Electric Rudder Trim
Albert Gardner
PostPosted: Mon Dec 15, 2008 10:35 am    Post subject: Electric Rudder Trim Reply with quote
I am very pleased with the spring bias rudder trim I installed last summer.
It was easy to fabricate, install, and required no modifications to the
rudder. It has adequate range for high attitude climbs and fast descents.
Beats having to hold rudder pressure for long periods of time. I used the
aileron trim servo kit and installed it just behind the baggage bulkhead
against the bottom skin straddling a stiffener. An additional cable connects
to the rudder horn on one side, wraps around a pulley, to the springs at the
servo and back to the rudder horn on the other side. Pictures available to
any who are interested.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
pitts_pilot(at)bellsouth.
PostPosted: Mon Dec 15, 2008 12:14 pm    Post subject: Electric Rudder Trim Reply with quote
I'd love to see pictures! I've modified my -10 so that the rudder
cables hook to the pedals inside the tunnel, and will add a loop to tie
the rudder pedals together. The trim is the only thing left!
Linn
Albert Gardner
Yuma, AZ
rv(at)thelefflers.com
PostPosted: Mon Dec 15, 2008 12:35 pm    Post subject: Electric Rudder Trim Reply with quote
You're going to get numerous requests, so please post pictures, parts lists, and instructions.
Inquiring minds want to know......
thansk,
bob
Date: 2008/12/15 Mon PM 03:13:00 EST
Subject: Re: Electric Rudder Trim
Linn
> Albert Gardner
> Yuma, AZ
jcumins(at)jcis.net
PostPosted: Mon Dec 15, 2008 3:05 pm    Post subject: Electric Rudder Trim Reply with quote
Albert
Please send me pics I am very interested in this.
Send them off list if you like.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
jcumins(at)jcis.net
PostPosted: Mon Dec 15, 2008 3:06 pm    Post subject: Electric Rudder Trim Reply with quote
Linn can you send me pics how you connected the rudder pedals in the tunnel
I very much want to do that on my 10.
thanks
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
PostPosted: Mon Dec 15, 2008 9:16 pm    Post subject: Electric Rudder Trim Reply with quote
I'll try!!!
Linn
thanks
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
PostPosted: Mon Dec 15, 2008 9:25 pm    Post subject: Electric Rudder Trim Reply with quote
Lemme try again!!! Smile
linn Walters wrote:
I'll try!!!
Linn
> tunnel
> thanks
> John G. Cumins
 Filesize:  169.72 KB
 Viewed:  319 Time(s)
 Filesize:  182.35 KB
 Viewed:  356 Time(s)
Albert Gardner
PostPosted: Tue Dec 16, 2008 12:36 am    Post subject: Electric Rudder Trim Reply with quote
I had a lot of requests for pics so I'll post this to the list.
I used the same servo kit that we use in the wing for aileron trim, servo,
springs, assembly etc. I left a 12" gap in the cables for springs just like
in the aileron setup and that seems to produce adequate trim.
The pulley is a 3" dia for 3/32" cable. I put a keeper over the pulley so
the cable couldn't come off but I think it is redundant.
The bracket holding the pulley sits on top of F-1035 and under the elevator
servo mounting bracket see page 10-24 fig 1. I bent a flange on the sides to
make it stiffer.
I installed the pulley bracket and then assembled the MAC servo kit. The
servo and bracket are mounted about midway between the bulkheads and
straddling a stiffener using 4 flat head screws up through the bottom skin.
I used 3/32 7x19 s/s cable with MS20668 Eye Ends. At the rudder horn I used
a longer AN3 bolt and attached the trim cable below the original rudder
cable.
This was actually very easy to install especially if you had thought ahead
and the 5 wire cable was already in place. The dual cables at the rudder
horn aren't too nice but I didn't want to clamp onto the rudder cables
inside the tail cone for some reason. The new cables line up well with the
snap bushings and the original rudder cables. You can easily over-ride the
trim should it be necessary.
Albert Gardner
Yuma, AZ
 Filesize:  25.59 KB
 Viewed:  348 Time(s)
 Filesize:  41.37 KB
 Viewed:  327 Time(s)
 Filesize:  36.6 KB
 Viewed:  309 Time(s)
 Filesize:  20.17 KB
 Viewed:  324 Time(s)
 Filesize:  32.84 KB
 Viewed:  342 Time(s)
 Filesize:  19.75 KB
 Viewed:  328 Time(s)
 Filesize:  35.17 KB
 Viewed:  333 Time(s)
 Filesize:  38.96 KB
 Viewed:  329 Time(s)
 Filesize:  30.55 KB
 Viewed:  347 Time(s)
RV-9A N872RV
RV-10 N991RV
