mz(at)cariama.nl Guest
Posted: Fri Jan 02, 2009 9:02 am Post subject: Garrecht Ultracompact VT01 installed anyone? |
I am about to replace my Terra TRT-250D transponder (mode a+c ) with a Mode-S transponder, and have ordered a Garrecht VT01 Ultra compact Class2.
Has anyone already installed this transponder in their Europa, and was EASA paperwork completed (Form 32) that I can refer to when submitting my paperwork?
Anyone interested in buying the Terra transponder once I have replaced it?
Marcel
Visit - www.EuropaOwners.org
Posted: Fri Jan 02, 2009 9:52 am Post subject: Garrecht Ultracompact VT01 installed anyone? |
Hi! Marcel,
I have just read and re-read the item on Mode S in the January issue of
the LAA Magazine. This is very sensitive to me since I have a Garmin
Mode S 328 on order from 7th January.
The item reads that Mode S will not become mandatory except in Class A
to C and specific areas of Class D Airspace but will be required by
March 31st 2012 in those specified areas. "otherwise Mode A/C will
continue until at least 2012 with a two year notice period of it's
demise in UK airspace."
Whilst I welcome this I'm somewhat confused when in August 2008 Dutch
Military enforced Maximum height restriction of 1500ft on me flying from
Speyer to Texel forcing me to either bust some local airspace or fly
through an IMC storm along the Belgian/Dutch border.
If we are to suffer isolated enforcement from different authorities it
will be an "airborne minefield" to navigate to avoid mode S areas.
Hopefully someone will respond in time with some logic so that by 6th of
January I can cancel my order because I for one don't have GBP £1800 to
throw in the wind.
Perhaps this doesn't help you now Marcel but it may promote some
enlightening discussion!
Best regards and Happy New Year.
Bob Harrison G-PTAG
Posted: Fri Jan 02, 2009 11:40 am Post subject: Garrecht Ultracompact VT01 installed anyone? |
[quote:84434a7145="ptag.dev"]Whilst I welcome this I'm somewhat confused when in August 2008 Dutch Military enforced Maximum height restriction of 1500ft on me flying from Speyer to Texel forcing me to either bust some local airspace or fly through an IMC storm along the Belgian/Dutch border.[/quote:84434a7145]
You are so right here, this is exactly why I feel I have no option but to replace my mode A/C with a mode S. Not having a mode S simply is too limiting if you're based in Holland (below 1500ft are nice altitudes to fly at, but only when descending for landing or ascending to cruising level )
[quote:84434a7145="ptag.dev"]If we are to suffer isolated enforcement from different authorities it will be an "airborne minefield" to navigate to avoid mode S areas.[/quote:84434a7145]
Spot on. My approach: get a mode S to eliminate the minefields all together...
[quote:84434a7145="ptag.dev"]Hopefully someone will respond in time with some logic so that by 6th of January I can cancel my order because I for one don't have GBP £1800 to throw in the wind.[/quote:84434a7145]
Well, knowing that you do quite some touring around Europe, I would not consider this money thrown in the wind in your situation: having a mode S would make your touring a lot less troublesome for the time being (at some point you will be forced to replace your A/C anyway, so the money will be leaving your pocket anyway).
Posted: Fri Jan 02, 2009 3:08 pm Post subject: Garrecht Ultracompact VT01 installed anyone? |
Hi! Marcel
I think what you are saying is that there is more necessity for Mode S
when flying in Europe than in the UK and this I can not agree with. If
the UK CAA are content to bring Mode S in over a longer period but the
rest of Europe isn't, IMHO this "smacks" of European bureaucracy
applying "you do what WE say NOW" philosophy.
I believe that the greater proportion of radar reception equipment is
unable to handle all VFR Mode S traffic yet on a Europe wide basis, or
am I mistaken?
