Posted: Wed Dec 03, 2008 3:42 pm Post subject: Does the Alternator shut down if battery power is removed? |
Given an alternator and an LR3 controller, with the engine running, will
the alternator shut down if the battery master is switched off?
I'm guessing that the alternator will continue to function normally
since it's still self-exciting the field line. Shutting down the
alternator would require pulling the field breaker.
Is that correct?
Bill Watson
RV10 with a Z-14
