Rotax Engine Technicians
hgmckay
PostPosted: Tue Dec 16, 2008 7:28 am    Post subject: Rotax Engine Technicians Reply with quote
Why can I not find an authorized Rotax engine technician listed any where in the US? I went to the Rotax-owners.com site and clicked on the tab for support, and under that tab is a list of items, one of which is “find a technician”. When you follow that trail I cannot find a technician listed in any of the US states. Why is this? Certainly there must be some Rotax engine authorized technicians in the US!!
Have I just made a mistake or am I correct in my finding?
Hugh McKay
Rotax 912 UL
arno7452(at)bellsouth.net
PostPosted: Tue Dec 16, 2008 7:41 am    Post subject: Rotax Engine Technicians Reply with quote
Hugh,
Are you aware of Lockwood near Lakeland, FL? They are distributor and seller of Rotax.
Ken Arnold
hgmckay
PostPosted: Tue Dec 16, 2008 8:11 am    Post subject: Rotax Engine Technicians Reply with quote
Ken:
Yes, I am aware of them and their services. What I am asking is, does Lockwood have the only qualified Rotax technicians in the US?
Hugh
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Ken Arnold
Sent: Tuesday, December 16, 2008 10:41 AM
Subject: Re: RotaxEngines-List: Rotax Engine Technicians
Hugh,
Ken Arnold
Arty Trost
PostPosted: Tue Dec 16, 2008 8:21 am    Post subject: Rotax Engine Technicians Reply with quote
There certainly ARE authorized Rotax engine technicians throughout the U.S. I believe LEAF is one, as well as Lockwood. Clyde Poser of Rainier Ultralight (in Washington - state, not D.C.) is another. Also check with Rainbow Aviation in Corning, Calif.If they're not (and I believe they are) they will certainly know of other authorized Rotax engine technicians.
Arty Trost
Rotax 503
Sandy, Oregon
PostPosted: Tue Dec 16, 2008 10:53 am    Post subject: Rotax Engine Technicians Reply with quote
Hugh,
We have a Rotax tech here in Goldsboro. However, he is only qualified to remove and install external parts. He cannot open the case. As I understand, he can balance carbs and such. I have used him a little but nothing very complex.
Good luck,
Ken
JOE RONCO
PostPosted: Tue Dec 16, 2008 1:36 pm    Post subject: Rotax Engine Technicians Reply with quote
Try:
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated Rotax Service Center 520-574-1080
Roger Lee (ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com))
Hope this helps.
Joe R
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of hgmckay(at)bellsouth.net
Sent: Tuesday, December 16, 2008 8:28 AM
To: 'Rotax Engines'
Subject: Rotax Engine Technicians
Hugh McKay
Rotax 912 UL
Venu Rao
PostPosted: Tue Dec 16, 2008 1:45 pm    Post subject: Rotax Engine Technicians Reply with quote
Anyone Rotax technicians in Texas/Central TexasThanks,
Venu
Austin, TX
On Dec 16, 2008, at 3:35 PM, Joe Ronco wrote:
Try:
Roger Lee
Tucson, Az.
Hope this helps.
Joe R
From: owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com) [mailto:owner-rotaxengines-list-server(at)matronics.com (owner-rotaxengines-list-server(at)matronics.com)] On Behalf Of hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
To: 'Rotax Engines'
Hugh McKay
Rotax 912 UL
Venu Rao
Austin, TX
Europa Mono
Builder: Jim Nelson
TTAE 119.1 hrs
Roger Lee
PostPosted: Tue Dec 16, 2008 4:05 pm    Post subject: Re: Rotax Engine Technicians Reply with quote
Hi Guys,
I see Joe listed my name. Thanks, Joe.
I'm here in Tucson, Az if you need anything.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Cell 520-349-7056
bob(at)fly-ul.com
PostPosted: Wed Dec 17, 2008 7:48 am    Post subject: Rotax Engine Technicians Reply with quote
I've been on travel, and just now catching up on e-mails. My apologies if someone else already posted the answer. You'll find the list of Rotax techs, here: http://www.rotaxflyingclub.com/global/repaircentre.htm
I'm not sure why Rotax-Owner doesn't keep their site up to date Sad
Bob Comperini
e-mail: bob(at)fly-ul.com
WWW: http://www.fly-ul.com
Cmflyboy12(at)aol.com
PostPosted: Wed Dec 17, 2008 4:11 pm    Post subject: Rotax Engine Technicians Reply with quote
can i use 100L fuel in my 582 2 stroke rotax
One site keeps you connected to all your email: AOL Mail, Gmail,40vanity&ncid=emlcntaolcom00000025">Try it now.
