klwerner(at)comcast.net Guest
Posted: Wed Mar 22, 2006 10:14 am Post subject: Balanced |
| Quote: | >SNIP
..that the "regular" (whatever that means, probably factory) limits are good enough. He just laughed when I started talking about balancing combustion chamber cc, rod length, etc.
On the other hand, an engineer at Powerflow told me that in order to get the best out of their exhaust, to check the cam because the factory limits are so loose some don't get the scavenging done even though within factory specs.
Skip Simpson
Dear Skip,
I think you are absolutely correct. The regular Lycoming specified limits are "good enough" to produce a "good enough" running engine.
It may not necessarily be the greatest running engine, -nor the smoothest running engine. But it will be a "good enough" running engine.
That it's technology standards are well seasoned (I am not saying that this is good or bad) is "good enough" for such an Engine to provide good service!
And in regards to the Powerflow exhaust and their remark on the standard Lycoming camshaft specs, they may be loose but after all, they are "good enough" for a standard exhaust system!
Good enough now,
Konrad
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