Bob Harrison G-PTAG
Posted: Fri Jan 02, 2009 3:15 pm Post subject: Garrecht Ultracompact VT01 installed anyone? |
Hi! Marcel,
Further to my message just sent on this Mode S topic on past experiences
a delay period of three years is quite likely for the equipment
specifications to change so that mandatory installation just may make
equipment bought now obsolete necessitating still further expense, don't
forget it's our hard earned cash they are spending not theirs!
Bob Harrison G-PTAG
DuaneFamly(at)aol.com Guest
Posted: Fri Jan 02, 2009 8:15 pm Post subject: Garrecht Ultracompact VT01 installed anyone? |
Just to my 2 cents, or maybe pence in this case.....but exactly how much less expensive will that Garmin be in 3 years? If it's anything like computer stuff, maybe 50%? From the other side of the Pond.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300A
Sensenich R64Z N
Ground Adjustable Prop
Stay up-to-date on /a> - from fashion trends to celebrity break-ups and everything in between.
Posted: Sat Jan 03, 2009 2:03 am Post subject: Garrecht Ultracompact VT01 installed anyone? |
[quote:fa65874136="ptag.dev"]I think what you are saying is that there is more necessity for Mode S when flying in Europe than in the UK[/quote:fa65874136]
I did not intend to compare countries with my statement, I was only looking at cockpit and flight-prep procedures: if you have a Mode S, you don't need to worry about Mode S or Mode A/C anymore. No more need to circumnavigate Mode S mandatory zones, no more height-restrictions due to not having one, etc. Just turn the thing on, and 'forget' about it...
My view of course will be clouded, because in Holland you must have Mode S if you wish to go higher than 1500ft, making the decision of getting a Mode S the more obvious one (please read: almost an absolute necessity).
Marcel
PS 2
I do fully subscribe your views on bureaucracy
Posted: Sat Jan 03, 2009 3:17 am Post subject: Garrecht Ultracompact VT01 installed anyone? |
Hi! Marcel
I appreciate your points but I don't think the motives of the
authorities are such that with Mode S will entitle you to zoom about
anywhere but that if you do then they will have a "handle" on you and
details of where to send their bill, be it a fine for infringement or
indeed as seemingly necessary for "Air Navigation Services" charges for
entering and leaving such as Tempelhof air traffic control zone. They
will still require you to comply with all height restrictions, the main
difference with Mode S being that they will have height read out against
your name.
Of course my point about some possibility of equipment needing to be up
graded or superceded by three years in the future may also be affected
by prices of such equipment being slashed as Mike Duane points out, but
where aeronautical equipment is concerned the manufacturers expect that
we can stand the cost whatever so I would be amazed if they reduced any
current prices.
Regrds
Bob Harrison G-PTAG
craigb(at)onthenet.com.au Guest
Posted: Sat Jan 03, 2009 4:09 am Post subject: Garrecht Ultracompact VT01 installed anyone? |
Bob just touching on the price and possible reduction over time. MGL are
supposedly
releasing a Mode S transponder shortly. Given the price of their EFIS panels
we can all hope they might "throw a cat amongst the pigeons" as it were
which could force
a price drop from the others.
As far as the Mode S goes in australia, All new aircraft Registrations are
being issued a mode
S ident.
Craig
Ivor Phillips
Posted: Sat Jan 03, 2009 5:02 am Post subject: Garrecht Ultracompact VT01 installed anyone? |
Same here Craig, the CAA have issued Ident's since 2007, I personally have only
one year's use of a new Garmin GTX327 and therefore reluctant to replace it just yet, As Bob and me do a lot of trips together i think it would be best for Bob to change to mode S and i follow behind using mode A as part of the formation
Or more likely though i dont condone it, is Pilots NOT turning on there transponders at all in class G ( that will really improve safety)
regards
Ivor
Quote: | Bob just touching on the price and possible reduction over time. MGL are
supposedly
which could force
being issued a mode
S ident.
Hi! Marcel
your name.
current prices.
Regrds
Bob Harrison G-PTAG
Marcel
PS 2
Checked by AVG - http://www.avg.com
1:10 PM
