Strobe and E.I. UGB-16 Issue
cbrxxdrv(at)aol.com
PostPosted: Mon Dec 15, 2008 2:47 pm    Post subject: Strobe and E.I. UGB-16 Issue Reply with quote
I am posting this for a friend.....He can not send, only receive e-mails.
" I'm having a problem with Whelen strobe interference on my E.I. UGB-16 engine analyzer showing up on number two cylinder. The display and bar graph jump between 190 and -300 deg F. When I turn off the strobes the problem disappears. The 2 power packs are mounted on the wingtips and are on a separate breakers for the E.I. and strobes. The interference causes the E.I. to trip its 5 amp breaker taking along the engine instruments and flap circuit with it.
If after checking all the T/C connections from number 2 I still have problems can anyone suggest any ideas ?
Doug Gardner RV-8A N456DG 101 hrs
Palm Harbor/Lakeland Fl
Douglas P. Gardner
Fireye Regional Sales Manager/Southeast
Palm Harbor, Florida 34683
(727) 784-2600 Fax (727) 785-4767
Email : seabearfl(at)netzero.com (seabearfl(at)netzero.com)
Listen to 350+ music, sports, & news radio stations – including songs for the holidays – FREE while you browse. Start Listening Now!
rv8a2001(at)yahoo.com
PostPosted: Mon Dec 15, 2008 3:39 pm    Post subject: Strobe and E.I. UGB-16 Issue Reply with quote
Off the top of my head..........
Do not run any wires that supply power near a wire used for an instrument reading.
For example on my firewall I have power wires going through in one area and wires used for sensors in another area seperated by about 2 feet.
I am guesing that somewhere along the way the strobe wires are to close to other non-power wires.......?
Scott RV-8a
To: rv-list(at)matronics.com
Sent: Monday, December 15, 2008 2:45:08 PM
Subject: Strobe and E.I. UGB-16 Issue
Douglas P. Gardner
cbrxxdrv(at)aol.com
PostPosted: Mon Dec 15, 2008 6:50 pm    Post subject: Strobe and E.I. UGB-16 Issue Reply with quote
I will say this for him......it was fine for the first 100 hours ??
I am gonna take a look at it this weekend with him but will take all suggestions Smile
Sal
Kellym
PostPosted: Mon Dec 15, 2008 7:16 pm    Post subject: Strobe and E.I. UGB-16 Issue Reply with quote
Interesting. I have a similar issue with #2 EGT only on same system.
Sometimes it is fine, othertimes it jumps around, occasionally drops off
line. Strobe switch is next to UBG-16 power switch. However this only
developed after 150 hours. Next time it happens will try turning strobes
off.
cbrxxdrv(at)aol.com wrote:
[quote] I will say this for him.......it was fine for the first 100 hours ??
suggestions Smile
Sal
Kelly McMullen
KCHD
