dewittw(at)earthlink.net Guest
Posted: Tue Dec 02, 2008 11:27 am Post subject: Where to find closed-end lugs for Super-CCA cable |
Where is the best place to buy lugs for Eric Jones' Super-CCA electric cable in #4 size? My partners wants a "closed end" type as suggested by Bob Nuckolls on one of his weekend seminars. It appears that Eric only sells the open end type. This would be a type which uses the "solder pellet" which you drop into the lug, then insert the wire and heat.
Dee
DeWitt (Dee) Whittington
406 N Mulberry St
Richmond, VA 23220-3320
(804) 358-4333 phone and fax
SKYPE: hilltopkid
dee.whittington(at)gmail.com [quote][b]
jindoguy(at)gmail.com Guest
Posted: Tue Dec 02, 2008 12:33 pm Post subject: Where to find closed-end lugs for Super-CCA cable |
Try welding supply and farm supply stores.
Rick
On Tue, Dec 2, 2008 at 1:24 PM, DeWitt Whittington <dewittw(at)earthlink.net (dewittw(at)earthlink.net)> wrote:
| Quote: | Where is the best place to buy lugs for Eric Jones' Super-CCA electric cable in #4 size? My partners wants a "closed end" type as suggested by Bob Nuckolls on one of his weekend seminars. It appears that Eric only sells the open end type. This would be a type which uses the "solder pellet" which you drop into the lug, then insert the wire and heat.
Dee
406 N Mulberry St
SKYPE: hilltopkid
dee.whittington(at)gmail.com (dee.whittington(at)gmail.com) [/b] |
