jjflyboy(at)gmail.com Guest
Posted: Tue Dec 02, 2008 12:46 pm Post subject: Use of Vans ES14684 60A Alternator |
Sorry if this question has been dealt with before, but I would like to know if use of a Vans ES 14684 60A alternator with internal regulation would be suitable in a system designed around Bob's Z-11 Generic Light Aircraft Electrical System. As this alternator is internally regulated, is the generic "Ford" regulator still needed or should it be eliminated? I am also considering purchase of the Overvoltage Module (OVM-14) from B & C but see there is a caution about using OV protection with this alternator on Vans site. The caution concerns a need to contact the manufacturer of the OV device to ensure any special wiring requirements are met. Would the Z-11 diagram show the correct wiring for use of this device with this alternator?
I also have a Grand Rapids (model 4000) EIS I am planning on using so I plan on eliminating the low voltage monitor module (AEC 9005 - 101) as I believe this function is included in the EIS. Any comments?
Thanks for your help.
Jerry
Posted: Fri Dec 05, 2008 5:47 am Post subject: Use of Vans ES14684 60A Alternator |
At 02:45 PM 12/2/2008, you wrote:
| Quote: | | Sorry if this question has been dealt with before, but I would like to know if use of a Vans ES 14684 60A alternator with internal regulation would be suitable in a system designed around Bob's Z-11 Generic Light Aircraft Electrical System. As this alternator is internally regulated, is the generic "Ford" regulator still needed or should it be eliminated? |
It's eliminated.
| Quote: | | I am also considering purchase of the Overvoltage Module (OVM-14) from B & C but see there is a caution about using OV protection with this alternator on Vans site. The caution concerns a need to contact the manufacturer of the OV device to ensure any special wiring requirements are met. Would the Z-11 diagram show the correct wiring for use of this device with this alternator? |
I was recently offered a tour of an alternator/
starter remanufacturing facility that produces about
22,000 units a day. They box product for a host of customers
not the least of which is AC Delco and includes many of
big-name chain stores.
I learned that it's exceedingly difficult if not impossible
for a "small" users of alternators to acquire a factory-fresh
device . . . The folks who build brand new product want to
schedule car-loads of units to a minimum number of deliveries.
This is because transportation and handling is a MAJOR cost of
the product.
I'm working on a white-paper that will publish details of
what I learned but the short answer now is that we don't
know where Van's alternators come from. We do know that SOME
parts were vulnerable to their own load dump transients
in the past.
I do know that the factory, QA and IR&D facilities I toured
produces products intended to withstand a series of five, max-rpm,
max-current, high-temperature load-dumps in a row without damage
to its internals. I witnessed one such demonstration in their labs.
14684 is a "Lester Number" . . . an industry cataloging
system that brings parts of like functionality into a
specific application. While this part number MIGHT
get you a device with all original parts from the
likes of Nipon Denso or Bosch, it's not a guarantee
and most likely, the part has been disassembled for
some manner of refurbishment.
If you want to buy 100 pcs minimum per month, you
can put your hands on brand-new 14684 machines
here:
http://tinyurl.com/5sguzm
Bottom line is that there are dozens of alternators
from DOZENS OF SOURCES that are adaptable to your
engine. By adaptable we mean that the alternator
requires appropriate mounting configuration to
bolt to your machine. Van offers a kit of tension
arm and bracket to adapt a "14684" alternator to
Lycoming engines at:
http://tinyurl.com/5uz5n6
I'll call the reader's attention to the caveat on
Van's page that reads as follows:
Caution: Builders planning to utilize overvoltage protection with
Van's internally regulated 60 amp alternator should consult with
the manufacturer of the overvoltage device to insure that any
special wiring requirements are met during installation.
I've never enjoyed direct conversation with folks
at Van's in spite of specific attempts
to enter into constructive dialog. Their
initial reaction to reported failures of
alternators combined with b-lead disconnect
contactors was not so measured as the statement
above. As it turns out, not all alternators
are potential victims to their own load-dump
transients in spite of the fact that they
have THE SAME part number.
The short answer is that installing ANY internally
regulated alternator with external ov protection
described in:
http://tinyurl.com/5n989y
. . . is a perfectly rational thing to do. Just
be wary of turning the alternator OFF under
load at more than idle RPM until the final
solution described is available.
Alternatively, one may certainly run the alternator
"barefoot" as many folks recommend. This discussion
isn't about imperatives. It's about risk reduction.
| Quote: | | I also have a Grand Rapids (model 4000) EIS I am planning on using so I plan on eliminating the low voltage monitor module (AEC 9005 - 101) as I believe this function is included in the EIS. Any comments? |
The low voltage annunciation on your EIS is
a useful substitution for independent low
voltage warning.
Bob . . . [quote][b]
