Riveting rudder hinge
K Dilks
PostPosted: Sat Dec 06, 2008 4:28 am    Post subject: Riveting rudder hinge Reply with quote
Hi all ,
just riveting the rudder together and noticed I cant get the rivet gun on the rivets for the upper hinge brackets, also I see people leave them off until later but I cant find any reference to this.
How do you rivet these 2 parts on? plane says A5 rivets
Kev
Back home .................
Ianrat
PostPosted: Sat Dec 06, 2008 5:06 am    Post subject: Re: Riveting rudder hinge Reply with quote
I have used small bolts instead of the outer two rivets. Some plains were having a problem with the hinge becoming loose over time. If you can not get the rivet gun onto the rivet you can get a puller that has the sides ground back. Most tool suppliers will have these. Yes i did wait until i was able to fit the rudder to the fuselage before fitting the top hinges.
Hope this helps you out
Ianrat
Bolted top rudder hinges
 Filesize:  379.52 KB
 Viewed:  767 Time(s)
 Filesize:  493.19 KB
 Viewed:  799 Time(s)
ideaz1(at)sbcglobal.net
PostPosted: Sat Dec 06, 2008 7:35 am    Post subject: Riveting rudder hinge Reply with quote
look here and see the video "pull riveting in tight places" it is quite
simple. http://www.eaa.org/video/homebuilders.html?videoId=1858922506
Dirk
Hi all ,
Kev
Austria .............
http://forums.matronics.com/viewtopic.php?p 17890#217890
naumuk(at)alltel.net
PostPosted: Sat Dec 06, 2008 9:36 am    Post subject: Riveting rudder hinge Reply with quote
Kev-
The reason you leave one set of hinges off is to make it easier to line
them up with the fuse. Being as I'm the valedictorian of the school of hard
knocks, take it from me-I highly recommend waiting.
Bill
JohnDRead(at)aol.com
PostPosted: Sat Dec 06, 2008 3:45 pm    Post subject: Riveting rudder hinge Reply with quote
Hi Kevin;
 I found that with many of the rivets that are close in I had to modify a hand riveter. I did this by grinding off the sides of the rivetter so I could get in close. The rudder is one of many places where the air riveter cannot get in close enough. I can send a picture if this would help
John Read
CH701 in Colorado
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 12/6/2008 5:29:37 A.M. Mountain Standard Time, kevin.dilks(at)liwest.at writes:
--> Zenith601-List message posted by: "K Dilks" <kevin.dilks(at)liwest.at>
Hi all ,
Kev
http://forums.matronics.com/viewtopic.php?p=217890#217890
Stay in touch with ALL of your friends: update your AIM, Bebo, Facebookn=new-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000012">The NEW AOL.com.
paulrod36(at)msn.com
PostPosted: Mon Dec 08, 2008 12:50 pm    Post subject: Riveting rudder hinge Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> John, several years ago somebody came up with a good fix-- They took a piece of half inch rod, drilled it slightly larger than the rivet stem, cut it about half an inch long, and then ground a 30 to 40 degree flat on one end. The idea was that you slip it on the rivet shaft with the angled flat to the puller, ran the shaft into the riveter nose, and pulled the rivet. The shaft then bends around the corner as you pull. I made one, and it worked well.
Paul Rodriguez
601XL/Corvair
n85ae
PostPosted: Tue Dec 09, 2008 8:24 am    Post subject: Re: Riveting rudder hinge Reply with quote
If you use bolts you will need to have access plates installed. A better
way if you're worried about the rivets is to use Solids. They are MUCH
stronger than A5's
Jeff
PostPosted: Tue Dec 09, 2008 1:01 pm    Post subject: Riveting rudder hinge Reply with quote
If you are worried about strength why not use A6 rivets. If you use either bolts or solids you will need access to the inside of the rudder.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 12/9/2008 9:28:11 A.M. Mountain Standard Time, n85ae(at)yahoo.com writes:
--> Zenith601-List message posted by: "n85ae" <n85ae(at)yahoo.com>
stronger than A5's
Jeff
http://forums.matronics.com/viewtopic.php?p=218486#218486
Stay in touch with ALL of your friends: update your AIM, Bebo, Fa/?optin=new-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000012">The NEW AOL.com.
ter_turn(at)yahoo.com
PostPosted: Tue Dec 09, 2008 1:46 pm    Post subject: Riveting rudder hinge Reply with quote
How about SS rivets?
JohnDRead(at)aol.com wrote:[quote] If you are worried about strength why not use A6 rivets. If you use either bolts or solids you will need access to the inside of the rudder.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
stronger than A5's
Jeff
http://forums.matronics.com/viewtopic.php?p 18486#218486
n85ae
PostPosted: Wed Dec 10, 2008 12:56 pm    Post subject: Re: Riveting rudder hinge Reply with quote
You could use CherryMax expensive, but strong
If you use solids you only need access when you put them in, but then you
can close the rudder skin. Bolts, you will need permanent access. Unless you
put in nutplates.
I bought a rivet gun to shoot solids, and the better I get with it, more I find
I use it.
I made a test fixture with a hydraulic jack, and A5's really tear apart
easily, always before the surrounding material. Solids generally tear
out a hunk of material. I have never failed a solid, always the material
the rivet is in fails first (that is with 6061 sheet)
A5's are strong initially in sheer because of the steel core, but as soon
as the structure deforms, the heads pop right off. Not very impressive
in my opinion.
Jeff
PostPosted: Wed Dec 10, 2008 7:50 pm    Post subject: Riveting rudder hinge Reply with quote
Good question, I think they would be OK. I would call ZAC before using SS though. do not archive
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 12/9/2008 2:51:27 P.M. Mountain Standard Time, ter_turn(at)yahoo.com writes:
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
stronger than A5's
Jeff
http://www.matronics.com/Navigator?Zenith601-List eb = ============ [/b]
One site keeps you connected to all your email:-dp&icid=aolcom40vanity&ncid=emlcntaolcom00000019">The NEW AOL.com.
