John Bickham
Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
Posted: Fri Mar 24, 2006 4:13 pm Post subject: Wheel to wheel dimension - Mark IIIC |
Hello List,
I have been working on some new gear legs for my Mark IIIC. I've welded them up and fitted them.
Before I drill the holes for the axles I wanted to see if I was close to the right dimension for the distance from the outside to outside of the wheel. Problem is my old gear legs are bent so bad it is hard to be sure.
I searched the archives and found I response to Larry B from Richard Pike. Richard had a distance of 76" from outside of wheel to outside of wheel.
If any of you walk by your plane and could measure the wheel to wheel distance I would appreciate it. I'm kinda doing this in the "true experimental" spirit as far as a my experience level goes. Just checking. I am a bit interested in what the variations are in this distance, if there is any, among all the MarkIIIC's. Maybe everyone is right at 76".
I'm close to 78" with the axle flush against the sleeve. You will notice that there is ~7 degree camber in the wheels. I'm not sure if it is positive or negative. Not an expert. That is what Jim Hauck recommended. I've read a few complaints about the factory gear sitting ugly with weight and a few firm landings. Mine should be close to straight once I've done my little drop ins. Gives me room to work! Kinda like the look better.
Thanks in advance.
| Axle extended a bit. Do you think this would be a problem. |
99.84 KB |
542 Time(s) |
| Axle mounted flush against sleeve. |
96.17 KB |
556 Time(s) |
| Sit a bit higher with new gear and wheels. Notice the original bent gear in the background. |
116.38 KB |
575 Time(s) |
_________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. |
Posted: Fri Mar 24, 2006 4:29 pm Post subject: Wheel to wheel dimension - Mark IIIC |
outside of the wheel. Kinda like the look better.
| John Bickham
Looks great to me. I like a lot of positive camber.
As far as track is concerned??? I don't think it makes a lot of
difference. My gear is probably a foot wider than standark MKIIIc.
Helps me keep the wings level when I ground loop.
Recommend using two 1/4" bolts in each axle socket. When I put on my
upgraded brakes, I was using the stand two 3/16" bolts. First time I
taxied down to the end of the strip, used the brake to pivot, I wrung
off the two bolts. That is when I decided to upgrade to 1/4.
Gonna be a good looking, good flying MKIIIc. Already been initiated,
so don't have to do that anymore.
MKIII
_________________ John Hauck
Titus, Alabama |
Steven Green
Posted: Sat Mar 25, 2006 2:39 pm Post subject: Wheel to wheel dimension - Mark IIIC |
John,
Mine is 76" also.
Steven Green
Hello List,
_________________ Steven Green |
