		Jerry Grimmonpre'
  Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
				 Posted: Wed Dec 17, 2008 10:47 am    Post subject: Static System Assembly |
				Dear List ...
 I'm rebuilding my static system and am looking for "how did you do it"
 suggestions.
 Specifically:
 How did you attach the tubing to the Van's static port rivet tails?
 Glue, RTV or ... ?
 Did any of you find a clamp that would work with such a small diameter and
 short rivet tail?
 What method does not work or will not hold together between condition
 inspections?
 Thanks, Jerry
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rice737(at)msn.com Guest
				 Posted: Wed Dec 17, 2008 12:17 pm    Post subject: Static System Assembly |
				Hey Jerry C
  I bought some rivets with the same head but a longer grip and used a little sealant and a zip tie.  I didn't like that the vans rivets had such a short shank to clamp to.
  Paul Rice
  RV8 Flying Siren
  130 hours
  	  | Quote: | 	 		   From: jerry(at)mc.net
  To: rv-list(at)matronics.com
  Subject: Static System Assembly
  Date: Wed C 17 Dec 2008 12:37:31 -0600
  --> RV-List message posted by: "Jerry Grimmonpre" <jerry(at)mc.net>
  Dear List ...
  suggestions.
  Specifically:
  Glue C RTV or ... ?
  short rivet tail?
  inspections?
  Thanks========
		jfogarty(at)tds.net Guest
				 Posted: Wed Dec 17, 2008 1:09 pm    Post subject: Static System Assembly |
				RV's Builders,  I used a silicone and the rivets in  the kit from Van's.  Is there any problem with using silicone on the  aluminum skin or ribs?  Silicone works well for holding parts in  place, however, will it effect the skin over time?  Thanks for any  input.
  Jim
  RV9a
  [quote]   ---
		rv9jim(at)juno.com Guest
		stein(at)steinair.com Guest
				 Posted: Wed Dec 17, 2008 1:47 pm    Post subject: Static System Assembly |
				It won't  necessarily affect the skins, but if you use it externally it'll likely make it  near to impossible to ever get a paint job to stick to it...even with it visibly  cleaned.  Silicone (or an product with silicone in it) is a  big no-no for external use on airplanes as it doesn't play nicely with  paint.
  Stein
  [quote]   -----Original    Message-----
 From: owner-rv-list-server(at)matronics.com    [mailto:owner-rv-list-server(at)matronics.com]On Behalf Of Jim Fogarty at    Lakes & Leisure Realty
 Sent: Wednesday, December 17, 2008 3:09    PM
 Subject: Re: Static    System Assembly
    Jim
    RV9a
		pbesing(at)yahoo.com Guest
				 Posted: Wed Dec 17, 2008 2:37 pm    Post subject: Static System Assembly |
				Not sure if they still sell them, but Cleveland tool makes some machined static ports which are very nice.  Just be sure and mount them to the OUTSIDE of the skin...otherwise the static port will be caught in the boundary layer, and will not be accurate..ask me how I know....
 Paul Besing
 Sent: Wednesday, December 17, 2008 2:47:27 PM
 Subject: RE: Static System Assembly
      .hmmessage P { PADDING-RIGHT:0px;PADDING-LEFT:0px;PADDING-BOTTOM:0px;MARGIN:0px;PADDING-TOP:0px;} BODY.hmmessage { FONT-SIZE:10pt;FONT-FAMILY:Verdana;}    It won't  necessarily affect the skins, but if you use it externally it'll likely make it  near to impossible to ever get a paint job to stick to it...even with it visibly  cleaned.  Silicone (or an product with silicone in it) is a  big no-no for external use on airplanes as it doesn't play nicely with  paint.
  Stein
    Jim
    RV9a
		gyoung
  Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
				 Posted: Wed Dec 17, 2008 2:43 pm    Post subject: Static System Assembly |
				There are numerous paintable sealant/adhesives that can do the  same kind of job as the silicone-based ones. Proseal-like tank sealants, Lexel  and Sikaflex come to mind.
 Greg Young
  [quote]         From: owner-rv-list-server(at)matronics.com    [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of SteinAir,    Inc.
