riffeljl(at)gmail.com Guest
Posted: Wed Dec 10, 2008 6:38 pm Post subject: 1st Flight Test Plan? |
I'd appreciate any constructive input on my plan for my 1st Flight:
____________________
Ground -
Equipment: -
Fire extinguisher -
Hatchet -
Knife -
Gloves -
Phillips screwdriver -
monitor freq: 122.85 -
Record Launch Time: __________________________________ -
Prompt/record:
Elapsed
Oil Press
Oil Temp
EGT1
EGT2
EGT3
EGT4
CHT1
CHT2
CHT3
CHT4
2 min
5 min
10 min
15 min
20 min
25 min
30 min
IF CHT => 400°F, advise LANDING -
30 Minutes -
Prompt for -
RPM: ______________ -
MAP: ______________ -
AIRSPEED: _________ -
Remind to LAND -
Record Landing Time: _______________ -
IF CRASH: -
Dial 911 & give location -
Save Pilot – aircraft is secondary -
Gloves, knife, hatchet, Fire Extinguisher -
Canopy latch rotates CLOCKWISE to OPEN -
MASTER OFF (lower left panel) -
Fuel Selector: (center, front of spar) -
OFF (aft left) -
Seat belts: PULL FLAP -
Shoulder Harness: PULL TABS to LOOSEN -
Cowl: -
Oil Door for top cowl hinge wires on firewall -
Phillips screwdriver for hinge wires on cowl halves -
Battery located on pilot side firewall -
Chase -
Monitor 122.85 -
Com check: Ground/TestFlight -
Depart first; take station EAST of runway -
Take up ½ mile trail -
Check Fluids/Flapping Parts -
If TestFlight rocks wings: -
Come up on right wing till TestFlight acknowledges -
Fly under to left wing, then over top to right wing -
Signal TestFlight: -
OK: Thumbsup -
Problems: cut Throat to land -
Emergencies: -
Com Failure: -
Come up on right wing -
Point to Ears -
Parts/Fluid/fire: -
Cut Throat to indicate landing -
Remind pilot: -
Master Off -
FUEL OFF -
Canopy Unlatched – but closed -
Crash: -
Tell Ground location -
Circle till Ground arrives -
TestFlight -
Equipment: -
Fire extinguisher -
Hatchet -
Knife -
Com: 122.85 -
Com Check: Ground/Chase -
Ensure EIS configuration set for oil temp -
Retest Brakes on taxi/runup -
Depart after Chase -
TAKEOFF: -
FULL POWER, FULL RICH (lean only to smooth engine) -
70-75% power -
3000', 2400/24" -
Verify Airspeed registering -
Boost Pump Off -
Orbit, traffic pattern direction, ½ mile radius of airport -
IF CHT => 400°F, LAND -
Tasks -
Straight & Level: -
Both trims in neutral -
Record vsi/roll: _____________________________________________________ -
Adjust for level -
Tell Ground OilT/P, EGTs, CHTs -
Check w/ Chase that area is clear -
Stall -
Slow to mushy controls/buffet -
Airspeed: _________ -
Check: OilT/P, EGTs, CHTs -
Flaps: 20% (two marks) -
Flaps: FULL -
Airspeed Check: -
Setup Airspeed to 120 kts -
Call Chase to right side -
Compare airspeeds with Chase -
Land -
Downwind: 1.5 times clean stall (80-90 kts?) -
Base: 20° flaps -
Stay on mains if possible -
Signals: -
Ears: com failure -
Cut Throat: Land -
Rock Wings: Chase come up to look over TestFlight
HCRV6(at)comcast.net Guest
Posted: Wed Dec 10, 2008 8:00 pm Post subject: 1st Flight Test Plan? |
In my experience if your engine is new or newly overhauled your 400 Deg limit for CHT on the first flight is overly conservative. On my first flight with a new O-360 from Van's the CHT's, which now approach 400 deg only in a hot day full power climb at near gross, went over 400 deg on the initial climb out. Since Lycoming sets 450 deg as the NTE if I recall correctly, you can safely use that temp as your limit. Just my opinion.
