carlossa52(at)gmail.com Guest
Posted: Mon Dec 22, 2008 3:39 pm Post subject: Rivet puller problems (off-list) |
Harvey, this subject was discussed in the recent past - can't remember on which z-list, neither the outcome - but you should be able to find it with a search.
Good luck
Carlos
CH601-HD, plans
2008/12/22 Harvey Richards <lisa.richards(at)ns.sympatico.ca (lisa.richards(at)ns.sympatico.ca)>
[quote] --> Zenith701801-List message posted by: "Harvey Richards" <lisa.richards(at)ns.sympatico.ca (lisa.richards(at)ns.sympatico.ca)>
Would anyone have any ideas on the following hand rivet puller problems. About every 5th or so A5 rivet has a sharp stem protrusion a mm or so and some are breaking off with 10 mm or so protruding with the same sharp angle. I have disassembled and lightly lubricated and it still happens. A4 rivets pull ok. Thanks Do not archive
CH 701