Roger Lee
PostPosted: Thu Dec 18, 2008 7:29 am    Post subject: Re: Rotax Engine Technicians Reply with quote
You should not use 100LL in your 2 stroke. Stay with auto fuel.
Roger Lee
Tucson, Az.
Cell 520-349-7056
matronics(at)bob.brennan.
PostPosted: Thu Dec 18, 2008 7:56 am    Post subject: Rotax Engine Technicians Reply with quote
Roger, shouldn't that be - you should *try* to use auto fuel wherever
possible, at least the octane level recommended for your engine (my 582 is
91 octane), and with as little and preferably no ethanol, and never above
10% tested. If not possible use 100LL with an additive such as Decalin. And
make sure everything in your fuel delivery system is ethanol tolerant.
We all know auto gas without ethanol is nearly impossible to find in most
areas now, and you would be hard-pressed to find an FBO on a cross-country
that sells mogas. The airport directory for Pennsylvania lists 1 airport in
the whole state that sells mogas.
I bow to your expertise as a Rotax repairman - but in the real world are my
recommendations above the best one can go by? Always willing to learn!
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
Roger Lee
PostPosted: Thu Dec 18, 2008 9:42 am    Post subject: 100LL in 2 Strokes Reply with quote
Hi Bob,
Here is a page out of the 2 Stroke Operators Manual. This is taught in the Rotax classes, too.
Bob your right in your statements. "Try" is the operative word, but try hard.
You should avoid using 100LL in 2 strokes if at all possible. They were never really designed to handle the lead like the 4 strokes. It is more likely to gum up the rings for one. That said I would try very hard to stay away from 100LL in the 912's also if possible. I hate lead build up. If you had to use it because you are out of fuel somewhere then an emergency fuel use would certainly take precedence. Using 100LL in your 2 stroke all the time will cause more maint and possibly premature engine rebuild.
I know the engine seems to run fine because 100LL is fuel, but the darn lead causes issues. You are right that if you get stuck using 100LL then a fuel additive like Decalin should be used to help with the lead scavenging. If you plan a cross-country then use some program like AirNav to find the airports that have Mogas. I know that finding these airports are not always feasible, but one should try. In my 912ULS I personally will use 91 octane with ethanol before using 100LL. Most of us aren't flying 2 strokes above 8K-10K MLS to worry about any kind of a vapor lock. If you have an exposed engine verses a fully cowled engine then vapor lock is reduced.
2 Stroke Operators Manual Page.doc
2 Stroke operators Manual page
10-8
 Filename:  2 Stroke Operators Manual Page.doc
 Filesize:  378.5 KB
 Downloaded:  575 Time(s)
Roger Lee
Tucson, Az.
Cell 520-349-7056
pwmac(at)sisna.com
PostPosted: Thu Dec 18, 2008 1:12 pm    Post subject: Rotax Engine Technicians Reply with quote
Roger,
Another point is since 100LL is a lighter fuel, thus more fuel/larger
jetting is required. We all know that lean mixture on a 2 stroke is
not so good. If one had the luxury of EFI then the efi would
compensate, but with carbs re jetting is necessary. The same comment
applies to gas contaminated with alcohol. New jetting is necessary to
avoid lean mixture. This info comes from the auto race guys who use
100LL or E85 in their carb equipped engines high compression engines.
Paul
At 10:42 AM 12/18/2008, you wrote:
Hi Bob,
Here is a page (10-Cool out of the 2 Stroke Operators Manual. This is
possible. If you had to use it because you are out of fuel somewhere
Roger Lee
Tucson, Az.
520-574-1080
http://forums.matronics.com/viewtopic.php?p 19978#219978
http://forums.matronics.com//files/2_stroke_operators_manual_199.pdf
