hammer408(at)comcast.net Guest
Posted: Fri Nov 28, 2008 10:20 am Post subject: Heavy Duty E-Bis Diode |
Bob:
I'm putting together my Relay and just noticed that your Z 32 diagram for
the Heavy Duty E-Bus relay uses a IN4001 Diode. When I ordered my relay
from B&C a month or 2 ago, they supplied me with the IN5400 Diode which
corresponds to their diagram.....
My question is: Is it critical that I use the IN4001 Diode for my Heavy
Duty E-Bus configuration or can I use the 5400?
Henry
nuckolls.bob(at)cox.net Guest
Posted: Fri Nov 28, 2008 11:41 am Post subject: Heavy Duty E-Bis Diode |
At 03:22 PM 11/28/2008, you wrote:
<hammer408(at)comcast.net>
Bob:
ANY diode will work electrically. The 5400 has larger
leads and may be difficult to get into the PIDG terminal
wire grip along with the 22AWG coil wire. If you can get
the crimp to work, it will be fine. Otherwise, go to Radio
Shack and get a 1N400x diode . . . any digit in the x
location is okay.
( -Thomas Paine 1776- )
Posted: Fri Nov 28, 2008 1:10 pm Post subject: Heavy Duty E-Bis Diode |
Thanks Bob:
I used the 5400....a little tough to crimp, but it cam e our just
fine.......
Henry
Eric M. Jones
Posted: Wed Dec 03, 2008 11:24 am Post subject: Re: Heavy Duty E-Bis Diode |
| Quote: | I'm putting together my Relay and just noticed that your Z 32 diagram for the Heavy Duty E-Bus relay uses a IN4001 Diode. When I ordered my relay from B&C a month or 2 ago, they supplied me with the IN5400 Diode which corresponds to their diagram.....
Duty E-Bus configuration or can I use the 5400? Thanks, Henry |
By the way....that's ONE N5400 not EYE N5400.
You should use bidirectional Zeners anyway....
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