Harry Crosby
RV-6 N16CX, 530 hours
Kellym
Posted: Wed Dec 10, 2008 8:17 pm Post subject: 1st Flight Test Plan? |
IMHO, 400 degrees should be a take action point, either add airspeed, fuel or reduce power, as appropriate to the situation. I would use 425 as a never exceed limit, as metal deformation can occur above that. Lycoming's numbers are WAY too hot if you want your cylinders and rings to survive. This time of year there shouldn't be any problem staying below 400. Initial climb out should be as flat and fast as terrain and obstacles permit for max cooling during first high power run.
Kelly McMullen
A&P/IA
Tech Counselor
HCRV6(at)comcast.net (HCRV6(at)comcast.net) wrote: [quote] p { margin: 0; } In my experience if your engine is new or newly overhauled your 400 Deg limit for CHT on the first flight is overly conservative. On my first flight with a new O-360 from Van's the CHT's, which now approach 400 deg only in a hot day full power climb at near gross, went over 400 deg on the initial climb out. Since Lycoming sets 450 deg as the NTE if I recall correctly, you can safely use that temp as your limit. Just my opinion.
Harry Crosby
KCHD |
rv8a2001(at)yahoo.com Guest
Posted: Wed Dec 10, 2008 8:22 pm Post subject: 1st Flight Test Plan? |
My personal opinion, and I know people will disagree....... that is WAY to much to be concerned about on your first flight, you should be doing nothing more than flying the plane and monitoring temps. Scope out off field landing places prior to flight but then again why would you fly further than gliding distance from the field.........
so just fly 2o minutes, land, check for leaks, celebrate and then ease into the below. I do like the "chase" portion though.
The first flight will be exciting enough with out having a check list a mile long to deal with..........unless of course your a former test pilot.........my comments above are for Joe average pilot.
Scott
RV-8a
To: rv-list <rv-list(at)matronics.com>
Sent: Wednesday, December 10, 2008 6:37:44 PM
Subject: 1st Flight Test Plan?
Ground -
Equipment: -
Fire extinguisher -
Hatchet -
Knife -
Gloves -
Prompt/record:
Elapsed
Oil Press
Oil Temp
EGT1
EGT2
EGT3
EGT4
CHT1
CHT2
CHT3
CHT4
2 min
5 min
10 min
15 min
20 min
25 min
30 min
30 Minutes -
Prompt for -
Remind to LAND -
IF CRASH: -
OFF (aft left) -
Cowl: -
Chase -
Monitor 122.85 -
OK: Thumbsup -
Emergencies: -
Com Failure: -
Point to Ears -
Parts/Fluid/fire: -
Remind pilot: -
Master Off -
FUEL OFF -
Crash: -
TestFlight -
Equipment: -
Fire extinguisher -
Hatchet -
Knife -
Com: 122.85 -
TAKEOFF: -
70-75% power -
3000', 2400/24" -
Boost Pump Off -
Tasks -
Straight & Level: -
Adjust for level -
Stall -
Flaps: FULL -
Airspeed Check: -
Land -
Base: 20° flaps -
Signals: -
Ears: com failure -
Cut Throat: Land -
ronlee(at)pcisys.net Guest
Posted: Wed Dec 10, 2008 8:34 pm Post subject: 1st Flight Test Plan? |
Hopefully someone else will record all that data. Not the test pilot.
Ron Lee
sbuc(at)hiwaay.net Guest
Wow! I've been flying my RV-6 for 900 hrs and don't think I'd have the
presence of mind to punch half the stuff on that list.
Sam Buchanan
http://thervjournal.com
J Riffel wrote:
| Quote: | I'd appreciate any constructive input on my plan for my 1st Flight:
1.
*Ground*
1.
Equipment:
1.
Fire extinguisher
2.
Hatchet
3.
Knife
4.
Gloves
5.
2.
monitor freq: *122.85*
3.
*Record Launch Time: __________________________________*
4.
Prompt/record:
*Elapsed*
*Oil Press*
*Oil Temp*
*EGT1*
*EGT2*
*EGT3*
*EGT4*
*CHT1*
*CHT2*
*CHT3*
*CHT4*
*2 min*
*5 min*
*10 min*
*15 min*
*20 min*
*25 min*
*30 min*
5.
*IF CHT => 400°F, advise LANDING*
6.
*30 Minutes*
1.
Prompt for
1.
RPM: ______________
2.
MAP: ______________
3.
AIRSPEED: _________
2.
