Lynn Matteson
Posted: Fri Dec 19, 2008 2:28 pm Post subject: Lovely snow...damned snow! Off topic |
We (in lower, Lower Michigan) got about 5-11" of new snow today,
(added to the 3-4" last week) but the damn stuff didn't quit until
flying hours...for me....were over for the day. Plus, the driveway
into the hangar was too deep to negotiate, and the plow guy was not
available. Tomorrow will/should be better for getting my ski-equipped
Kitfox out and enjoy the snow-flying. If this stuff would just come
2-3" at a time, I could handle the driveway and parking (the car)
problems, but when it comes in "wholesale" amounts, it's just too
much...damn!
Oh well, I've got a fresh bottle of Baileys Irish Cream to help me
through the night, plenty of wood brought inside to feed the fire,
and plenty of projects (vacuum bagging and TIG-welding practicing to
be done for the next pair of skis) to keep me busy. And you guys have
got your Kitfox-building projects, so all is well.
Lynn Matteson
Jabiru 2200, #2062, 596+ hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
patreilly43(at)hotmail.co Guest
Tom Jones
Posted: Fri Dec 19, 2008 3:39 pm Post subject: Re: Lovely snow...damned snow! Off topic |
Lynn,
At least you have skis so some fun to look foreword to. We have plenty of snow in Central Washington and more on the way. I wonder if I can take the skis off my snowmobile and put them on my kitfox.
Merry Christmas to all, card attached. do not archive
341.08 KB |
570 Time(s) |
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Fri Dec 19, 2008 4:28 pm Post subject: Lovely snow...damned snow! Off topic |
We're supposed to get between 11" and 24" on the ground before
Christmas. And me with undersized skis...drat!
They say that practice is what makes makes a TIG weldor, and to a
lesser extent the MIG. I had to weld a little on a snow-thrower
yesterday, and it was a real effort not to use the TIG, but the MIG
laid the metal down where I needed it, and a lot faster too. Now I've
got the "big 4"...arc, gas, MIG, and TIG, so no excuses for not being
able to stick something together...except for practice. The other
three I can make a presentable weld, but the TIG is a bear to master.
Lynn Matteson
Sensenich 62x46
system;
On Dec 19, 2008, at 6:24 PM, patrick reilly wrote:
| Quote: | Lynn, Same here in Rockford. 10" today and I was cutting firewood.
The difference is, I am studying for the written test. I will take
it after Christmas. I also need some welding practice. I can't mig
weld except in the flat. Haven't practiced enough yet to get the
right settings on the machine or proper torch position yet. It is
kind of like my painting experience, I do it so infrequently that I
am always starting over again.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> From: lynnmatt(at)jps.net
> Subject: Lovely snow...damned snow! Off topic
> Date: Fri, 19 Dec 2008 17:26:41 -0500
> To: kitfox-list(at)matronics.com
equipped
> much...damn!
have
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> system;
N369LM |
thesupe(at)hotmail.com Guest
Posted: Fri Dec 19, 2008 5:10 pm Post subject: Lovely snow...damned snow! Off topic |
I've had my plane on skis for almost 2 weeks C Flew about 3 hours between yesterday and Wednesday. Temps were about +7 F both days so I wasn't sweating anyway! We had about 12" of snow last weekend on top of the 6" or so that was there allready. Supposed to get 4"-8" tomorrow. Only real problem is the lakes are getting water coming up on top of the ice because the weight of all the snow on it and that makes slush which is not good to land on. I ruined a prop last winter when I taxied through slush that splashed up and hit the prop blades. Well at least up here in Mn we allways have something to complain about. LOL. Take care C Jim Chuk Avid MK IV Mn
| Quote: | Subject: Re: Lovely snow...damned snow! Off topic
Date: Fri C 19 Dec 2008 15:39:50 -0800
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
Lynn C
At least you have skis so some fun to look foreword to. We have plenty of snow in Central washing and more on the way. I wonder if I can take the skis off my snowmobile and put them on my kitfox.