 Sent: Wednesday, December 17, 2008 3:47 PM
    Stein
     	  | Quote: | 	 		       -----Original      Message-----
 Subject: Re: RV-List:      Static System Assembly
      Jim
      RV9a
  | 	  [b]
				 Posted: Wed Dec 17, 2008 2:45 pm    Post subject: Static System Assembly |
				Well ...... depends.  Some silicone caulk smells like vinegar ....
 acetic acid ..... which surely isn't friendly to aluminum ..... but
 unlike the lead pencil/aluminum corrosion I haven't heard of any real
 problems with using silicone on aluminum.  In fact, I see it used quite
 a lot.  I know I didn't answer your question, but it is something to
 think about.
 Linn
 Jim Fogarty at Lakes & Leisure Realty wrote:
 [quote] RV's Builders,  I used a silicone and the rivets in the kit from
  Jim
  RV9a
				 Posted: Wed Dec 17, 2008 3:01 pm    Post subject: Static System Assembly |
				Stein,  Thanks for the info.  I appreciate your  knowledge, I'm sorry I didn't get to your shop last Saturday.   I hope  you had a good turn out and that your business is busy.  Good luck in  2009.
  Jim
  RV9a
  [quote]   ---
		mikerv6a(at)ao.com Guest
				 Posted: Wed Dec 17, 2008 4:02 pm    Post subject: Static System Assembly |
				I came up with a way to make a back-side fitting for
 Van's static port. This permits use of a removable
 fitting for plastic tubing to connect the static vent
 plumbing. It's described in the EAA chapter 105
 newsletter for April 2005, page 2:
   http://www.eaa105.org/Newsletter/nl-200504.pdf
 Mike Linse
 Corvallis, OR
 RV-6A (canopy, in the winter...)
		Jerry Grimmonpre'
				 Posted: Wed Dec 17, 2008 6:40 pm    Post subject: Static System Assembly |
				Hi Mike,
 You have won the prize for an elegant solution to the static system plumbing
 challenge.  That's a clever approach.   If it's OK I am going to use it for
 my static hook-up.  It also seems possible to drill a close fitting hole in
 a light weight pipe cap, and expand the rivet into that cap then drive out
 the center stem.  Back it up with a little tank sealant.
 Thanks, Jerry
		bsavage22(at)hotmail.com Guest
				 Posted: Wed Dec 17, 2008 8:18 pm    Post subject: Static System Assembly |
				I had the same trouble with the rivet tail being to short.  I went to the hardware store and bought some aluminum tubing that would just fit over the rivet tail before it was installed.  I cut about a 1 inch length and had someone hold the tubing over the rivet on the inside of the fuselage while I pulled the rivet from the out side.  As the pop rivet expanded it did the same to the tubing and the tubing made a nice little nipple to connect van's plastic tubing to on the inside.  I sealed it with a couple of turns of safety wire.
 Bob Savage
 RV7A
 Firewall Forward
 [quote] From: jerry(at)mc.net
  Dear List ...
  suggestions.
  Specifically:
  Glue C RTV or ... ?
  short rivet tail?
  inspections?
  Tha=============
 Suspicious message? There’s an alert for that.  Get your Hotmail® account now.
				 Posted: Wed Dec 17, 2008 11:04 pm    Post subject: Static System Assembly |
				Hi Jerry
 That's a good idea: It eliminates the tapping operation.
 Also, one complication of my use of round bar is that
 there are not features for use of a wrench. Vise grip
 pliers solved that, but I made later versions from 1/2"
 hex aluminum bar. Pipe caps generally have features
 that make them compatible with some kind of wrench or
 pliers. McMaster sells an aluminum cap that's threaded
 for 1/8 pipe, their part number 44705K372, $2.18.
 Mike Linse
 Corvallis, OR
 RV-6A
  Hi Mike,
  [snip] It also seems possible to drill a close fitting hole
  in  a light weight pipe cap, and expand the rivet into that
  cap then drive out the center stem.  Back it up with a little
  tank sealant.
  Thanks, Jerry
 > Van's static port...  It's described in the EAA chapter 105
		Jerry Grimmonpre'
				 Posted: Thu Dec 18, 2008 1:17 pm    Post subject: Static System Assembly |
				Mike,
 Thanks for the McMaster part number on the cap.  I just ordered two of them
 along with enough "push to connect" parts to assemble the static plumbing.
 You are right, Mike, these parts will make rebuilding the system far easier
 and the sealing of small parts is now going to be a non-issue.
 One other thing to add:  If a push to connect T is installed in the static
 line leading to the instruments, the transponder check will be simple to do.
 This T could be permanently installed in the line passing through the rear
 cockpit which makes it accessible while standing on the ground and reaching
 over the canopy rail.
 Thanks,  Jerry