Remind to LAND
7.
*Record Landing Time: _______________*
8.
IF CRASH:
1.
2.
*Save Pilot – aircraft is secondary*
3.
4.
Canopy latch rotates *CLOCKWISE* to OPEN
5.
*MASTER OFF (lower left panel)*
6.
*Fuel Selector: (center, front of spar)*
1.
*OFF (aft left)*
7.
Seat belts: P*ULL FLAP*
8.
Shoulder Harness: *PULL TABS* to LOOSEN
9.
Cowl:
1.
2.
10.
2.
*Chase*
1.
Monitor *122.85*
2.
3.
Depart first; take station *EAST *of runway
4.
5.
6.
*If TestFlight rocks wings:*
1.
2.
3.
Signal TestFlight:
1.
OK: Thumbsup
2.
7.
*Emergencies:*
1.
Com Failure:
1.
2.
Point to Ears
2.
Parts/Fluid/fire:
1.
2.
3.
Remind pilot:
1.
*Master Off*
2.
*FUEL OFF*
3.
3.
Crash:
1.
2.
3.
*TestFlight*
1.
Equipment:
1.
Fire extinguisher
2.
Hatchet
3.
Knife
2.
Com:* 122.85*
3.
4.
5.
6.
Depart after Chase
7.
TAKEOFF:
1.
2.
70-75% power
1.
3000', 2400/24"
8.
9.
Boost Pump Off
10.
11.
*IF CHT => 400°F, LAND*
12.
Tasks
1.
Straight & Level:
1.
2.
Record vsi/roll:
3.
Adjust for level
2.
3.
4.
Stall
1.
2.
Airspeed: _________
3.
4.
5.
Airspeed: _________
6.
7.
Flaps: FULL
8.
Airspeed: _________
9.
5.
Airspeed Check:
1.
2.
3.
6.
Land
1.
2.
Base: 20° flaps
3.
13.
*Signals:*
1.
*Ears:* com failure
2.
*Cut Throat:* Land
3.
*Rock Wings:* Chase come up to look over TestFlight
Posted: Wed Dec 10, 2008 8:49 pm Post subject: 1st Flight Test Plan? |
EGT is not very important on the first flight
Ron
timb
Joined: 16 Apr 2008 Posts: 77 Location: Frankston, Texas
Posted: Thu Dec 11, 2008 5:58 am Post subject: 1st Flight Test Plan? |
I completely agree with another post; this is way more than you need to worry about on your first and even the second flight. Focus on how the plane feels, and try some slow flight before landing. Don’t venture too far from the airport, keep it short maybe 15 or 20 minutes and then land and go celebrate. The 25 – 40 hours after this will provide plenty of time to figure out the rest in small chunks. Your complete attention is needed to verify controllability and landing potential on your first flight.
Just my .02 cents worth.
Tim Bryan
RV-6 Flying
N616TB over 120 hours now
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of J Riffel
Sent: Wednesday, December 10, 2008 8:38 PM
To: rv-list
<![if !supportLists]>1. <![endif]>Ground
<![if !supportLists]>1. <![endif]>Equipment:
<![if !supportLists]>1. <![endif]>Fire extinguisher
<![if !supportLists]>2. <![endif]>Hatchet
<![if !supportLists]>3. <![endif]>Knife
<![if !supportLists]>4. <![endif]>Gloves
<![if !supportLists]>5. <![endif]>Phillips screwdriver
<![if !supportLists]>2. <![endif]>monitor freq: 122.85
<![if !supportLists]>3. <![endif]>Record Launch Time: __________________________________
<![if !supportLists]>4. <![endif]>Prompt/record:
Elapsed
Oil Press
Oil Temp
EGT1
EGT2
EGT3
EGT4
CHT1
CHT2
CHT3
CHT4
2 min
5 min
10 min
15 min
20 min
25 min
30 min
<![if !supportLists]>5. <![endif]>IF CHT => 400°F, advise LANDING
<![if !supportLists]>6. <![endif]>30 Minutes
<![if !supportLists]>1. <![endif]>Prompt for
<![if !supportLists]>1. <![endif]>RPM: ______________
<![if !supportLists]>2. <![endif]>MAP: ______________
<![if !supportLists]>3. <![endif]>AIRSPEED: _________
<![if !supportLists]>2. <![endif]>Remind to LAND
<![if !supportLists]>7. <![endif]>Record Landing Time: _______________
<![if !supportLists]>8. <![endif]>IF CRASH:
<![if !supportLists]>1. <![endif]>Dial 911 & give location
<![if !supportLists]>2. <![endif]>Save Pilot – aircraft is secondary