Merry Christmas to all C card attached.
Tom Jones
Classic IV
503 Rotax C 72 inch Two blade Warp
Ellensburg C WA
http://forums.matronics.com/viewtopic.php?p=220208#220208
http://forums.matronics.com//files/snow_ Archive Search & Download C 7-Day Browse C Chat C FAQ C
Send e-mail anywhere. No map C no compass. Get your Hotmail® account now.
akflyer
Posted: Fri Dec 19, 2008 6:16 pm Post subject: Re: Lovely snow...damned snow! Off topic |
| Lynn Matteson wrote: | We're supposed to get between 11" and 24" on the ground before
Lynn Matteson
Sensenich 62x46
system;
Lynn,
What tig unit do you have? are you using 1/16th or 1/8 tungsten? do you have a foot pedal, or better yet a thumb wheel to control the heat? If you are using 1/8" it is a bit trickier to run without burning through. Keep the tungsten VERY sharp. if you dip your wick, sand it sharp again. The easiest way it to put it in the cordless drill, spin it up and hold it against a belt or disk sander very lightly.
feeding the rod is the biggest issue most people have. They make a wire "pen" that has a little roller wheel on it to feed the wire if you dont have the thumb / pointer finger trained to feed the wire.
Keep the tungsten protrusion limited and use a small cup. Most of the time I bet my tungsten only sticks out 1/32 to maybe 1/16th from the cup.
For the airframe welding I use my buddies Miller econo tig unit and it works great, but the thumb wheel addition was a must. He originally had a foot pedal, but most time with planes you find yourself in a position that the foot pedal is un-accesible.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Fri Dec 19, 2008 7:45 pm Post subject: Lovely snow...damned snow! Off topic |
They probably wouldn't be large enough...or were you just kidding?
Lynn Matteson
Sensenich 62x46
system;
On Dec 19, 2008, at 6:39 PM, Tom Jones wrote:
Lynn,
Tom Jones
Classic IV
Ellensburg, WA
N369LM |
Lynn Matteson
I flew to my CFI' s house yesterday to do some work (I'm installing a
"Y"-shaped 150 control column in place of his 172 Cessna's "T"-shaped
control column, which requires lengthening the Y by about 5/8"...the
reason? Radio clearance in the center stack), and after a bit it
started to BR, so he suggested that I take it home or put it in his
hangar. I opted for the trip home...about 6 miles....in less than
ideal conditions. Made it fine. A half-hour later it was sun-shining
conditions. I flew later on for about an hour before it was time to
put it away. I went to some grass strips locally that I haven't been
into for a while. It was pretty flat lighting early on in the day,
and very hard to interpret the landing. I flew back over my CFI's
house and there was another plane...a Cub...on the ground with skis.
I landed and shot the breeze, then the other plane and I both left.
Pretty cool...both my CFI and this other guy are captains for AA
and..can't recall the other guy's airline...and both own and play
around (A&P/IA's) with small and large (Widgeons) planes in their
spare time. I'm lucky to be getting time to spend with this crowd and
getting the education that I am...damn! wish I was younger.
Did the blades break right away?...crack?
