Posted: Thu Dec 25, 2008 6:46 am Post subject: GX60/MX20 monthly - require Logbook entry? |
Folks,
I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. Am I
required to log the software revision and install date in the aircraft
logbook? If so, What would the entr look like?
Ralph
RV6A N822AR 0hrs getting ready for refresher training and waiting for the
weather......
rjquillin
Posted: Thu Dec 25, 2008 7:37 am Post subject: GX60/MX20 monthly - require Logbook entry? |
Got that new update subscription for Christmas?
Yes you are.
See the following citations for content and form.
Ron Q.
At 06:38 12/25/2008, you wrote:
| Quote: | Folks,
I get monthly Jeppesen updates for my GX60 and MX20 GPS map displays. Am I required to log the software revision and install date in the aircraft logbook? If so, What would the entr look like? |
You are permitted to keep your data base current by the following section:
Appendix A to Part 43—Major Alterations, Major Repairs, and Preventive Maintenance
(c) Preventive maintenance. Preventive maintenance is limited to the following work, provided it does not involve complex assembly operations:
(32) Updating self-contained, front instrument panel-mounted Air Traffic Control (ATC) navigational software data bases (excluding those of automatic flight control systems, transponders, and microwave frequency distance measuring equipment (DME)) provided no disassembly of the unit is required and pertinent instructions are provided. Prior to the unit's intended use, an operational check must be performed in accordance with applicable sections of part 91 of this chapter.
43.9 specifies what is required for a logbook entry.
§ 43.9 Content, form, and disposition of maintenance, preventive maintenance, rebuilding, and alteration records (except inspections performed in accordance with part 91, part 125, §135.411(a)(1), and §135.419 of this chapter).
(a) Maintenance record entries. Except as provided in paragraphs (b) and (c) of this section, each person who maintains, performs preventive maintenance, rebuilds, or alters an aircraft, airframe, aircraft engine, propeller, appliance, or component part shall make an entry in the maintenance record of that equipment containing the following information:
(1) A description (or reference to data acceptable to the Administrator) of work performed.
(2) The date of completion of the work performed.
(3) The name of the person performing the work if other than the person specified in paragraph (a)(4) of this section.
(4) If the work performed on the aircraft, airframe, aircraft engine, propeller, appliance, or component part has been performed satisfactorily, the signature, certificate number, and kind of certificate held by the person approving the work. The signature constitutes the approval for return to service only for the work performed.