<![if !supportLists]>3. <![endif]>Gloves, knife, hatchet, Fire Extinguisher
<![if !supportLists]>4. <![endif]>Canopy latch rotates CLOCKWISE to OPEN
<![if !supportLists]>5. <![endif]>MASTER OFF (lower left panel)
<![if !supportLists]>6. <![endif]>Fuel Selector: (center, front of spar)
<![if !supportLists]>1. <![endif]>OFF (aft left)
<![if !supportLists]>7. <![endif]>Seat belts: PULL FLAP
<![if !supportLists]>8. <![endif]>Shoulder Harness: PULL TABS to LOOSEN
<![if !supportLists]>9. <![endif]>Cowl:
<![if !supportLists]>1. <![endif]>Oil Door for top cowl hinge wires on firewall
<![if !supportLists]>2. <![endif]>Phillips screwdriver for hinge wires on cowl halves
<![if !supportLists]>10. <![endif]>Battery located on pilot side firewall
<![if !supportLists]>2. <![endif]>Chase
<![if !supportLists]>1. <![endif]>Monitor 122.85
<![if !supportLists]>2. <![endif]>Com check: Ground/TestFlight
<![if !supportLists]>3. <![endif]>Depart first; take station EAST of runway
<![if !supportLists]>4. <![endif]>Take up ½ mile trail
<![if !supportLists]>5. <![endif]>Check Fluids/Flapping Parts
<![if !supportLists]>6. <![endif]>If TestFlight rocks wings:
<![if !supportLists]>1. <![endif]>Come up on right wing till TestFlight acknowledges
<![if !supportLists]>2. <![endif]>Fly under to left wing, then over top to right wing
<![if !supportLists]>3. <![endif]>Signal TestFlight:
<![if !supportLists]>1. <![endif]>OK: Thumbsup
<![if !supportLists]>2. <![endif]>Problems: cut Throat to land
<![if !supportLists]>7. <![endif]>Emergencies:
<![if !supportLists]>1. <![endif]>Com Failure:
<![if !supportLists]>2. <![endif]>Point to Ears
<![if !supportLists]>2. <![endif]>Parts/Fluid/fire:
<![if !supportLists]>2. <![endif]>Cut Throat to indicate landing
<![if !supportLists]>3. <![endif]>Remind pilot:
<![if !supportLists]>1. <![endif]>Master Off
<![if !supportLists]>2. <![endif]>FUEL OFF
<![if !supportLists]>3. <![endif]>Canopy Unlatched – but closed
<![if !supportLists]>3. <![endif]>Crash:
<![if !supportLists]>1. <![endif]>Tell Ground location
<![if !supportLists]>2. <![endif]>Circle till Ground arrives
<![if !supportLists]>3. <![endif]>TestFlight
<![if !supportLists]>2. <![endif]>Com: 122.85
<![if !supportLists]>3. <![endif]>Com Check: Ground/Chase
<![if !supportLists]>4. <![endif]>Ensure EIS configuration set for oil temp
<![if !supportLists]>5. <![endif]>Retest Brakes on taxi/runup
<![if !supportLists]>6. <![endif]>Depart after Chase
<![if !supportLists]>7. <![endif]>TAKEOFF:
<![if !supportLists]>1. <![endif]>FULL POWER, FULL RICH (lean only to smooth engine)
<![if !supportLists]>2. <![endif]>70-75% power
<![if !supportLists]>1. <![endif]>3000', 2400/24"
<![if !supportLists]>8. <![endif]>Verify Airspeed registering
<![if !supportLists]>9. <![endif]>Boost Pump Off
<![if !supportLists]>10. <![endif]>Orbit, traffic pattern direction, ½ mile radius of airport
<![if !supportLists]>11. <![endif]>IF CHT => 400°F, LAND
<![if !supportLists]>12. <![endif]>Tasks
<![if !supportLists]>1. <![endif]>Straight & Level:
<![if !supportLists]>1. <![endif]>Both trims in neutral
<![if !supportLists]>2. <![endif]>Record vsi/roll: _____________________________________________________
<![if !supportLists]>3. <![endif]>Adjust for level
<![if !supportLists]>2. <![endif]>Tell Ground OilT/P, EGTs, CHTs
<![if !supportLists]>3. <![endif]>Check w/ Chase that area is clear
<![if !supportLists]>4. <![endif]>Stall
