Chelton SV-10
Goto page 1, 2  Next
ichelva(at)netspace.net.a
PostPosted: Thu Mar 23, 2006 8:16 am    Post subject: Chelton SV-10 Reply with quote
Anyone seen the info on Direct to Avionics website about the "new" Chelton SV-10? It appears to be a dual screen setup, with a wiring harness that claims to be complete - ie strobes, autopilot servoes, trim, pitot heat etc. This sounds like a better harness than Van's basic offering.
http://www.d2av.com/pdfs/SV-10.pdf
Indran Chelvanayagam
40228
Finish Kit arrived yesterday - the beginning of the end?
Mani Ravee
PostPosted: Thu Mar 23, 2006 8:41 am    Post subject: Chelton SV-10 Reply with quote
Answer to my prayers. I’m lovin’ it.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Indran Chelvanayagam
Sent: Thursday, March 23, 2006 11:14 AM
Subject: Chelton SV-10
40228
Mani Ravee
#40339
KUMP, Indianapolis
Tim(at)MyRV10.com
PostPosted: Thu Mar 23, 2006 9:40 am    Post subject: Chelton SV-10 Reply with quote
I'm not at all sure of this, but, I think the wiring harness, if it
truly includes pitot heat and all, is just based on Van's standard
wiring harness. I'd actually be a tiny bit discouraged if it included
all the other wiring in that there's WAY too much stuff that builders
will want to customize, and it's not nearly as clean to chop up
a harness in many cases as it is to just make one. For all the AHRS
and interconnect and Chelton related things though, the harness
would be a fantastic add-on.
offering.
40228
LarryRosen
PostPosted: Thu Mar 23, 2006 10:15 am    Post subject: Chelton SV-10 Reply with quote
If someone gets some details on the Chelton wiring harness please share
with the list.
Larry Rosen
> basic offering.
> 40228
Larry Rosen
#40356
N205EN (reserved)
<http>
sam.marlow
PostPosted: Thu Mar 23, 2006 11:14 am    Post subject: Chelton SV-10 Reply with quote
Really unbelievable they would publish the add with a non working phone number! Makes you wonder about the quality of there work!
40228
Tim(at)MyRV10.com
PostPosted: Thu Mar 23, 2006 11:33 am    Post subject: Chelton SV-10 Reply with quote
That's a misprint. The real number is 541-504-8300.
I know they have an outside company print their flyers, so obviously it
required further proofreading. Hope that helps you get to them easier.
> 40228
mike(at)cleavelandtool.co
PostPosted: Thu Mar 23, 2006 11:47 am    Post subject: Chelton SV-10 Reply with quote
It is easier that you can imagine.  We work on our catalog for months and have dozens of people look it over and it is full of little errors every year.
We printed 5000 invoices once with the wrong phone number on them.
We get phone calls everyday from a Harvard Business School ad that they ran 10 years ago with a misprinted phone number (since copied all over the internet in .JPG)
It happens, I just hope they are expert avionics guys and not proofreaders.
Mike Lauritsen
Cleaveland Aircraft Tool
2225 First St.
Boone, Iowa 50036
515-432-6794
mike(at)cleavelandtool.com (mike(at)cleavelandtool.com)
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam Marlow
Sent: Thursday, March 23, 2006 1:13 PM
Subject: Re: Chelton SV-10
40228
ron.mcgann(at)baesystems.
PostPosted: Thu Mar 23, 2006 1:58 pm    Post subject: Chelton SV-10 Reply with quote
Indran and other Ozzie 10 builders.
This product looks truly awesome (esp with the harness), but are we going to see the full value? Does anyone have any insight into the quality of the terrain database we would get?  Can we get weather?  By the time you complement this with dual coms, navs, xpdr, a/p, audio etc, and at close to 70c to the USD, the panel becomes a mighty expensive proposition.  I would like to consider this as an option b4 I commit to the GRT, which imho is a better bang for the buck option, so all comments appreciated.
cheers,
Ron
187
[quote] --
Tim(at)MyRV10.com
PostPosted: Thu Mar 23, 2006 2:35 pm    Post subject: Chelton SV-10 Reply with quote
I checked with Josh at D2AV today on a couple things:
* They updated the .pdf with the proper phone number
* They are very busy and will get out more info on the harness details
after Sun-N-Fun, as they're rushing to get things ready for the show
right now.
