GPS Serial Data to Garmin GTX-327 Transponder
Site Admin
PostPosted: Fri Jan 02, 2009 10:45 am    Post subject: GPS Serial Data to Garmin GTX-327 Transponder Reply with quote
Listers,
I've tried sending two different sources of NMEA 0183 data at 4800/9600/19200/38400/57600 baud rates to my Garmin GTX-327 on both serial input ports 1 (db25 Pin 2) and port 2 (db25 pin 19), and configured for "GPS" input. But I don't get anything on the GTX-327 serial input test display. I have been successful at getting AirData Z-format from the GRT EFIS at 9600 baud into either of the GTX-327 serial ports, so the ports are good. The NMEA 0183 data registers correctly on other devices reading it so the GPS serial output seem fine. The GTX-327 just won't seem to see the GPS data for some reason.
Am I doing something wrong? Has anyone else tried this successfully?
Thanks!
RV-8 #82880 N998RV
Tim Olson
PostPosted: Fri Jan 02, 2009 11:29 am    Post subject: GPS Serial Data to Garmin GTX-327 Transponder Reply with quote
I'm not positive of this, but I think most Garmin stuff
will not work with NMEA 0183, only Aviation format. It
makes working with some things a bit tough. So the
GTX-327 probably just doesn't understand it.
Matt Dralle wrote:
Listers,
reason.
Thanks!
Matt Dralle RV-8 #82880 N998RV