<![if !supportLists]>1. <![endif]>Slow to mushy controls/buffet
<![if !supportLists]>2. <![endif]>Airspeed: _________
<![if !supportLists]>3. <![endif]>Check: OilT/P, EGTs, CHTs
<![if !supportLists]>4. <![endif]>Flaps: 20% (two marks)
<![if !supportLists]>5. <![endif]>Airspeed: _________
<![if !supportLists]>6. <![endif]>Check: OilT/P, EGTs, CHTs
<![if !supportLists]>7. <![endif]>Flaps: FULL
<![if !supportLists]>8. <![endif]>Airspeed: _________
<![if !supportLists]>9. <![endif]>Check: OilT/P, EGTs, CHTs
<![if !supportLists]>5. <![endif]>Airspeed Check:
<![if !supportLists]>1. <![endif]>Setup Airspeed to 120 kts
<![if !supportLists]>2. <![endif]>Call Chase to right side
<![if !supportLists]>3. <![endif]>Compare airspeeds with Chase
<![if !supportLists]>6. <![endif]>Land
<![if !supportLists]>1. <![endif]>Downwind: 1.5 times clean stall (80-90 kts?)
<![if !supportLists]>2. <![endif]>Base: 20° flaps
<![if !supportLists]>3. <![endif]>Stay on mains if possible
<![if !supportLists]>13. <![endif]>Signals:
<![if !supportLists]>1. <![endif]>Ears: com failure
<![if !supportLists]>2. <![endif]>Cut Throat: Land
<![if !supportLists]>3. <![endif]>Rock Wings: Chase come up to look over TestFlight
| Quote: | | http://www.matronics.com/contribution | 01234567890123
_________________ Tim Bryan
RV-6 Flying
N616TB |
Dale Ensing
Posted: Thu Dec 11, 2008 5:59 am Post subject: 1st Flight Test Plan? |
A system I have used as a Flight Advisor that keeps the test pilot attention on flying the airplane and not trying to read the flight plan and record data:
A person on the ground with handheld radio w/ headset and clip board with the flight plan/check list.The ground person calls out the items. Test pilot checks the insurments/airplane and responds to the ground member. Ground person records the data and flight time.
A preflight briefing between test pilot and ground crew helps all this take place.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Thu Dec 11, 2008 6:34 am Post subject: 1st Flight Test Plan? |
Good advice Tim! My first flight in my Pitts started with a couple dozen
of my friends around the hangar. I was gone for an hour .... because I
think I was too scared to land ..... y'all probably know that the Pitts
has a reputation for doing wild ballet during landing .... but the
landing was a no-brainer. Only a few die-hards remained when I returned
to the hangar, and it was a small celebration. In that hour I don't
think I got the Pitts outside the airport boundary!!! Having learned
from others over the years, a short (15-20 minutes) is long enough to
get the engine operating temps up and to uncover any oil leaks that may
crop up. Becoming comfortable with the amount of control necessary to
control the airplane is probably the biggest variable between planes. I
think we become more 'ham fisted' with the adrenaline rush .... and
there certainly is a big rush ....
Linn
Tim Bryan wrote:
*Tim Bryan*
*RV-6 Flying*
*N616TB over 120 hours now*
lifeofreiley2003(at)yahoo Guest
Posted: Thu Dec 11, 2008 7:41 am Post subject: 1st Flight Test Plan? |
Very well said Tim... And no big crowd necessary!
Darrell
--- On Thu, 12/11/08, Tim Bryan <n616tb(at)btsapps.com> wrote:
| Quote: | From: Tim Bryan <n616tb(at)btsapps.com>
Subject: RE: 1st Flight Test Plan?
To: rv-list(at)matronics.com
Date: Thursday, December 11, 2008, 7:57 AM
you need to
Focus on how the
then land and go
plenty of time to
flight.
