jblake207(at)COMCAST.NET Guest
Posted: Mon Dec 29, 2008 8:24 am Post subject: Voltage Regulators |
Pretty sure the VR on my CJ is kaput. Has anyone installed a zeftronics or other than original equipment VR on either a CJ or YAK? JB<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
JOE HOWSE
Joined: 10 Jan 2006 Posts: 140 Location: DUNCAN BC CANADA
Posted: Mon Dec 29, 2008 9:36 am Post subject: Voltage Regulators |
If you have the original magnetic VR ZY1500,
We have built a direct replacement using a standard
carbon pile regulator and a solid state reverse current diode.
Uses original wiring and mounts on the same position.
price is 750 plus freight.
If you are interested I can send pics.
Joe Howse
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
| [b]
_________________ J.C. HOWSE |
dougsappllc(at)gmail.com Guest
Posted: Mon Dec 29, 2008 9:38 am Post subject: Voltage Regulators |
JB,
I may have a new VR in my stock depending on which one you have.
Happy new year,
Doug
On Mon, Dec 29, 2008 at 8:22 AM, <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
gill.g(at)gpimail.com Guest
Posted: Mon Dec 29, 2008 10:07 am Post subject: Voltage Regulators |
Be sure you specify a type B generator when ordering a Zeftronics
Gill
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of jblake207(at)COMCAST.NET
Sent: Monday, December 29, 2008 9:23 AM
To: yak-list(at)matronics.com
Subject: Voltage Regulators
| Quote: | | http://www.matronics.com/contribution | 01234567890123
Checked by AVG - http://www.avg.com
12/28/2008 2:23 PM
yakplt(at)yahoo.com Guest
Posted: Mon Dec 29, 2008 2:02 pm Post subject: Voltage Regulators |
Just for grins... what makes you sure the voltage regulator is bad? I know nothing about CJ electrical systems. Never worked on, or touched one in my life. However, I will say that I can hold my own with the Russian designed systems. In the latter, a whole lot of things can go wrong, and the voltage regulator is not really at the top of the list. Shorts on the mount and VR wiring are not all that uncommon. A failed VR itself happens, but is not common. Of course anything can fail, but unless you have specifically tested the voltage regulator itself and are darn sure it is bad, I would be careful. I.E. If you have borrowed another VR from a fellow CJ owner and that FIXED the airplane, no issues. If you have not done that.... you might want to think about it before purchasing a new one.
Doug... anyone else... is the CJ-6 electrical system the same as the Russian design? I.E. Does it include an over-voltgage interupt relay to generator excitation, and does it use a reverse over-current relay like the Russian DNP-200?
Mark Bitterlich
N50YK
From: "jblake207(at)comcast.net" <jblake207(at)comcast.net>
Sent: Monday, December 29, 2008 11:22:48 AM
vectorwarbirds(at)aol.com Guest
Posted: Mon Dec 29, 2008 7:09 pm Post subject: Voltage Regulators |
JB:
I put the Jasco alternator on my CJ, lost about 25 pounds and works flawlessly. Easy to install. Got mine from George Coy at Gesoco, bolts right on. About 800 clams back then!
Bunndini
Vector Warbirds