Lynn Matteson
Sensenich 62x46
system;
On Dec 19, 2008, at 8:10 PM, Jim_and_Lucy Chuk wrote:
| Quote: | I've had my plane on skis for almost 2 weeks, Flew about 3 hours
something to complain about. LOL. Take care, Jim Chuk Avid MK
IV Mn
> From: nahsikhs(at)elltel.net
> Date: Fri, 19 Dec 2008 15:39:50 -0800
> Lynn,
> Tom Jones
> Classic IV
> 503 Rotax, 72 inch Two blade Warp
> Ellensburg, WA
> http://forums.matronics.com/viewtopic.php?p 20208#220208
Download, 7-Day Browse, Chat, FAQ,
Send e-mail anywhere. No map, no compass. Get your Hotmail® account
N369LM |
Lynn Matteson
Posted: Fri Dec 19, 2008 8:23 pm Post subject: Lovely snow...damned snow! Off topic |
I'm using 1/16" right now, but just picked up some .040" ceriated
tungsten (suggested for aluminum), smaller cup, collets, and collet
bodies. I have the Miller Diversion 165 TIG machine...got it about 2
weeks ago, and I'm having trouble getting used to using the built-in
thumb wheel to control the amperage, so I ordered and got the foot
pedal. It's a lot easier now to control amperage, and now I can
concentrate on playing the torch correctly. Once I get the proper
torch action, and can consistently make good welds, I'll unplug the
foot control and try again using the thumb wheel for amp control.
It's hard for me...a fairly accomplished gas welder...to hold the TIG
torch, play it, and control the amps at the same time. Dipping the
rod into the puddle is kinda new, too. I'm used to melting the rod
with a gas torch, drop it in the puddle, and melting it in, and this
isn't the way the TIG instructions say to do it....practice continues.
I would have thought that a longer stick-out would be better...I'm
using 3/16" to 1/4"...according to the instructions. I'll try less
and see how that goes. Once I get the hang of the right stick-out,
amperage, torch action, torch angle, rod angle, and speed, I'll try
using the thumb wheel amp control again.
You say there's a rod or wire feeder? Does this attach to the torch,
or is it used with the other hand?
Regarding sharp tungstens....I got a little jar of sharpening
"crystals"...you get the tungsten hot and dip it into the jar,
rotating the torch, and shake off what adheres to the tungsten...it's
amazing, but it works...very pointed tungsten. Won't work for welding
aluminum though...makes it too sharp, according...again...to the
instructions, which call for a blunt tungsten for aluminum.
Geez, they just gave the weather forecast for lower Michigan....
11"-26" of snow on the ground by Monday, single-digits and sub-zero
wind chills for Sunday. That would be a warm forecast for Alaska, eh,
Leonard?
Lynn Matteson
Sensenich 62x46
system;
On Dec 19, 2008, at 9:16 PM, akflyer wrote:
> Lynn Matteson
> Sensenich 62x46
> system;
> do not archive
Lynn,
from the cup.
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
As done as any plane will ever be.... cause now the tinkeritis
takes over.
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 20233#220233
N369LM |
Posted: Fri Dec 19, 2008 9:01 pm Post subject: Lovely snow...damned snow! Off topic |
Hi Lynn C After I landed C I taxied into about 3" of slush that I didn't see under about 10" of snow. When the slush hit the prop C it chipped off some of the thin trailing edge off of one blade. I was at a fast idle when it happened and as things started shaking I shut down right away. At any rate it kind of ruined that day. Stay out of the slush! Take care C Jim Chuk Avid MK IV Mn
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 596+ hrs
Sensenich 62x46
flying again after rebuild C and new Electroair direct-fire ignition
system;
> IV Mn
> > Lynn C
> > Tom Jones
> > Classic IV
> > Ellensburg C WA
> > Read this topic online here:
> ========== _-
You live life online. So we put t/01/' target='_new'>Learn more about Windows Live
akflyer
Posted: Fri Dec 19, 2008 9:11 pm Post subject: Re: Lovely snow...damned snow! Off topic |
http://products.esab.com/Templates/T041.asp?id=93098
It is called a tig pen, to help feed the wire if your having trouble with it. If you are good at gas welding then feeding the wire should not be an issue for you. I have never seen the "crystals" for sharpening tungsten. gonna have to check into those! I am guessing it just removes the steel that you have melted onto the tungsten and does not actually sharpen it if you stick the tip and break it off.. worth checking into.
Naw, you guys have been having colder winters than we have for the last few years. Here at work we hit 65 below ambient a few times last year, but I think it never got more than 25 below at the house for more than a few days. It got to -5 the other night at home. it is 30 above now and freezing rain....