Tim Bryan
RV-6 Flying
Riffel
To: rv-list
1st Flight:
1. Ground
1. Equipment:
1. Fire extinguisher
2. Hatchet
3. Knife
4. Gloves
5. Phillips screwdriver
2. monitor freq: 122.85
3. Record Launch Time:
4. Prompt/record:
Elapsed
Oil Press
Oil Temp
EGT1
EGT2
EGT3
EGT4
CHT1
CHT2
CHT3
CHT4
2 min
5 min
10 min
15 min
20 min
25 min
30 min
5. IF CHT => 400°F, advise LANDING
6. 30 Minutes
1. Prompt for
1. RPM: ______________
2. MAP: ______________
3. AIRSPEED: _________
2. Remind to LAND
7. Record Landing Time: _______________
8. IF CRASH:
1. Dial 911 & give location
2. Save Pilot – aircraft is secondary
3. Gloves, knife, hatchet, Fire Extinguisher
4. Canopy latch rotates CLOCKWISE to OPEN
5. MASTER OFF (lower left panel)
6. Fuel Selector: (center, front of spar)
1. OFF (aft left)
7. Seat belts: PULL FLAP
8. Shoulder Harness: PULL TABS to LOOSEN
9. Cowl:
1. Oil Door for top cowl hinge wires on firewall
2. Phillips screwdriver for hinge wires on cowl halves
10. Battery located on pilot side firewall
2. Chase
1. Monitor 122.85
2. Com check: Ground/TestFlight
3. Depart first; take station EAST of runway
4. Take up ½ mile trail
5. Check Fluids/Flapping Parts
6. If TestFlight rocks wings:
1. Come up on right wing till TestFlight acknowledges
2. Fly under to left wing, then over top to right wing
3. Signal TestFlight:
1. OK: Thumbsup
2. Problems: cut Throat to land
7. Emergencies:
1. Com Failure:
2. Point to Ears
2. Parts/Fluid/fire:
2. Cut Throat to indicate landing
3. Remind pilot:
1. Master Off
2. FUEL OFF
3. Canopy Unlatched – but closed
3. Crash:
1. Tell Ground location
2. Circle till Ground arrives
3. TestFlight
1. Equipment:
2. Hatchet
3. Knife
2. Com: 122.85
3. Com Check: Ground/Chase
4. Ensure EIS configuration set for oil temp
5. Retest Brakes on taxi/runup
6. Depart after Chase
7. TAKEOFF:
1. FULL POWER, FULL RICH (lean only to smooth engine)
2. 70-75% power
1. 3000', 2400/24"
8. Verify Airspeed registering
9. Boost Pump Off
10. Orbit, traffic pattern direction, ½ mile radius of
airport
11. IF CHT => 400°F, LAND
12. Tasks
1. Straight & Level:
1. Both trims in neutral
2. Record vsi/roll:
3. Adjust for level
2. Tell Ground OilT/P, EGTs, CHTs
3. Check w/ Chase that area is clear
4. Stall
1. Slow to mushy controls/buffet
2. Airspeed: _________
3. Check: OilT/P, EGTs, CHTs
4. Flaps: 20% (two marks)
5. Airspeed: _________
6. Check: OilT/P, EGTs, CHTs
7. Flaps: FULL
8. Airspeed: _________
9. Check: OilT/P, EGTs, CHTs
5. Airspeed Check:
1. Setup Airspeed to 120 kts
2. Call Chase to right side
3. Compare airspeeds with Chase
6. Land
1. Downwind: 1.5 times clean stall (80-90 kts?)
2. Base: 20° flaps
3. Stay on mains if possible
13. Signals:
1. Ears: com failure
2. Cut Throat: Land
3. Rock Wings: Chase come up to look over TestFlight
craigtxtx(at)yahoo.com Guest
Posted: Thu Dec 11, 2008 8:27 am Post subject: 1st Flight Test Plan? |
I did this about two weeks ago and agree with previous comments. Your total focus needs to be on flying the airplane and monitoring engine performance to the extent you assure that it continues to make noise. Plenty of time to record stuff later. Keep it simple. Keep it short. Stay focused on the airplane. Have fun.
