03, 2009 2:06 pm Post subject: Re: Aileron Trim Tab Lessons Learned Request |
Hi Anthony,
From another ZenVair owner, I felt it was about the same procedure for the aileron as the elevator. Gus Warren said that I should place a stiffener adjacent to the motor to keep the aileron from flexing, but it's much easier to do when building than after it's built.
Gus, if you're on the list, can you elaborate?
| nosky2high wrote: | It's the "new guy" again,
Best Regards,
Anthony |
_________________ Scott Thatcher, Port Saint Lucie, FL
601XL with Corvair, Registered as E-LSA
N601EL, EAA203 140 hours and not flying currently. |
nosky2high
Posted: Sat Jan 03, 2009 2:35 pm Post subject: Re: Aileron Trim Tab Lessons Learned Request |
The plans don't appear to be completely accurate, if you cut out the access panel hole as per the plans dimensions the cover plate will extend over the aileron spar bottom edge. I just shifted the access hole farther away from the spar by about 10mm farther than the plans called for. Too chicken to cut the metal though until I'm sure.
Regarding the additional angle to support the trim motor, I'm not picturing the placement, requesting some further guidance on that. Will hold off all the cutting until I can get clarification.
On to the wings.
Anthony
Ft.Bragg, NC
Kiowa Warrior Pilot
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sat Jan 03, 2009 3:35 pm Post subject: Aileron Trim Tab Lessons Learned Request |
Anthony
You are right about the plans. The access hole is shown too close to the
front edge of the aileron. If you put it there, there are conflicts, but I
cannot recall the details. Your 10-mm sounds about right. I wouldn't shift
the servo, just the access hole.
Regarding the stiffeners, Mirko suggested them a while back. My
understanding is for something like I've shown in the attached sketch,
probably attached with A4's. The flanges of the angles fit underneath the
servo. I plan to retrofit stiffeners eventually. I will probably cut the
web on the angles (i.e., the vertical side) to 1/2 or 1/3 the standard
width to lighten them. I believe that would be adequate.
Terry
At 02:35 PM 1/3/2009 -0800, you wrote:
| Quote: | The plans don't appear to be completely accurate, if you cut out the
On to the wings.
Anthony
Anthony Hanson
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
26.08 KB |
597 Time(s) |
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
jaybannist(at)cs.com Guest
Posted: Sat Jan 03, 2009 3:40 pm Post subject: Aileron Trim Tab Lessons Learned Request |
Anthony,
Be aware that there are left hand and right hand servos. The ones that ZAC furnishes doesn't always agree with the drawings. This can be very confusing since you are doing the mounting layout upside down. Mine were opposite hand from what was shown on the drawings and I didn't figure it out until I had cut the access hole. I had to cut an oversize hole and make a larger cover plate.
Jay in Dallas
nosky2high
Posted: Sat Jan 03, 2009 6:43 pm Post subject: Re: Aileron Trim Tab Lessons Learned Request |
Looks like I'm going to start over from the Tab cutout measurements, then from the center measure the rod distance to get the location of the servo. From there locate the L angle braces, then once the servo is set, cut the access panel in the bottom.
Question for the long term maintainers out there, is there a "best" side of the servo to put the access hole? over the clevis, over the wires, or just basically centered over the servo itself? seems that perhaps it would be advantageous to cheat the access over the side of the clevis and the wiring for easier clevis adjustments and any wiring issues.
Had a big bummer today, only got one 12' rear spar, how in the h&^K did they forget that? I inventoried everything else upon delivery focusing on the smaller parts mainly and just couldn't imagine that they'd forget the second rear spar so I didn't cut the packing paper off until today.
Any issues with ZAC on getting parts they failed to ship?
Blue Skies,
Anthony
Ft.Bragg, NC
Kiowa Warrior Pilot
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Sat Jan 03, 2009 7:02 pm Post subject: Re: Aileron Trim Tab Lessons Learned Request |
Best Regards,
Anthony |
Capt'nPurple,
I don't know if this helps, but here is what I did when I scratch built mine.
http://mykitlog.com/users/display_log.php?user=rlendon&project=113&category=1683&log=19488&row=407
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
Iberplanes
Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
Posted: Sun Jan 04, 2009 1:39 am Post subject: Aileron Trim Tab Lessons Learned Request |
Hello Anthony,.
I´m in the same part as you are, I guess you´re right, installation should be like the aileron trim tab. I´ve bought an Olpha knife and I expect to cut the aluminum as shown on the homebuilthelp videos.
Bye,
Alberto Martin
www.iberplanes.es
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
_________________ Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
Igualada - Barcelona - Spain |
nosky2high
Posted: Sun Jan 04, 2009 2:28 pm Post subject: Re: Aileron Trim Tab Lessons Learned Request |
See these attached photos of the top and bottom aileron skin measurements for the trim tab and motor.
The plans call for 145mm from edge of trim tab cut out to the bottom row of holes in the servo, by my measurements 135mm is the better measurement due to interference with the aileron spar flange. Any others out there experiencing the same issue? I love pre-punched skins just wish they'd pre-punched out the trim tab like they do in the elevator.
higher resolution photos available here;
http://picasaweb.google.com/nosky2high/WingKitFlapsAilerons?feat=directlink
if the attached downsized photos don't explain the situation well enough.
phone call to ZAC tomorrow.
Anthony
70.22 KB |
608 Time(s) |
69.94 KB |
662 Time(s) |
Ft.Bragg, NC
Kiowa Warrior Pilot
Ron Lendon
Posted: Sun Jan 04, 2009 4:20 pm Post subject: Re: Aileron Trim Tab Lessons Learned Request |
Anthony,
Try transferring the flange line to the outside of the skin after you have the access hole cut. I think the servo needs to be close but not touching the flange, perhaps .5mm clearance.
Make sure you have a straight line from the servo to the trim tab horn and it will work out.
The wings aren't here otherwise I would give you some dimensions.
CH 601 XLB
N601LT - Flying
dvanlanen
Posted: Mon Jan 05, 2009 8:42 am Post subject: Aileron Trim Tab Lessons Learned Request |
I had the same experience. It appears that the plans are incorrect. When I
first asked ZAC about it, they suggested overlapping the spar flange with
the servo, which I didn't think was a good idea, so I asked if I could move
the servo rearward and they said that would work just fine. I moved the
servo rearward until I had about 2mm to 3mm of clearnce from the aileron
spar flange, and then went from there.
Dave Van Lanen
601XL - tail done, flaps done, finishing ailerons
Time: 02:29:45 PM PST US
Subject: Re: Aileron Trim Tab Lessons Learned Request
for the
trim tab and motor.
holes
interference
trim
Anthony
winmail.dat |
3.96 KB |
468 Time(s) |