* The approximate cost of the harness purchased separately is $2,210.00
Beyond that, to answer Ron's questions, the Terrain database is the same
as all the other units...there is only one terrain database. The
weather is an add-on module that can be added on at any time. WSI is
merging with Sirius, so later there will be a new WSI receiver. On my
site this a.m. I posted some WSI news that since I had a non-activated
AV100 receiver, if I activate a plan or buy hardware in 2006, I will
get a free AV300 receiver in late 2006 when the merge is done, which
will let me work with Sirius/WSI for weather. Until then I'll have my
plain old WSI as usual. I believe that it's very likely you'll hear
that you can add XM weather to the Chelton this year as well, so yes,
you can get weather. The important thing to remember is that the panel
mounted screens themselves are identical to the units they've been
selling recently that are non-RV-10, except that they have a different
startup graphic.
You are correct that when you add all of it up it becomes quite
an expensive panel. If you fill your panel with all sorts of stuff,
it's going to cost a lot....especially if you put lots of Garmin stuff
in there. 480's/530's and GDL-69's, MX-20/GMX200's, and all of the
toys, the panel is going to be a considerable hunk of your plane's
cost. In my case, I'm figuring my panel is about 38-40% of the overall
cost of the plane.
The GRT is also a very good bang for the buck, and is a good system,
it's just different.
It's like shopping for a Geo (Dynon) Chevy (GRT) BMW (Chelton) or
Ferrari (Avidyne/Garmin G1000) They all get you there, but you get
increasing resolutions/reliability/features depending on how far you
push the purchases. Strive for the best you can within your budget,
and you can make a very good panel with just about any of the systems.
McGANN, Ron wrote:
[quote] Indran and other Ozzie 10 builders.
cheers,
Ron
187
n8vim(at)arrl.net
PostPosted: Thu Mar 23, 2006 2:52 pm    Post subject: Chelton SV-10 Reply with quote
Any idea what the cost is?
I know I'll be broke after buying an engine, so I may have to wait a few
years for a real panel, but may as well get the sticker shock out of the
way now!
-Jim 40384
right now.
same as all the other units...there is only one terrain database. The
panel mounted screens themselves are identical to the units they've
been selling recently that are non-RV-10, except that they have a
different startup graphic.
cost of the plane.
> cheers,
> Ron
> 187
> do not archive
PostPosted: Thu Mar 23, 2006 2:56 pm    Post subject: Chelton SV-10 Reply with quote
Ron,
Apparently terrain is based on international Jeppesen database - so will include Aussie terrain & published obstructions.
Weather not likely to ever appear on Satellite radio. However, I plan to mount a small car PC & touchscreen into the dash, with a CDMA "mobile broadband" adapter. The reception is surprisingly good in the air - I get coverage most of the way from Bunbury to Geraldton at 2-5000 ft. Would be good to have access to the NAIPS system both in the air and on the ramp prior to takeoff - imagine submitting a flight plan via internet while flying! Also the Bureau of Meteorology website has links to weather radar around the country, updated every 10mins.
No doubt that the GRT better value for money, but I am leaning more toward Chelton for the terrain, traffic (with Mode S transponder) and safety in numbers - more units out there (both certified & experimental). Also WAAS upgradeable whenever we get it down under.
The word on the SV-10  with wiring harness is that it will cost approx $1000 more than standard. They will start shipping units in May, with 40 projected to go out the door by November.
Indran
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Friday, 24 March 2006 5:56 AM
Subject: RE: Chelton SV-10
cheers,
Ron
187
[quote] --
 Filesize:  44.12 KB
 Viewed:  610 Time(s)
 Filesize:  68.95 KB
 Viewed:  642 Time(s)
PostPosted: Thu Mar 23, 2006 3:03 pm    Post subject: Chelton SV-10 Reply with quote
Hi Tim - great response as always.