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
akflyer
Posted: Fri Dec 19, 2008 9:14 pm Post subject: Re: Lovely snow...damned snow! Off topic |
[quote="thesupe(at)hotmail.com"]Hi Lynn C� After I landed C I taxied into�about 3" of �slush that I didn't see under about 10" of snow.� When the slush hit the prop C it chipped off some of the thin trailing edge off of one blade.� I was at a fast idle�when it happened and as things started shaking I shut down right away.� At any rate it kind of ruined that day.� Stay out of the slush!� Take care C� Jim Chuk�� Avid MK IV� Mn
When landing on a lake, you should come in and "drag" it. be like a wheel landing. After "dragging" a set of track, go around and take a look at them from the air. If the tracks are grey it is cause they are filling with water from the over flow. Find another place to land.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Posted: Sat Dec 20, 2008 5:54 am Post subject: Lovely snow...damned snow! Off topic |
You are so right Leni C and actually where I landed it was okey C but I got into trouble after I landed and was taxieng to another part of the lake. I also watch for fresh snowmobile tracks to see if they are filling with water from there being slush. Take care C Jim Chuk Avid MK IV Mn
[quote] Subject: Re: Lovely snow...damned snow! Off topic
Date: Fri C 19 Dec 2008 21:14:14 -0800
--> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com>
When landing on a lake C you should come in and "drag" it. be like a wheel landing. After "dragging" a set of track C go around and take a look at them from the air. If the tracks are grey it is cause they are filling with water from the over flow. Find another place to land.
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
As done as any plane will ever be.... cause now the tinkeritis takes over.
http://forums.matronics.com/viewtopic.php?p=220253#220253
Send e-mail faster without improving your typing skills. Get your Hotmail® account.
Lynn Matteson
Posted: Sat Dec 20, 2008 7:27 am Post subject: Lovely snow...damned snow! Off topic |
That looks pretty slick...I'll look into it further. Thanks for the
website.
The product for sharpening tungsten electrodes is called
"Chemsharp...tungsten electrode sharpener", made in USA, by Dynaflux,
Inc., out of Cartersville, Georgia, 30120, USA. Another name on the
label is ULTRAbrand. A 5 oz jar was about $14. You let about 1" of
tungsten stick out and touch it to the ground until it glows cherry
red about 3/8" up from the tip, then quickly immerse approx. 1/4"
deep into the product repeatedly until the desired point is formed.
It really points the tungsten, much more than the 2 1/2 times the
electrode diameter that my instructions for the welder call for. I
haven't tried it yet when welding aluminum, as my instructions call
Lynn Matteson
Sensenich 62x46
system;
On Dec 20, 2008, at 12:11 AM, akflyer wrote:
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
takes over.
http://forums.matronics.com/viewtopic.php?p 20252#220252
N369LM |
Guy Buchanan
Posted: Sat Dec 20, 2008 8:40 am Post subject: Lovely snow...damned snow! Off topic |
At 06:16 PM 12/19/2008, you wrote:
| Quote: | | What tig unit do you have? are you using 1/16th or 1/8 tungsten? do you have a foot pedal, or better yet a thumb wheel to control the heat? If you are using 1/8" it is a bit trickier to run without burning through. Keep the tungsten VERY sharp. if you dip your wick, sand it sharp again. The easiest way it to put it in the cordless drill, spin it up and hold it against a belt or disk sander very lightly. |
HOLD ON THERE LEONARD! (LOL) How about a subject change. Things are getting kind of loosy-goosy in the subject category and it makes for lousy archives. I appreciate a minor digression, but some of these threads are taking on a life of their own.
Guidelines: How about this: If you think someone might reply to your digression, it should have another subject. If you think A LOT of people might reply, it should definitely have another subject.
Thanks all!