Craig Gallenbach
RV8A N184CG
5 hours
--- On Wed, 12/10/08, J Riffel <riffeljl(at)gmail.com> wrote:
| Quote: | From: J Riffel <riffeljl(at)gmail.com>
To: "rv-list" <rv-list(at)matronics.com>
Date: Wednesday, December 10, 2008, 8:37 PM
Ground
Equipment:
Fire extinguisher
Hatchet
Knife
Gloves
Prompt/record:
Elapsed
Oil Press
Oil Temp
EGT1
EGT2
EGT3
EGT4
CHT1
CHT2
CHT3
CHT4
2 min
5 min
10 min
15 min
20 min
25 min
30 min
30 Minutes
Prompt for
RPM: ______________
MAP: ______________
AIRSPEED: _________
Remind to LAND
IF CRASH:
OFF (aft left)
Cowl:
Chase
Monitor 122.85
Signal TestFlight:
OK: Thumbsup
Emergencies:
Com Failure:
Point to Ears
Parts/Fluid/fire:
Remind pilot:
Master Off
FUEL OFF
Crash:
TestFlight
Equipment:
Fire extinguisher
Hatchet
Knife
Com: 122.85
Depart after Chase
TAKEOFF:
70-75% power
3000', 2400/24"
Boost Pump Off
Tasks
Straight & Level:
Adjust for level
Stall
Airspeed: _________
Airspeed: _________
Flaps: FULL
Airspeed: _________
Airspeed Check:
Land
Base: 20° flaps
Signals:
Ears: com failure
Cut Throat: Land
t=_blank rel=nofollow>http://www.matronics.com/Navigator?RV-List
| [quote][b]
rv9jim(at)juno.com Guest
Posted: Thu Dec 11, 2008 10:06 am Post subject: 1st Flight Test Plan? |
You did not say what type of instrumentation you are using to tell you
the info you want. I have the EIS from Grand Rapids that has limits
(both high and low) set in the unit. If any of these are exceeded, the
"big red light" turns on and tells you what is the offending parameter.
That way, on my first flight, and the rest of them, I could concentrate
on flying the plane. There is enough stress on the pilot for the first
flight with out taking your attention off the flying. CHT's are the
most important thing to watch. I kept my airspeed on take off in the
110K range. This gave me good cooling as well as good visibility. It
also gives you many options if things get sticky. Airspeed is life as
the air force jocks will tell you. The biggest problem will be to loose
the airspeed on downwind. That means that I need to reduce power as soon
as I get to downwind altitude. Tough to do with the slippery RV's. In
thirty seconds you will be ready to turn cross wind and then thirty
seconds later, to down wind. It all happens fast !!!!!!
Jim
Criminal Lawyers - Click here.
http://thirdpartyoffers.juno.com/TGL2141/fc/PnY6rw3dDC4Q87ZKvBGgg4A5PcYwRy849yHbAS7GIRAAEo9AZMtTd/
khorton01(at)rogers.com Guest
Posted: Thu Dec 11, 2008 3:35 pm Post subject: 1st Flight Test Plan? |
Three comments:
1. I'd drop the formation airspeed check. Doing a 120 kt airspeed
check just adds more low power time, which detracts from the engine
break-in, but it doesn't tell you anything that can't wait a few
flights. Take your IAS at the full flap stall, and multiply by about
1.5, and do a very quick controllablity evaluation at that speed. If
it feels good, use that for the initial approach speed. You can work
on dialing that down a bit slower on subsequent flights.
2. I'd restrict the duration to 20 minutes, or less. There are a lot
of things that can be happening ahead of the firewall on the first
flight, and it is best to keep the duration short, and then do a very
detailed inspection before flying again. I know of several RV owners
who had the alternator pulley wear through the cowling on the first
flight. I thought I had enough clearance between the alternator
pulley and the cowling, but apparently the air loads push the lower
cowling aft. I did a 20 minute first flight, and my alternator pulley
put a very deep gouge in the cowling. I think it may have worn all
the way through in 30 minutes. It is a lot easier to fill in a gouge,
that it is to repair it if it comes all the way through. I also had
an issue with heat stress on the throttle cable, as it was too close
to the exhaust.
3. I wouldn't record EGT. It tells you nothing useful. CHTs, oil
temperature and oil pressure should be monitored. Recording them is
optional.
I like the detailed notes on ground items, chase briefing, etc.
Good luck,
Kevin Horton
Ottawa, Canada
