pdn8r(at)yahoo.com Guest
Posted: Wed Dec 17, 2008 3:38 pm Post subject: Corvair Block Question |
Sorry thought I changed the subject line
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
--- On Wed, 12/17/08, Bill Pagan <pdn8r(at)yahoo.com> wrote:
| Quote: | From: Bill Pagan <pdn8r(at)yahoo.com>
Subject: Re: Re: Simple rivet test/unzip
Date: Wednesday, December 17, 2008, 6:17 PM
Picked up another Corvair block and it is different than the one I already have. Can someone tell me what the hole below the lifters are in the attached photo?
296.05 KB |
633 Time(s) |
Brady
Posted: Fri Dec 19, 2008 9:59 am Post subject: Re: Corvair Block Question |
Bill,
As Roy said on the other list, "it's an oil fill" but rather than plug it, why not just use it as your oil fill? you're going to need one any way.
It's on the correct side and it will allow you to avoid modifying you valve cover.
If you can make it work out for you it might be an advantage.
Just a thought?
_________________ Brady McCormick
Poulsbo, WA
www.magnificentmachine.com |