I was under the impression that 'the rest of the world' including us deep southerners received lower resolution terrain compared to North America.  Also, my understanding of the Weather capability is that the data are sourced from satellite.  I'm pretty sure we don't have access to that data down here.  Garmin 396's aren't that popular here for that reason.  Would be delighted if I am wrong, 'cause I really like the Chelton system.
cheers,
Ron
acs(at)acspropeller.com.a
PostPosted: Thu Mar 23, 2006 4:12 pm    Post subject: Chelton SV-10 Reply with quote
Ron and Indran, also keep in mind the introduction of ADS-B (draft AC-21-45(0) released yesterday).
There may well be another box to buy. It might influence your transponder choice.
Also check out AIRNAV www.sentientsoftware.com.au for their panel based PC running XP with touch screen. VFR info but you can display moving map over genuine charts.
Just a thought, combine 300XL with SL30 and you get two comms, a nav and a gps all readable from the GRT’s, a saving of $2K + over the 430 with an extra comm for  similar capability.
John 40315
Sent: Friday, 24 March 2006 9:03 AM
cheers,
Ron
[mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)]On Behalf Of Tim Olson
Sent: Friday, 24 March 2006 9:04 AM
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
right now.
startup graphic.
cost of the plane.
deej(at)deej.net
PostPosted: Thu Mar 23, 2006 4:33 pm    Post subject: Chelton SV-10 Reply with quote
Hi John,
Any idea where to find this document online?
I tried Google and the FAA site, but no joy.
-Dj
PostPosted: Thu Mar 23, 2006 4:55 pm    Post subject: Chelton SV-10 Reply with quote
Sorry Dj,
I meant to clarify,
"6. APPLICABILITY
6.1 This AC is applicable to all Australian registered aircraft and foreign
aircraft wishing
to transmit ADS-B information in Australia."
The Australian CASA will be consulting with the FAA in any case and it may
provide interesting reading for you, so if you still want a copy I'll
forward it to your personal email.
John
deej(at)deej.net
PostPosted: Thu Mar 23, 2006 5:02 pm    Post subject: Chelton SV-10 Reply with quote
Ah! Well, that makes sense why I could not find it... *grin*
Actually, I'd love a copy if you don't mind. I'm very interested
in ADS-B.
-Dj
jesse(at)itecusa.org
PostPosted: Fri Mar 24, 2006 5:17 am    Post subject: Chelton SV-10 Reply with quote
Anyone know the price for the whole shebang?
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of May.  You may call me at 352-505-1899 and leave a message that I can check from down here.  Any I-TEC questions can be directed to the I-TEC office at 352-465-4545.
40228
Tim(at)MyRV10.com
PostPosted: Fri Mar 24, 2006 5:45 am    Post subject: Chelton SV-10 Reply with quote
It's going to be right around $26,000.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>
www.itecusa.org <http://www.itecusa.org>
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Indran
Chelvanayagam
*Sent:* Thursday, March 23, 2006 11:14 AM
*To:* rv10-list(at)matronics.com
*Subject:* Chelton SV-10
offering.
40228
rnewman(at)lutron.com
PostPosted: Fri Mar 24, 2006 6:28 am    Post subject: Chelton SV-10 Reply with quote
Tim, I had a long discussion with Josh at Direct 2 and I'm almost
certain he said the price is going to be $26,900.
Bob
>> Tim(at)MyRV10.com 3/24/2006 8:44:46 AM >>>
Jesse Saint
I-TEC, Inc.
of
I-TEC
Chelvanayagam
basic
offering.
40228
stein(at)steinair.com
PostPosted: Fri Mar 24, 2006 6:59 am    Post subject: Chelton SV-10 Reply with quote
$26,900
[quote] --
Goto page 1, 2  Next
Page 1 of 2