Guy Buchanan - Kitfox List Moderator
San Diego, CA
K-IV/1200 w/ 582 C-box & Warp 3 blade
100% and flying thanks mostly to Bob Ducar [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Sat Dec 20, 2008 3:24 pm Post subject: Lovely snow...damned snow! Off topic |
Good advice, Jim. I got a 20-minute flight in today after the
driveway into the hangar was cleaned of about 10" of snow. The
takeoff was sluggish, but finally, just as I was about to abort, it
lifted off. Landed at Napoleon Field (3NP), where the snowmobiles (I
hate those damn things) had carved up 9-27 pretty good. I landed
where they hadn't made tracks, and it was smo-o-o-th. Taxiing back,
the going was again sluggish, so I steered into those s'mobile tracks
and speed picked up. Turned and took off, using their tracks for a
less friction takeoff...I hate them a little less now. But come thaw
time, and I have to land in frozen ruts (maybe some of my own) I'll
hate 'em again. : )
I can't wait until I get my new ones built, because the friction will
be much less, and taxiing and takeoffs will benefit.
Lynn Matteson
Sensenich 62x46
system;
On Dec 20, 2008, at 12:00 AM, Jim_and_Lucy Chuk wrote:
| Quote: | Hi Lynn, After I landed, I taxied into about 3" of slush that I
didn't see under about 10" of snow. When the slush hit the prop,
Stay out of the slush! Take care, Jim Chuk Avid MK IV Mn
> Lynn Matteson
> Sensenich 62x46
> system;
> do not archive
> > IV Mn
> > > Lynn,
> > > Tom Jones
> > > Classic IV
> > > Ellensburg, WA
account
> > ========== _-
about Windows Live_-
N369LM |
Lynn Matteson
Posted: Sat Dec 20, 2008 3:25 pm Post subject: Lovely snow...damned snow! Off topic |
I'll shoulder some of the blame for the welding topic...sorry.
Lynn Matteson
Sensenich 62x46
system;
Thanks all!
San Diego, CA
N369LM |
Posted: Sat Dec 20, 2008 7:35 pm Post subject: Lovely snow...damned snow! Off topic |
Tom C That's not funny. Deke Morrisse in MI built his out of the plastic skins from Artic Cat used on their snow machines. I bought a set of skins and will have them on mine next year. They aren't real big so you need packed snow I would imagine. How about that Deke? Those snow machine skies you designed won't work in deep snow C or will they?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Lynn Matteson
Posted: Sat Dec 20, 2008 8:08 pm Post subject: Lovely snow...damned snow! Off topic |
Deke and Pat-
How wide and long are these "skins"? What is the area of each ski
(length in inches, multiplied by the width in inches)? Like Leonard
Perry pointed out the other day, you need all the area you can get in
soft powder snow (or words to that effect).
Maybe skis could be added to that list of useless things in aviation:
Fuel left back at the hangar.....altitude above you....runway behind
you.....(can't think of the others)...and wider skis left on the
drawing table.
I had a heck of a time getting out of 10" of snow today, and earlier
this year from about 9" of snow. Granted, my skis are wheel-
penetration skis, and I have re-thought the design, but it seems to
make sense to have all the area you can get...I think.
Lynn Matteson
Sensenich 62x46
system;
On Dec 20, 2008, at 10:34 PM, patrick reilly wrote:
| Quote: | Tom, That's not funny. Deke Morrisse in MI built his out of the
snow, or will they?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Lynn,
> Tom Jones
> Classic IV
> Ellensburg, WA
> http://forums.matronics.com//files/snow_trees_card_202.jpg
N369LM |
akflyer
Posted: Sat Dec 20, 2008 8:13 pm Post subject: Re: Lovely snow...damned snow! Off topic |
There is NO WAY the skis from a sled, unless it was from an old twin track alpine (and that would be marginal), will hold the KF up on anything but very hard packed snow or ice. They wont even hold up my sled in powder. If you try landing in 12" of powder you are going straight to he bottom.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
