Choke Cable Splitter for Rotax 912 UL
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
hgmckay
PostPosted: Mon Dec 29, 2008 7:05 am    Post subject: Choke Cable Splitter for Rotax 912 UL Reply with quote
On my E-LSA Allegro 2000 with a Rotax 912 UL engine the choke for the two
carburetors uses a plastic tube type cable splitter that is permanently
mounted through the fire wall. I need to replace the cable that goes from
the splitter to the left carburetor. To do this I need to open the splitter
and pull the cable back through it to remove the cable. The Allegro assembly
manual showing this splitter shows only a photograph of the splitter and the
three cable connections on the splitter itself before it is inserted into
the plastic tube. It has been three years since I assembled this splitter
and I cannot remember if it can be disassembled or not. Since the tube and
its internal assembly are permanently mounted through the fire wall with
JBWeld, I cannot take the full assembly out. Is there anyone out there that
has recently built an E-LSA Allegro 2000 using this carburetor splitter that
remembers how it went together and how to disassemble it?
Hugh McKay
Allegro 2000
Rotax 912UL
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
hans.norring(at)vip.cyber
PostPosted: Mon Dec 29, 2008 8:32 am    Post subject: Choke Cable Splitter for Rotax 912 UL Reply with quote
Hi Hugh
My experiance is that the splitter is a temp-installation, after a periode
of about 3 years the plastic attachment that move in the tube gets bigger,
and thereby get stuck, that will give a real funny engine sound when u go to
idle ( landing situation )it nearly get the engine to stop, all because of
having choker on, so get rid of this hopeless arrangement, we are 3 allegro
2000 here in denmark that had that problem, and it was not possible for us
to get it open, so my suggestion is to buy a similar 2 to 1 cabel
arrangement from aircraftspruce, its made by alu and a brass assambly, the
only bad thing is that the diameter is smaller than the original, so there u
need to be creative.
Hans Norring
OY-9259
Denmark
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
